16-35 VR, vignetting and filter stacking
Started Apr 9, 2012 | Discussions
Canyongazer
Regular MemberPosts: 196Gear list
Apr 9, 2012
I've been using 10 stop and 6 stop 77mm ND filters together stepped down to the 72mm thread of a 24-85 f2.8-4 Nikon for long daylight exposures. Even with the slightly oversized filters, I'm getting some vignetting at 24mm/ f9.5. A bit of reverse vignetting in Lightroom and a tiny bit of cropping usually fixes it.
I would like to go wider and am considering the 16-35 f4VR but am concerned the vignetting with the then not oversized 77mm filters will require cropping, thus negating some of the extra field of view.
And yes, I'm sure I like wider than 24....my most used wide is the 14-24 f2.8
Anyone with filter stacking experience or, perhaps, polarizer use on this lens? What do you think?
 Canyongazer's gear list:Canyongazer's gear list
Fujifilm X100S +2 more
Mako2011
Forum ProPosts: 14,383
Re: 16-35 VR, vignetting and filter stacking
In reply to Canyongazer, Apr 9, 2012
DX or FF?
Canyongazer
DX or FF
In reply to Mako2011, Apr 9, 2012
Sorry, should have said: FF
D700
D800 is on deck.
Mako2011
I shoot it on DX so vignetting isn't a big problem even stacked once.
The best I can do for FF vignetting example is here and as you can see even without filters vignetting can be an issue unless you post process to remove. Stacked I would think there may be issues but you could always frame the subject such as to mitigate the problem. Good luck and sorry I couldn't help more.
http://mansurovs.com/nikon-16-35mm-f4-vr-review
john Clinch
Senior MemberPosts: 2,633
I'd contact Ian Bramham
http://www.dpreview.com/members/2361742005
He's got that lens and is big on ND stacking. I think he said it was alot better than the Sigma 10-20 on DX
Mako2011
In reply to john Clinch, Apr 9, 2012
May be of help but does Ian shoot FF as the OP is not using a DX body?
shakes268
Forum MemberPosts: 71Gear list
What size filters are you using? The standard Cokin P holder filters are 85mm.
The next size up is 100mm - (Lee, Hitech Modular System, Cokin Z).
I used Cokin P size but have recently switched to a larger size and a better holder (or hand hold) and it helped out quite a bit.
 shakes268's gear list:shakes268's gear list
Nikon D90 Nikon D700 Nikon AF-S Nikkor 16-35mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +1 more
ShelNf
Regular MemberPosts: 381
In reply to shakes268, Apr 9, 2012
You're probably going to need to move to a Lee holder with a wide angle adapter, with 100mm filters. I had a 2 week wait for mine which wasn't too bad, they are hard to get these days.
Canyongazer
In reply to john Clinch, Apr 10, 2012
Thanks for the link, John.
Ian B. seems to be using it on a D700 now so I sent him an email.
Am considering a used 20mm 2.8 Nikon as an alternative...it takes 62mm filters so ought not (I think) vignette with 77s and a step ring. From what I've read it is a good performer at f8 which is where I normally set the aperture for wide angle lens/landscape.
I really want to use the two rather good and rather expensive B+W NDs I already have rather than go the Lee slide in route.
Thanks to all for taking the trouble to reply.
