AF Issue + Free test pattern
Started Apr 7, 2012 | Discussions
D800Fanboy
New MemberPosts: 10
Apr 7, 2012
I created a High Quality test pattern i am will to share it with anyone who wants it. I just need someone to show me how to upload the pdf file.
I did some tests with a 50mm lens at f1.4 for the AF issue. Can someone please look at them and tell me if they are ok. I did the test with the D800 and D300. Please look at my pics and give advice i still have 3 weeks to replace it if i need to. I may have shot the D800 slightly out of focus.
Nikon D300 Nikon D800
gonzalu
Forum ProPosts: 10,313Gear list
D300 still looks to be the same
In reply to D800Fanboy, Apr 7, 2012
difference in sharpness from left to center
MAKE SURE your image is aligned with the sensor... it must be perfect or else you risk an improper test.
Measure with a precise measuring tape, preferably a soft type, not a metal one, from the edges of the lens bayonet to the edges of your test pattern/wall... this will give you a reasonable degree of accuracy...
I would do it on a tripod and face the camera at the floor. Put your target on the floor and check the level of the floor then using a spirit level also check the level of the lcd screen on the back of the camera as it faces the target to get a reasonable degree of accurate alignment.
Manny
http://www.pbase.com/gonzalu/
http://www.thrustimages.com/
FCAS Member - http://fcasmembers.com/
 gonzalu's gear list:gonzalu's gear list
Nikon D3 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +4 more
Marcin 3M
Senior MemberPosts: 1,197Gear list
This test is not ...
showing the possibility of AF troubles (if I understand what's the nature of the problem).
You should shot Your test chart using different AF points and then compare results.
Regards.
Marcin_3M
 Marcin 3M's gear list:Marcin 3M's gear list
Epson Stylus Pro 3880 Adobe Photoshop CS6 Nik Capture NX Phase One Capture One Pro Portrait Professional Studio 64 +1 more
D800Fanboy
New MemberPosts: 10
Re: This test is not ...
In reply to Marcin 3M, Apr 7, 2012
Thanks guys, What i did was setup my tripod with the camera. Made sure the camera lens was level with the target and height was at center of target. Focused on the center of target. I also moved the camera in to fill the test pattern. I tried different AF points and they look fine but the 1.4 seemed to me just a little soft on the left
samjstern
Veteran MemberPosts: 6,373Gear list
Hey D800Fanboy, ...
did you try to calibrate the 50mm lens to the D800 and then shoot the test pattern??
 samjstern's gear list:samjstern's gear list
Nikon D70s Nikon D600 Nikon D610 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +8 more
D800Fanboy
New MemberPosts: 10
Re: Hey D800Fanboy, ...
In reply to samjstern, Apr 7, 2012
No i did not, i'm learning a lot already. Looks like i'm gonna have to redo the test.
Is their a tutorial some were i can goto to learn how to calibrate the lens.
Marcin 3M
You have to note, that lens may have some alignment imperfections, and may perform different on the left and right side. But this can be proven with a single shot of a subject paralel to the sensor's plane. Unfrtunatelly, it's quite oftenly observed flaw.
But we are talking about specific af system flaw. Isolating the problem may be really dificult if the lens is not perfect. Therefore try to use different lenses.
Marcin_3M
GMack
Senior MemberPosts: 2,928
Re: AF Issue + Free test pattern
How about making one and trying to align the right and left high contrast targets with the one in the camera? Idea would be to move the internal focus point to either the right of left without moving the camera to see if their is a Right to Left focus error that may be an issue if you follow the D800 focus error thread.
Nikon seems to like the focus target below as it is the one in their lens repair manual.
Aside, is there a reason why the black circular pie target in the center isn't fully black but rather spotted? The photo maybe vs. the PDF?
Mack
Event_shooter
Contributing MemberPosts: 975
Here's a good chart for download
In reply to GMack, Apr 7, 2012
Leonard Shepherd
Veteran MemberPosts: 7,946Gear list
It can be a good target - but I expect Nikon have very specific guidance for viewfinder alignment.
Without very specific viewfinder alignment and focus distance relevant to focal length the camera AF could assume the center of the target is not where Nikon intend, leading to a possible front or back focus indication the lens does not have.
Leonard Shepherd
Photography could be easier - if cameras and lenses came with an increase in skill button.
Nikon D800 Nikon D7100 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 16-35mm f/4G ED VR +18 more
Leonard Shepherd
The target is capable of providing a lot of information - with a however
The however is the AF target at the centre does not seem to meet Nikon's standard for consistent reliable AF in camera instruction books or at
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/4585
While AF often works very well with less than ideal targets sometimes a poor target can result in poor focus - indicating a fault with the target rather than the lens being tested
Leonard Shepherd
Leonard Shepherd
Re: Here's a good chart for download
In reply to Event_shooter, Apr 7, 2012
What convinces you it is a good target for testing AF?
It does not meet Nikon's guidance for consistent reliable AF in your camera instruction book or at
While AF often works well with less than an ideal target sometimes a less than ideal target indicates a "focus error" which is a fault with the target rather than the lens.
Leonard Shepherd
DvD5
Contributing MemberPosts: 831
You need to make sure your sensor is perfectly parallel to (and centered on) the target. You can do this a number of ways including measuring distance from floor for height, then measuring diagonals for right/left alignment. You can also have someone hold a mirror perfectly flat on the target and make sure you see the image of your lens perfectly in the center of your viewfinder.
I've noticed that I need to dial in negative focus adjustment for nearly all my lenses, so that may be part of the issue. Edges of the chart won't look all that great at f/1.4, but they should be similar sharpness to each other.
Don
http://www.dvd5.zenfolio.com
Leonard Shepherd
In reply to DvD5, Apr 7, 2012
If you are using a reliable AF target the likely problem is your camera body is out of AF alignment.
If you are not using a reliable target and always start focus from either in front or behind the target it could be your camera and lenses are OK.
Leonard Shepherd
SteveL54
Senior MemberPosts: 2,589
In reply to Leonard Shepherd, Apr 7, 2012
It is a good target.
The service manual does have a procedure to ensure the mirrors are properly aligned and flat. But this is not relevant to the suitablility of any chart or pattern as an appropriate AF target
There is no sensitivity to the "center of the target". The entire target is parallel to the sensor, so the test is not sensitive to aim as you seem to think.
Last year Marianne and I (plus others) tried to explain to you how PDAF works.
http://forums.dpreview.com/forums/read.asp?forum=1030&message=37475367
If a camera/lens combination miss focuses when that target is mounted reasonably parallel to the camera either the camera or the lens (maybe both) need adjustment. It won't cause a false positive as you imply.
Steve
Leonard Shepherd
TOF guy
TOF guy MOD
Forum ProPosts: 10,400Gear list
In reply to Leonard Shepherd, Apr 8, 2012
That is not true. The target is perfectly adequate and meets Nikon's standard
Can't be the explanation.
Thierry
 TOF guy's gear list:TOF guy's gear list
Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +3 more
lanef
Forum ProPosts: 10,317
Re: D800Fanboy
In reply to D800Fanboy, Apr 8, 2012
Hi D800Fanboy, thanks for sharing, I would like to give your chart a try, would you mind email me a PDF? Thanks
Flashlight
Veteran MemberPosts: 5,217
Some points on AF testing
On the local forum someone had a D7000 with focus issues, brought it to Nikon that simply made a +10 adjustment for his 50mm lens. He still had issues. The guy asked for help and I spent some time helping him out. He made the shots on my instructions, uploaded the NEFs and I did the processing. Something interesting was shown:
First I had him make a 45 degree triangle cardboard test target with letters on the front, put it on a piece of paper with lines and set the camera @ 45 degrees. The letters were a bit larger than I intended so he focused on the edge of the round part of the '5'. Also, the camera was slightly off-axis. Focus distance is 2 meters, all test shots taken with AF-S:
I ran the shots through a Photoshop action, involving 'Find Edges' and contrast manipulation. This is a shot with Live View Contrast AF:
First off the lens seemed misaligned, although part of this could have come from the camera placement. The purple line indicates the focal plane as seen on the full sized image:
Then I had him make series of 5 shots each. The first series is where he moved the plane of focus closest to the camera before each shot, then focus once and take the shot (leftmost is control shot with Contrast AF):
Then I had him turn the focal plane closest to the camera before each shot like in the first test, but now half-press the shutter button 5 times so the focus had time to 'settle' and take the shot (leftmost is control shot with Contrast AF):
As you can see when you compare the first and second series, repeatedly half-pressing the shutter button and focusing before each shot makes the D7000 focus much more consistently. It was also proved that the +10 AF Fine Tune setting made by Nikon was not optimal and should probably be +5 or 0.
I would also not use the AF-C + AF-ON focus method with this camera, as repeatedly focusing on the same target has no effect when using AF-C.
Philip
Photo Pete
Senior MemberPosts: 1,372
Re: Some points on AF testing
In reply to Flashlight, Apr 8, 2012
And how was the focus accuracy at 50m distance and f4? I'll bet a different fine tune setting would be required!
Have Fun
Photo Pete
Flashlight
In reply to Photo Pete, Apr 8, 2012
That usually happens with miscalibrated lenses. As far as the experiment above goes, I was already happy to convince the tester not using the closest possible focus distance but a 'whopping' 2 meters. Personally I always test lenses at several focus distances.
Philip
