OM-D EM-5 / black is black
Started Apr 4, 2012 | Discussions
Jokica
Regular MemberPosts: 496Gear list
Apr 4, 2012
I am very interested to get OM-D EM-5.
I have done some IQ comparison using images on this site.
OM-D EM-5 is very similar and comparable to best APS-C or even FF cameras (MHO), except in upper right corner of image. Black color looks washout and noisy.
On other parts of image, black is black (I love that song)
Is this lens issue, or Dynamic Range, or what?
I am not a pro, can someone please explain.
Sorry about my poor English.
Kind Regards
 Jokica's gear list:Jokica's gear list
Sony Alpha NEX-5N
Timur Born
Senior MemberPosts: 3,663
Re: OM-D EM-5 / black is black
In reply to Jokica, Apr 4, 2012
Likely some kind of (too strong) low-cut filter at work. You can find something similar with some other cameras,too, like the D800. The histograms also shows a big ugly spike for pure black on these.
Jokica
In reply to Timur Born, Apr 4, 2012
Thanks for the explanation.
I just add D800 into my comparison page and the color is even "blackier" than D5100.
The difference is even more obvious now. When I move the frame to i.e. left bottle, there is no big difference between competitors.
Sony Alpha NEX-5N
Timur Born
The EM5 does it, too, but mostly on lower ISO. Look at the box with the orange sewing thread and yellow wool behind that. Parts of these are cut off to black.
Timur Born
I meant mostly visible on lower ISO. Higher ISO addsnoise to these black areas, too.
Yohan Pamudji
Senior MemberPosts: 2,857
Exposure difference
Just looks like E-M5 exposure is higher than others, making the whole image brighter. It's not just the black background. The colorful balls in the foreground are brighter than on the other shots as well.
Jogger
Veteran MemberPosts: 8,320Gear list
depends on what "comparable" means i guess
4 stops of DR is pretty significant, methinks
Kind Regards
 Jogger's gear list:Jogger's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
szlevi
Contributing MemberPosts: 932Gear list
Another pseudo-scientific, useless-meaningless comparo (nt)
In reply to Jokica, Apr 5, 2012
 szlevi's gear list:szlevi's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm 1:1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Adobe Photoshop Lightroom 4 +7 more
szlevi
Re: depends on what "comparable" means i guess
In reply to Jogger, Apr 5, 2012
Jokica
Thanks, guys!
Sony Alpha NEX-5N
Timur Born
I just noticed that you compared a part with grey background (grey gradations printed on paper). Here is a better "black" comparison:
rare wolf
Contributing MemberPosts: 874
Re: Another pseudo-scientific, useless-meaningless comparo (nt)
In reply to szlevi, Apr 5, 2012
If the OM-D sensor response really captures less contrast at the corners as the OP queries, how useless is that? He's only asking others to confirm or deny this "apparent" evidence with real world experience. I'm just as interested ...
cheerios from the Avalon Peninsula, Newfoundland
http://www.michael.shaffer.net/albums.html
Timur Born
In reply to rare wolf, Apr 5, 2012
Sorry, I misunderstood that this was a question about contrast.
Two possible explanations:
1) DR on the mFT sensors is lower and noise-reduction on JPGs seems stronger.
2) WB on the mFT (EM5) is considerably warmer (more red). Reduce the red on the EM5 result and it will look closer (as in darker and more contrasty) to the other results, too.
Aleo Veuliah
Forum ProPosts: 14,455Gear list
Re: Exposure difference
In reply to Yohan Pamudji, Apr 5, 2012
True, I noticed that also, the exposure should be controlled on these testing, all cameras should use the same exposure, because these differences can lead into wrong interpretations
Simplicity is the ultimate sophistication.
God is the tangential point between zero and infinity.
Imagination is more important than knowledge.
God always take the simplest way.
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Nikon 1 V3 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +3 more
Jokica
Sorry, can not agree with that. Even if "E-M5 exposure is higher than others" and "The colorful balls in the foreground are brighter", it is in such small degree that makes it barely visible.
However, there is much more degree of clearly visible difference in dark-grey areas of the frame between peers.
IMHO, It can not go only to higher exposure.
Regards
Sony Alpha NEX-5N
