5DM3 VF display illumination
Started Apr 12, 2012 | Discussions
kpz4ever
Junior MemberPosts: 33
Apr 12, 2012
Good evening!
Does somebody know how to enable the VF display illumination on the the 5DM3? According to handbook it's in the AF5 setting and I got it activated there. Still it is not working when using the camera in any other mode than green.
Thanks!
Stefan
Canon EOS 5D
Dylthedog
Contributing MemberPosts: 692Gear list
Re: 5DM3 VF display illumination
In reply to kpz4ever, Apr 12, 2012
Mine only flashes red when the subject is below a certain light level - maybe you're trying it in bright conditions?
 Dylthedog's gear list:Dylthedog's gear list
Canon EOS 5D Mark II Olympus PEN E-P1 Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM +8 more
kpz4ever
In reply to Dylthedog, Apr 12, 2012
Nope. Bright light is not the issue, I basically need it under bad light conditions. It's hard to see what you are aiming at when the focus point is black
Thanks!
Stefan
Bartek
Senior MemberPosts: 1,408Gear list
should flash automatically, try resetting the settings to be sure that you didn't set anything by mistake - lots of options there
Good news is that it flashes at the green zone so not hardware failure probably - sounds rather like wrong settings
Bartek
 Bartek's gear list:Bartek's gear list
Canon EOS-1Ds Mark III Canon EOS 5D Mark III
Dylthedog
It's not illuminated by default - it remains black until you get focus, and it only then flashes red when the light is below a certain level.
A few people have complained about that.
The workaround is to press the focus point move button to change points then it illuminates. Or just remember where you left it
Thanks!
Stefan
Alfonso Bresciani
Senior MemberPosts: 1,622
Re: VF display illumination and af confirm is BAD
In reply to Dylthedog, Apr 13, 2012
Is THE ONLY thing I hate about the mIII and I even wrote to Chuck Westfall
that a $3500 camera should have a way better af illumination system, you can hardly see it turning red in bright light, and the smearing of the red light all over the VF is disgusting and distracting!
Alfonso Bresciani
http://nolaPIC.com/
http://www.pompo.com
http://www.flickr.com/photos/pompob/
Edymagno
Senior MemberPosts: 2,798Gear list
In reply to Alfonso Bresciani, Apr 13, 2012
I think diglloyd reported it as a total screw up.
Eduardo
Alfonso Bresciani
http://nolaPIC.com/
Alfonso Bresciani
In reply to Edymagno, Apr 13, 2012
I sure hope the 1DX won't have this cr@p viewfinder illumination!
Alfonso Bresciani
http://nolaPIC.com/
kpz4ever
In reply to Bartek, Apr 13, 2012
Yeah, did the reset. It works now, but I have no idea what I did wrong in the first place
Thanks!
Stefan
Bartek
kpz4ever
In reply to kpz4ever, Apr 15, 2012
Hi all!
I actually found it. AF illumination does not work in AI SERVO...no idea why. switching to ONE SHOT or AI FOCUS solves it. Makes no sense, but yeah
Thanks!
Stefan
24Peter
Senior MemberPosts: 2,990
kpz4ever wrote:
Hi all!
AFAIK - There's no AF illumination in AI Servo on any Canon DSLR - at least not on my 5DII, 60D, 40D, Rebel XT
View my photo galleries here: http://imageevent.com/24peter
Model Mayhem: http://www.modelmayhem.com/93181
shooter00
Regular MemberPosts: 305
In reply to 24Peter, Apr 15, 2012
Don't know about earlier 1D models but it is a feature of the MKIII and IV and works in AI servo.
There's a Cf.n to adjust it....
