I got my Q today.
Started Apr 12, 2012 | Discussions
brandrx
Forum ProPosts: 26,574
I got my Q today.
Apr 12, 2012
Hi folks,
I got my Q today. Damn that thing is small but a lot heavier than I expected. Battery is now charging.
Now, for the very first time ever, I will have to read the manual to figure out how to use it.
My reason for buying it is to use it with some long lenses for shooting at the birds. In the manner of snostorm (Scott).
Has anyone used the Pentax 5-15mm f/2.8-4.5 Zoom Lens for the Q? Is it worth a buy?
Thanks.
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
stern
Senior MemberPosts: 1,712Gear list
Re: I got my Q today.
In reply to brandrx, Apr 12, 2012
brandrx wrote:
Hi folks,
I have it and use it for the wide shots (the 01 prime is a bit narrow) and bought it as part of the double lens kit (was cheaper than buying it extra). The Q BW-high contrast samples on my Zenfolio site were all taken with the zoom (in a place called Penco in Chile). Also the pictures a bit further down in this forum (Easter exhibition in St. Jakob/Austria) were taken with the zoom.
Nevertheless I am eagerly awaiting Pentax to come up with a wide prime (I heard something about autumn 2012).
Thanks.
Cheers.
Ron
 stern's gear list:stern's gear list
Pentax MX-1 Pentax K-7 HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR
Ishpuini
Veteran MemberPosts: 6,076Gear list
brandrx wrote:
Hi folks,
Congrats Ron!! You'll find it a fun little camera to use! Though perhaps it's more of a city/street camera than an outdoor camera. For me the added value is that the Q allows me to have a camera with me at all times. When, as you(?), one drives around in a large car all the time, having a DSLR with you all the time is possible, so perhaps that added value of the Q will be much less for you?
Why? Its interface is almost identical to any Pentax DSLRs. Actually it's the first "compact" that I managed to "master" from the moment I put my hands on it.
That's what I intend to do with it as well. In term that is. I'm waiting for the Pentax adapter. None of the third party adapters seem to have a decent tripod mount. The reason being that the lenses I intend using (K135/2.5, FA50/2.8 macro) don't have their own tripod mount. And the shutter in the adapter should be an added value as well. I dread the price they will ask for it though.
My main use will remain everyday camera though.
As I wrote, I'm currently using it as an everyday camera, so the zoom is a bit too big to pocket the camera. I love the 01, and I'm eagerly awaiting the announced wide prime (hoping it will be as fast as the 01). Diffraction kicking in from f/4 onwards, means fast lenses are a necessity for decent IQ. The 02 zoom is on the limit.
Wim
PS: don't forget to update both firmware for camera and 01 lens to versions 1.01. Update process is very similar to DSLRs, though it won't launch when you start the camera while pressing the menu button. You need to go into the firmware menu and select which upgrade you want to apply (provided it's in the root of your card). The update is much much faster as on a DSLR btw.
Belgium, GMT+1
 Ishpuini's gear list:Ishpuini's gear list
Pentax Q Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +15 more
brandrx
brandrx OP
Wim...
In reply to Ishpuini, Apr 12, 2012
Ishpuini wrote:
brandrx wrote:
Hi folks,
Hi Wim,
I have an idea that I want to try out. Have 500mm or longer that I can keep, as a small package, in my Jeep at all times.
Yes, I see that now. So far I havn't had to open the manual.
Hopefully, if what I have planned works out, I will be using it without a tripod mount on the lens or the adapter. It should end up being 550mm to 1100mm (depending on which lens works best) that is small and easy to grab and shoot. That way I won't always have to have a monster lens with me to get those grab shots of birds that I sometimes see. More to come if it works.
I just figured I would try out lens 02 for times when I need a bit wider than 47mm and don't want to be carrying my DSLR with me.
Wim
I have updated the firmware for the lens 01 and the camera.
Cheers.
Ron
Ishpuini
Re: Wim...
Not sure working hand held will be easy. As far as I understand SR on the Q will not work for lenses other than the dedicated Q mount lenses. I suspect the camera will not ask for a focal length the way a DSLR does? Hence you will have to rely on the shutter speed to be fast enough to compensate the shake, i.e. apply the classic 1/(FocalLength x CropFactor) as approximation for the desired shutter speed. You'll be needing 1/1000s and faster most of the time.
Of course, shutter speeds are possible up to 1/8000s, so that should enable fast enough exposures, but you need enough light to allow for these. Though that will be using the electronic shutter. There is a risk of rolling shutter artifacts, though I expect that risk to be limited to non existing at these speeds. Still a leaf shutter should be preferred, and that will only be possible with the Pentax adapter, and probably only up to 1/2000s (as with the leaf shutter in the 01 prime).
Anyway, I suspect you'll be using a bean bag or sth like that?
My main issue so far with walk around compacts was IQ. And from tests with the Q I see that diffraction starts resulting in soft images once you stop down more than f/4. That means the tele end of the 02 will always suffer from loss of sharpness by diffraction. And the wide end will only have about one stop flexibility.
I found out the hard way that this is an important characteristic of the Q. My first walk only yielded good images when I used the 01 wide open. Most of the time I had (stupidly) been stopping down 2 to 3 stops as I'm used to do for glass on my DSLRs. Most shots were at f/6.3 and not that sharp... Actually the IQ for these was on the level that made me dismiss earlier compacts I owned. Now I use the 01 between f/1.9 and f/3.5 and I'm happy about IQ.
This diffraction issue means that you need fast glass that's great wide open for optimal performance on the Q. That should be an important factor in deciding which long lenses would work on the Q. Even the excellent FA*300/4.5 does not seem tack sharp in Snostorm's images, not because it's not good wide open, but I expect because of diffraction? Did he stop down the lens? I forget...
I'm looking forward to seeing your take on the diffraction story once you start working your way through your extensive long lens collection!!
Wim
Belgium, GMT+1
GeoffNS
Contributing MemberPosts: 585
Congratulations on your new camera. Hope you enjoy it. I'd be interested to know how it performs with a DA*300 F4 lens. I have one I use with my K10D, but I have not yet acquired a Pentax Q. (As the DA*300 has a tripod mount on the lens I expect that would make it easier to use.) Looking foirward to seeing examples of your Q photos. Regards, Geoff.
Jack Simpson
Forum ProPosts: 11,096Gear list
Re: I got my Q today. (Wide angle Zoom)
brandrx wrote:
Hi folks,
Hi Ron,
and congrats
IMO, I think it is and below is a link to some pics I took around the area where
I work, albeit with only one shot (I think) showing the zoom range. The majority were just shot at the wide-angle (27mm) end
http://forums.dpreview.com/forums/read.asp?forum=1028&message=40700238
And, FWIW, I printed them off at work (as 8x12) straight from the card and was,
frankly, amazed at the quality
Jack
Thanks.
Cheers.
Ron
STREET PHOTOGRAPHY DOCUMENTARY: http://www.youtube.com/watch?v=6kkHKP4Gnd0
( UPDATED NOV 16th )MY BLOG.... http://www.nakedmanonawire.blogspot.com
MY EMAIL ADDRESS IN IS MY 'VIEW PLAN'
It's amazing what one can do when one doesn't know what one is doing
 Jack Simpson's gear list:Jack Simpson's gear list
Canon PowerShot G2 Ricoh GR Digital IV Pentax *ist DS Pentax K-r Pentax K-50 +3 more
brandrx
brandrx OP
Re: Wim...
Wim,
All I know is that Scott gave ma an image to print from the FA*300/4.5 on the Q. I printed it, and as far as I am concerned it is a wall hanger to me. That single image is what gave me the courage to buy the Q for myself.
Cheers.
Ron
brandrx
brandrx OP
Jack...
In reply to Jack Simpson, Apr 12, 2012
Jack Simpson wrote:
brandrx wrote:
Hi folks,
Hi Ron,
and congrats
Jack
Thanks Jack. I ordered the zoom.
Ron
Jack Simpson
Re: Jack...
In reply to brandrx, Apr 13, 2012
brandrx wrote:
Jack Simpson wrote:
brandrx wrote:
Hi folks,
Hi Ron,
and congrats
Jack
Hi Ron,
Ya will nae be disappionted and, when/if, Pentax comes out with their
lens adapter (for K lenses), you can pop on a 100mm lens and have the
equivalent of a 500mm lens and, god forbid, you pop on a 500mm lens :o
;D
Jack
Ron
Richard Smals
Senior MemberPosts: 1,778Gear list
Mine tomorrow, hopefully ...congrats.
I hate the battery loading part...how long will it take?
I watch you so better excel in taking those first shots. Enjoy
Bye4now
http://www.indots.nl
I have the deepest respect for all those people who like me.
brandrx
brandrx OP
Re: Jack...
In reply to Jack Simpson, Apr 13, 2012
If I read correctly somewhere before the crop factor is 5.5.
Of course as soon as I get the proper adapter I will surely have to try my Nikon 400mm f2.8 lens. Dang! That's 2200mm.
Cheers.
Ron
brandrx
brandrx OP
Shooting in total darkness.
In my opinion, using focus assist beam, this little gem takes pretty dang good images in total darkness using the flash.
So much to learn about this little monster.
Cheers.
Ron
arnelie
Regular MemberPosts: 320Gear list
Why diffraction loss on the Q with big glass?
In reply to Ishpuini, Apr 13, 2012
Hm, I do not understand the math behind why e.g. the 300/f4.5 should pose diffraction limitations at let say f4.5-5.6 on the Q when it does not on an APS-C sensor (K5, e.g.)! The Q only captures the inner part of the image circle, which should be the part with the best resolution, yes? Intuitively, I can understand why it happens in small compact lenses, with much smaller image circle. Can somebody enlighten this topic, please?
/Arne
 arnelie's gear list:arnelie's gear list
Pentax K-7 Pentax smc FA 50mm F1.4 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA 21mm F3.2 AL Limited Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Ishpuini
Re: Why diffraction loss on the Q with big glass?
In reply to arnelie, Apr 13, 2012
There's the pixel size, which is much larger on a APS-C sensor than it is on a 1/2.3" sensor. Hence diffraction will be visible much sooner. Slightly deviated light beams may still hit the correct pixel if that pixel is large enough, whereas they'll miss it in case of a smaller pixel and as such cause blurring.
I think you're confusing two things. It's true that the more the outer limits of the image circle are avoided the better the results will be. Hence stopping down is often required to use a lens optimally. Diffraction, however, is caused when light beams passing at the edge of the opening are deviated. The smaller the opening, the larger the proportion of light affected by this. This is why stopping down too much you see IQ drop off again.
I never worried about this on my DSLRs, but I did start noticing it on my K-5 when I stopping down to f/22 (I never noticed it as much on earlier cameras with larger pixels). Mistakingly using the 01 on the Q at f/6.3 drew my attention that on the Q, diffraction may be a more important factor to take into account.
Anyway, I have always understood that diffraction is related to pixel size on the sensor rather than being lens dependent. Perhaps I got it wrong? I'm not really sure whether the relative opening (the f/stop) or actual physical opening determines diffraction. I'm looking forward to learning about this in order to be able to use my gear optimally. I'm sure the "problem" can be easily avoided.
Wim
Belgium, GMT+1
Ishpuini
Re: Wim...
brandrx wrote:
Wim,
Cheers.
Ron
That sounds like good enough a reason! Looking forward to seeing your results Ron!
Wim
Belgium, GMT+1
brandrx
brandrx OP
Influence of diffraction
Scroll down after the link to "Influence of diffraction".
When I enter the numbers for the Q I get 4.2 for Diffraction Limited Aperture.
Cheers.
Ron
Ishpuini
Re: correct result is f/3.1 :-(
Cheers.
Ron
Tx Ron! I forgot about the calculators on that site. A great resource it is!
BTW, which sensor size did you enter? I suspect 1/2" is closest (the Q having a 1/2.3"), but that gives me a number of f/3.1? That's in line with what I see for the 01 lens: OK up to f/2.8, then it starts degrading.
I think you made a mistake in putting 2/3" for the sensor size? I wasn't sure at first when I got a different number to yours, so I tried the Focal Length Multiplier Calculator higher up the page, and that confirmed to me that 1/2" is the closest size to the Q's sensor size.
Anyway, diffraction kicks in gradually, so perhaps the FA*300/4.5 wide open will still just be within what we find OK, as you concluded from the print you did.
Regardless, practice will show...
Wim
Belgium, GMT+1
brandrx
brandrx OP
Wim...
Cheers.
Ron
Wim, you are correct. I just made a mistake. Brain fart I guess.
EDIT: I will probably just be using f2.8 long lenses. Of course I will experiment with others though. Perhaps a tryout with the Canon FD 200mm f4 Macro and the Canon FD 400mm f4.5 lenses.
Ron
PaulParis
Forum MemberPosts: 84Gear list
Re: Mine tomorrow, hopefully ...congrats.
In reply to Richard Smals, Apr 13, 2012
loading battery not more than an hour and a half, it's only a small one (small camera)...
