46mm UV Filter for Sigma 30mm Lens
Started Apr 10, 2012 | Discussions
Uncivilizedamd
Junior MemberPosts: 33
Apr 10, 2012
What UV filters are you guys using for your sigma 30mm lens or in general what 46mm UV filters are recommended?
headofdestiny
Veteran MemberPosts: 9,179
Re: 46mm UV Filter for Sigma 30mm Lens
In reply to Uncivilizedamd, Apr 10, 2012
You first need to decide if you want to use one at all. If you do, you can't really beat Hoya multicoated filters, for the price. In fact, according to this test, regardless of price:
http://www.lenstip.com/113.1-article-UV_filters_test.html
John Bean (UK)
Forum ProPosts: 18,034
In reply to headofdestiny, Apr 10, 2012
You first need to decide if you want to use one at all...
... is the right answer
John Bean [BST (GMT+1)]
headofdestiny
In reply to John Bean (UK), Apr 10, 2012
Yep, I rarely use UV filters, but, of course, there are about a billion threads on that topic.
Uncivilizedamd
yep decided already to use one
Knallberto
Senior MemberPosts: 5,478
Smiert Spionam
Contributing MemberPosts: 542
In reply to Knallberto, Apr 10, 2012
Knallberto wrote:
More than $ 5 for 46 mm pol filter are searobbery!
UV filters are 102% UNnecessary !
http://www.ebay.com/sch/i.html?_nkw=filter+46mm+polarizing&_sacat=0&LH_BIN=1&_dmpt=Camera_Filters&_odkw=filter+46mm&_osacat=0&_trksid=p3286.c0.m270.l1313
Oh, brother.
(I do agree about UV filters, in the vast majority of situations, though.)
amuro
Regular MemberPosts: 306Gear list
In reply to Smiert Spionam, Apr 11, 2012
when I have the coupon I usually get the B&W filter which cost about the same after the discount.
people in glass houses shouldn't throw stones...
 amuro's gear list:amuro's gear list
Sony Alpha NEX-5 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony DT 35mm F1.8 SAM Sony E 18-200mm F3.5-6.3 +10 more
Sagiluck
Junior MemberPosts: 47Gear list
In reply to Uncivilizedamd, Apr 11, 2012
The front glass just so small, easier to take care without any filter
 Sagiluck's gear list:Sagiluck's gear list
Sony Alpha 7 Sony FE 24-70mm F4 OSS +2 more
jeep
Forum MemberPosts: 62
Sigmas own 46mm UV filter seemed like a no brainer, got one with the lens at time of purchase.
DtEW
Senior MemberPosts: 1,630Gear list
Based on the Sigma 30mm's excellent resistance to flare... I'm hoping (guessing?) it has something to do with their coating, and so I decided to find one of their DG filters as an alternative to the usual Hoya Super HMC's I use on my primes. They seem to be well-reviewed. I guess I'll see tomorrow when I receive it.
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Canon EF 100mm f/2.0 USM Canon EF 75-300mm f/4.0-5.6 IS USM Canon EF 24-105mm f/4L IS USM Samyang 14mm F2.8 IF ED MC Aspherical +14 more
Silat Shooter
Contributing MemberPosts: 746
In reply to DtEW, Apr 11, 2012
As others have said, it's really unnecessary. Photographically speaking, adding a another glass element can lead more refraction on the glass surface. But no doubt, it will add a layer of protection for the front element. So peace of mind for the investment.
I think a lens shade/hood would be more useful. I'll probably pick up a cheap rubber one for mine.
Was happy to see the lens is "Made in Japan". Sure doesn't feel great, especially off camera when you can hear something loose inside. But results look quite good so far and the size is great.
wll
wll
Veteran MemberPosts: 4,820
I use all B+W UV multi coated pro-F and have not been disappointed. I like the fact that the filter ring is made of brass and have not had one bind up on the lens.
I have also used Hoya multi coated filters with good luck.
wll
John Bean (UK)
In reply to wll, Apr 11, 2012
Brass is good to avoid binding, especially if the lens filter thread is aluminium. I doubt it makes any difference on a plastic thread though.
I have found B+W hard to clean for whatever reason. They used to be my number one choice at one time, but these days I'd take Marumi over B+W every time.
Hoya Pro-1 are pretty good as well but "ordinary" Hoya are no better than most Chinese knock-offs at a fraction of the price.
They're all seriously over-priced though - look how much a complex multi-element lens like the Sigma 30 costs then consider why a simple plain - plane even - UV filter costs as much as it does. "Rip off" springs to mind.
probert500
Contributing MemberPosts: 953Gear list
Re:I'd get a step up ring
46mm is an odd size. I'd get a 46 to 52 and/or a 46 to 49 step upring and use standard filters you may just have hanging around. 49mm is the thread on the kit zoom - if it were my I'd be trying to standardize my threads.
probert500
Re: 46mm UV Filter for Sigma 30mm Lens re binding
In reply to John Bean (UK), Apr 11, 2012
If a filter seems stuck try unscrewing it by pressing it with the palm of your hand and then twisting. Sometimes grabbing w 2 fingers can distart the filter making it hard to turn.
nightin9ale
New MemberPosts: 17
