My friends D800 Exploded
Started Apr 6, 2012 | Discussions
Mssimo
Senior MemberPosts: 1,040Gear list
Apr 6, 2012
Someone please fill my in on what happened. We did not notice any noise just a dark spot on the view finder and check out the damage. This camera was S/N30004XX (xx is the final two numbers)
Mássimo
 Mssimo's gear list:Mssimo's gear list
Nikon D810 Carl Zeiss Distagon T* 2/25 Carl Zeiss Distagon T* 2,8/15 Nikon AF-S Nikkor 85mm f/1.8G Sigma 50mm F1.4 DG HSM | A +4 more
Nikon D800
ssmumich00
Regular MemberPosts: 415Gear list
Re: My friends D800 Exploded
In reply to Mssimo, Apr 7, 2012
Did it come like this? A few users have reported these random spots in their D800's already.
Or did it literally explode when your were shooting?
That's Sony sensors for you!
(w): http://www.neilphotos.com
(p): http://www.suneil.net
 ssmumich00's gear list:ssmumich00's gear list
Nikon D7000 Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 85mm f/1.4D +3 more
Mssimo
Mssimo OP
In reply to ssmumich00, Apr 7, 2012
No, I think we got around 1500 clicks on it. I noticed the dark spot on the view finder. It still works and pictures still look good. Not sure what failed on it. I mailed it back to nikon. They told me 7-10 days.
Mássimo
reginalddwight
Senior MemberPosts: 2,003Gear list
Early adoption woes. Warranty should cover this, no?
Robin Casady
Forum ProPosts: 12,898
Stress fracture?
Looks like a stress fracture in the viewfinder screen. Could have been some foreign object wedged between the frame and the screen. Not sure what the shiny spill is next to the screen.
Robin Casady
http://www.robincasady.com/Photo/index.html
Mssimo
Mssimo OP
Re: Stress fracture?
In reply to Robin Casady, Apr 7, 2012
I think that is melted plastic. Seems like the focus screen and mirror also melted.
Mássimo
BJN
BJN
Veteran MemberPosts: 5,041Gear list
A short burning some of the metal coating?
Looks to me like the pitted metal and missing black coating got vaporized and that's the dark comet shadow on the focusing screen.
BJ Nicholls
SLC, UT
 BJN's gear list:BJN's gear list
Panasonic Lumix DMC-GM5
ukat123
Contributing MemberPosts: 761
Wow. You need to ask a new one.
I fear there will be quality issues for early adopters as Nikon was not ready to launch this camera and the high number of orders is going to put stress on their production lines.
ukat123
Mssimo
Mssimo OP
Re: A short burning some of the metal coating?
In reply to BJN, Apr 7, 2012
Looks like plastic to me. How do you think it would get vaporized?
Mássimo
Marianne Oelund
Veteran MemberPosts: 5,155Gear list
Component Infant Mortality
Manufacturers attempt to screen out components with hidden defects before shipping product, but inevitably, a few manage to get out the door.
This could have been a capacitor, such as a bypass capacitor connected across the power supply, or perhaps an active component, which failed dramatically. Sometimes assembly errors such as installing a polarized capacitor with the wrong orientation, or an incorrect part type, will not cause immediate failures but then will produce a failure later in the field.
Looks like it came from a small board in the viewfinder area and partially impacted against the upper surface of the viewfinder screen as it moved downward at high speed.
It's a good example of the reasons why we want warranties on new gear.
chris maytag
Regular MemberPosts: 264
In reply to reginalddwight, Apr 7, 2012
I had one of the early D200's with the infamous "banding". It's a risk we take. Nikon will surely cover it, as they did back then.
Still a hassle.
John Brewton
Contributing MemberPosts: 724Gear list
DvD5
Contributing MemberPosts: 831
Was your friend taking photos with the sun on the edge of the frame? I seem to remember a photo of a D200 that looked like this after sitting on a tripod for a few minutes with the sun shining in the lens. Or, could be a component failure as others suggested.
Don
http://www.dvd5.zenfolio.com
Marianne Oelund
You can look above the viewscreen
At the center of the front (towards the lens) edge of the viewscreen, is a metal tab that you can pull forward to release the viewscreen, then you can see what's above it. Might be interesting.
reginalddwight
Re: Component Infant Mortality
In reply to Marianne Oelund, Apr 7, 2012
Interesting theory, Marianne. You could be onto something.
Horshack
Veteran MemberPosts: 5,728
If that's the case there should be something rattling inside the body, unless it got wedged somewhere.
Stevequad
Senior MemberPosts: 1,447Gear list
In reply to Horshack, Apr 7, 2012
Which lens was in use? Did it the mirror contact the back of the lens? Look there also, unless the damage is on the hinged side of the mirror.
Non Ai lens?
Have Fun!
Steve
 Stevequad's gear list:Stevequad's gear list
Nikon Coolpix S51c Canon PowerShot G10 Nikon D3S Nikon D300 Nikon D100 +23 more
Mssimo
Mssimo OP
At the time I believe it was the 85mm f1.4D
In reply to Stevequad, Apr 7, 2012
At the time I believe it was the 85mm f1.4D.
Only other lenses he has is the 14-24mm and 50mm f1.8g
Mássimo
10-75
Forum MemberPosts: 64Gear list
Was your friend shooting into the sun or was the camera inadvertently aimed into the sun?
