How to remove dust from inside barrel of a Canon EF-S 18-200mm
Started Apr 10, 2012 | Discussions
Fab Fish Junior Member • Posts: 47
Hi folks
Is there a guide or video that explains hHow to remove dust from inside barrel of a Canon EF-S 18-200mm ?
TIA
 Fab Fish's gear list:Fab Fish's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF 70-200mm f/2.8L IS USM Canon EF 100mm f/2.8 Macro USM +1 more
theatrus Senior Member • Posts: 1,335
Re: How to remove dust from inside barrel of a Canon EF-S 18-200mm
You'd have to fully disassemble the lens, which I strongly do not recommend doing (especially the plastic lens bodies).
Have you noticed an effect on your images?
Warning: The internet is filled with one sided views. Stay objective.
 theatrus's gear list:theatrus's gear list
Canon EOS 5D Canon EOS 300D Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 24-70mm f/2.8L USM +2 more
hotdog321
hotdog321 Forum Pro • Posts: 15,457
Unless you have an issue with it showing in your photographs, don't worry about it. Very doubtful you can clean it yourself without trashing the lens. The only alternative is an expensive Canon repair.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
Fab Fish OP Junior Member • Posts: 47
Thanks for the replies so far. I am worried some of the dust will now end up in the camera body. I was hoping all I would need to do is to remove the front element? If they cannot be cleaned via DIY any idea what canon charge for cleaning them?
hotdog321
Disassembling and reassembling a zoom lens is no joke. It would probably cost more than the lens is worth.
There is no reason for the dust to work itself from the interior of a lens into the camera body. And if it does, the sensor is (relatively) easily cleaned.
Relax. Take pictures!
js473 New Member • Posts: 8
i know this post is old but i tool will like to if there is a DIY guide on how to open and clean the lens.
Because of the fungus build up on the inside of the glass both front and rear i get a blueish haze when i take pictures also the lens experiences trouble to auto focus when zoomed in anywhere after 70mm.
I dont mind the risk of cleaning the lens myself as i only paid $200 US for it and it more expensive to get it professionally clean than the cost of the lens itself. Also i'm looking to upgrade to either canon 17-40mm, canon 16-35mm or a sigma alternative, so it doesnt bother me if the lens become useless afterwards
 js473's gear list:js473's gear list
Canon EOS 600D Canon EF 50mm f/1.8 II Canon EF-S 18-200mm f/3.5-5.6 IS Samyang 8mm F3.5 Aspherical IF MC Fisheye Canon EF-S 55-250mm f/4-5.6 IS II
