D800 AF Fine Tune: Matters more than D700...
Started Apr 7, 2012 | Discussions
DvD5
Contributing MemberPosts: 831
Apr 7, 2012
I just spent the entire day yesterday fine tuning the AF on the D800 for each of my lenses. Interesting because I had to dial in quite a bit of adjustment for nearly all my lenses. This was not my experience on my D700.
If you don't shoot wide open and you don't make large prints/crops, then you may not notice, but otherwise I found this made a big difference for me.
In the end, here's what I came up with:
14-24mm f/2.8G: -20
24-70mm f/2.8G: -18
70-200mm f/2.6G VRII: -19
24mm f/3.5 PC-E: -14 (Based on the focus confirmation dot & LV)
50mm f/1.4G: -14
85mm f/1.4G: -9
500mm f/4G: +7
500mm f/4G + TC1.4 +20 (Note: this TC has always been an issue)
500mm f/4G + TC1.7 +2
These settings obviously won't work for your combination, but I thought it was interesting that most of my "regular" lenses needed so much adjustment. In a way I'm glad that my D800 body seems to be biased to the negative side since my 500 + 1.4TC combo has always been a problem on my D700 and D300s--It always wanted more than +20, but that was the limit...
YMMV, Don
http://www.dvd5.zenfolio.com
Nikon D300S Nikon D700 Nikon D800
ukat123
Contributing MemberPosts: 761
Re: D800 AF Fine Tune: Matters more than D700...
In reply to DvD5, Apr 7, 2012
Good to know. All my fast prime lenses (24G, 35G, 85G) needed a lot of adjustments on my D700 as well when shooting at 1.4
thomas2279f
Senior MemberPosts: 2,626Gear list
Thanks for sharing your settings..
 thomas2279f's gear list:thomas2279f's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Nikon D800 Canon EOS 70D A3000 +49 more
Yaamon
Senior MemberPosts: 1,741Gear list
That's excessive
In reply to thomas2279f, Apr 7, 2012
I also have a D800 on order and if I had to adjust my lens by that amount while on your D700 they were good I would send it back fro exchange or send it into Nikon and have them calibrate your D800.
Not good when you have to fine tune lens when they are at the limit of fine tune adjustment.
My D7000 had a similar issue constant back focus till I sent it in twice so the lens no longer needs any fine tune.
Canon 5D III, 5D II, 7D , 60D & Nikon D7000 & Sony A35
 Yaamon's gear list:Yaamon's gear list
Canon EOS 5D Mark II Nikon D90 Sony SLT-A35 Nikon D800 Canon EOS 5D Mark III
DamionR
New MemberPosts: 20
Don,
I had to do pretty much the same thing you did with my D800.
Nikon 14-24mm f2.8 needed to be set to -20.
Sigma 50-500mm OS needed to be set to -20 also.
This is kind of worrisome that they needed so much adjustment. It begs the question, what if we could adjust beyond -20?
Is something wrong with our D800s that they need so much adjustment in AF-tune?
Tom Matty
Contributing MemberPosts: 826Gear list
I found the same for my D800, much greater adjustments required than for my D700. I ended up setting the body at default -10 and only then could I get all my lenses aligned.
 Tom Matty's gear list:Tom Matty's gear list
Nikon D800 Sigma 50mm F1.4 EX DG HSM Sigma 35mm F1.4 DG HSM | A
lefty from Saratoga
Contributing MemberPosts: 613
In reply to Tom Matty, Apr 8, 2012
How are you checking your focus wide open? Are you using the Lens Align tool or?
Saratoga Lefty
http://www.bernieweinzimmerphotography.com
cafenated
Forum MemberPosts: 78
In reply to DvD5, Apr 8, 2012
Weird.
On the d800 I have 0 need to fine tune the sigma 50 1.4 nor the 85 1.4--the 50 which needed -7 on the d7000 with the same pixel pitch while the 85 needed none.
DvD5
DvD5 OP
In reply to DamionR, Apr 8, 2012
DamionR wrote:
Don,
Good question--as long as I can get everything tuned I'm okay with it. The concern is if I get a new lens that needs -25!
Don
DvD5
DvD5 OP
In reply to lefty from Saratoga, Apr 8, 2012
I don't use Lens Align. You can do something as easy as setting up a business card with contrasty print on a measuring tape. Make sure the card is parallel to the sensor and the measuring tape runs perpendicular to the sensor (or at a slight angle). Focus on the business card (using a tripod and good light). Examine the image at 100%; if the focus point is in front of the business card, you need +correction. If the focus point is in back of the card, you need -correction.
Don
The Photo Ninja
Senior MemberPosts: 2,066
This just doesn't seem right to me.
I've got a D700,
My lenses are 24, 35, 85 1.4 variety, 14-24, 70-200 2nd edition and all are set to 0 for AF fine tune.
Maybe I'm doing something wrong.
shzygjrmdwg
Junior MemberPosts: 32
Re: This just doesn't seem right to me.
In reply to The Photo Ninja, Apr 8, 2012
I just realized that my lens are bit off focus today as well, the samyang 35mm f/1.4 (which is manual focus) is at -10, 24-70 seems also be good at -10 but it's only been tested indoors, will do some more testing in better light. The 85 f/1.4D seems to be OK at.
It is kind of annoying as I often forget to fine tune after changing lens
Leonard Shepherd
Forum ProPosts: 10,048Gear list
Or maybe the others are photographic dopes
People claiming lenses have front or back focus hardly ever show it with a sample image.
Their camera instruction books tell them fine tune is not normally needed, some types of AF target can induce wrong focus and for good measure Nikon repeat much of this at
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/4585
Despite all this many who do "no hope of a reliable result" tests blame the equipment instead of themselves.
Having examined over 720 images posted over a number of years I have seen only 2 using AF targets which Nikon consider as reliable for consistent accurate focus.
What the actual equipment failure rate is is unknown, but based on examples posted at dpreview it seems below 1% - with the other 99% being mainly a failure to test in a way likely to produce an accurate measure of AF accuracy.
Leonard Shepherd
Photography could be easier - if cameras and lenses came with an increase in skill button.
Nikon D800 Nikon D7100 Nikon D810 Nikon D750 Nikon D7200 +22 more
lightmagic
Senior MemberPosts: 1,410
In reply to Leonard Shepherd, Apr 8, 2012
i use just pro lenses. The newest, 2 months old for me is the 400/2.8 VR. It works with every camera. I never ever feel the need to fine tune any lens.
The Lightmagician
Sun is my eye
Winds my breaths
Sky my open Mind.
MTFBWY
http://www.lightmagical.com
DvD5
DvD5 OP
I've got a D700,
Not at all. Most body/lens combinations don't require any fine tune. My experience with my D700 was that all my lenses other than the 500VR were fine with 0 fine tune.
Very different experience with my D800.
Don
inasir1971
Senior MemberPosts: 3,413Gear list
Nikon needs to do something to expand the adjustment range
Since a lot of people are having to fine to the maximum limit, the lens might actually need adjustment beyond that.
Nikon, until they figure out what is going on and if there is a problem, should at least put out a temporary fix urgently in the form of a firmware update possibly to expand the fine-tuning range for the D800 (/ D4?).
And Happy Easter everyone
 inasir1971's gear list:inasir1971's gear list
Nikon D4 Nikon D810 Nikon D750
DvD5
DvD5 OP
Why do you think Nikon & Canon (& Oly) put the feature in the cameras? It is because so many people had problems with front/back focus. The methodology I use for setting AF fine tune works very well for my purposes and is highly repeatable. It makes a big difference in two scenarios especially: 1) 500 VR with or without TC's. 2) Shooting wide open (e.g. f/1.4) where DOF is razor thin.
As I pointed out, if you are shooting at small apertures or printing small, you likely won't need to fine tune AF for your lenses.
Don
ssmumich00
Regular MemberPosts: 415Gear list
My D700 has required ZERO AF tuning for 24-70, 70-200, 85 1.4, 24 1.4, and 50 1.4....
I've got a D700,
Don
 ssmumich00's gear list:ssmumich00's gear list
Nikon D7000 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 20mm f/2.8D +3 more
Photo Exporter
Regular MemberPosts: 188
My experience is similar with D3/D700, D7000
My D3/D700 needed very little adjustment with all of my lenses (Sigmas, Nikkors). But both my D7000's need significant (and nearly identical) adjustments.
For example my Nikkor 14-24 on my D3/D700 was -2 on both. But on both D7000's it is -20 -- Wow, right! When I first shot with the 14-24 without adjustment I though I had a $100 junk lens. After AF finetune, you could (ahem) cut glass with the sharpness.
I have noticed every lens I have requires a negative AF finetune on both D7000's, and every one of them is within 1 point between the bodies. So it seems that both bodies are identical (or close). It has alos been noted by many that the D7000 tends to back focus., Almost seems like a design or manufacture issue. But since I have been able to get every lens perfect within the +20/-20 range I have not felt it necessary to send them in to Nikon.
BTW when I get new gear I spend hours calibrating, using: test charts, brick walls and REAL photos. It stinks to blow all that time. But if you are going to spends tens of thousands of dollars and then not tune... well, a Ferrari needs tuning before she goes out to race
Resul83
Regular MemberPosts: 140Gear list
Best way?
What is the best way to do AF tuning?
Saw something called focus pyramid for $20... Anyone have experience with that?
 Resul83's gear list:Resul83's gear list
Nikon D800E Nikon AF-S Nikkor 24mm f/1.4G ED
