X3FJpegXtract for mac
Started Apr 6, 2012 | Discussions
Ignatz Junior Member • Posts: 29
Does anyone have the application X3FJpegXtract for mac. The links I found don't work.
Thank you.
whisky Senior Member • Posts: 1,330
Re: X3FJpegXtract for mac
Try this plugin 'X3F Utilities' from,
corpus-callosum.com
Cheers.
 whisky's gear list:whisky's gear list
Sigma SD15 Fujifilm FinePix 6900 Zoom Olympus OM-D E-M5 Sigma 10-20mm F4-5.6 EX DC HSM Sigma 70-300mm F4-5.6 APO DG Macro +5 more
Ignatz OP Junior Member • Posts: 29
Thanks, but I think this won't work on my computer. I have 10.4 on a G4.
rick decker MOD Forum Pro • Posts: 13,514
Won't the SPP Convert-to-jpeg function give you what you want?
http://www.lightreflection.com
http://www.silveroaksranch.com
http://www.pbase.com/rickdecker
Yes, it will. But for various reasons I mostly use SPP 3.3 which does not have the convert-to-jpeg function.
Can't be certain but I first used it on my iMac G5 running OSX 10.3 Panther. It is still OK now on OSX 10.5 so if your machine is on OSX 10.4 it should run OK.
Cheers.
I thought Corpus Callosum's X3F Utilities worked with QuickLook which was introduced in 10.5.
Roland Karlsson Forum Pro • Posts: 24,304
Re: You can use my tool
See below --- it works on OSX
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax K-1 +12 more
ArvoJ Senior Member • Posts: 1,277
I found something: http://homepage3.nifty.com/haruya/tools/X3FJpegXtract.zip
If this works, let me know - I'll host it separately.
Arvo
Sigma/Foveon information collection and little gallery:
http://www.stv.ee/~donq/sigma.htm
http://www.stv.ee/~donq/images.htm
 ArvoJ's gear list:ArvoJ's gear list
Sigma SD14 Sigma 10-20mm F4-5.6 EX DC HSM Sigma 105mm F2.8 EX DG Macro +1 more
Thanks Roland. Would you tell me step by step how to use your extract tool.
Arvo, this looked promising but it's for intel macs only. Mine is a PPC. Thank you.
Sure!
You download the executables from the http://www.proxel.se/x3f.html page.
Then you unpack it with
tar xvfz x3f-041.tgz
In the unpacked directory, you will find the executable x3f/osx/x3f_extract. Put that executable where you can use it, i.e. somewhere according to your PATH variable.
Then you extract JPEG files with
x3f_extract -jpg foo.x3f
I put it in usr/local/bin but got a command not found message. As you can tell I know nothing about the terminal and command lines. Awhile ago I had put cdparanoia in the same place and it worked. Any suggestions? Thanks
This may be a long and painful conversation ... or not
If it cannot be found, even though it sin the usr/local/bin dir .... then it can be one of many problems.
  1. This directory is not in your PATH. You can test that by typing "echo $PATH" . Its quite common t NOT have this dir in your path.
  2. The program is not executable. You can test that by typing "ls -l usr/local/bin/x3f_extract" . If it isnt executable you make it so by typing "chmod +x usr/local/bin/x3f_extract"
  3. Many other things ...
echo $PATH gave me this bin: sbin: usr/bin: usr/sbin/ so I put it in usr/sbin and got this:
Link (dyld) error:
Symbol not found: stack_chk_guard
Referenced from: usr/sbin/x3f_extract
Expected in:
usr/lib/libSystem.B.dylib
tam ille Junior Member • Posts: 47
Hi,
if you're interested, I have a perl script which actually extract the thumbnail. It should be easy to modify it to extract the preview instead.
Another nice feature of the script is it can adjust the orientation of the image by modifying the x3f header (orientation field).
It's actually not online, but if you want to give it a try... I'll host it somewhere.
Link (dyld) error:
Expected in:
Ehhhhhhhhhh .. what?
It might be this:
http://wiki.osdev.org/GCC_Stack_Smashing_Protector
or this one:
https://discussions.apple.com/thread/2625035?start=0&tstart=0
Do you have Microsoft Office installed on your Mac?
Thanks for the offer but I'd have no idea what to do with a perl script.
No, I don't have Microsoft Office installed. This is a new version of X3F; should I try the previous one? Thanks for all your help. Let me know if this gets bothersome.
brazile Contributing Member • Posts: 567
You'd run it, same as the executable Roland is offering. This will only work if you have perl installed, but it seems likely that you do; type "perl -version" at the command line and see if it responds with version information. If so, you should be able to run the perl script on your image files.
Robert
