How come 40mm is such an irrelevant focal length?
Started Apr 3, 2012 | Discussions
Tom__Brown Senior Member • Posts: 1,344
I love the DA40L technically, but it's a useless lens. I'll just pull it out to test with, every time I get another camera body. lol!
I've heard others here lament the focal length. Why is it so useless? I've got quite a few some shots with a DA16-45 that were taken at 45mm. 45mm isn't so far from 40.
Strange then the 40L feels like such a fish out of water in DX format. I'm sure it would be one of my favorite focal lengths if I was shooting full frame.
-- Tom
 Tom__Brown's gear list:Tom__Brown's gear list
Pentax K100D Pentax K20D Pentax K-5 Pentax K-01 Pentax smc DA 14mm F2.8 ED (IF) +6 more
ozdean
ozdean Forum Pro • Posts: 22,944
Re: How come 40mm is such an irrelevant focal length?
I reckon its the perfect prime for what the K01 was designed for; a touch longer than normal.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
John Cal
John Cal Regular Member • Posts: 307
It's a great lens for many things. This is the lens that made me buy into Pentax coming from Canon and Nikon.
 John Cal's gear list:John Cal's gear list
Panasonic Lumix DMC-TS1 Pentax K10D Pentax K-7 Pentax Q Pentax K-01 +14 more
timo Veteran Member • Posts: 4,766
I have one, and it works well.
I would feel better about it if there were a modern 28mm. If you have a 40, then 35mm seems a bit redundant and vice versa. And yet the 21mm is too far away.
More and more I find myself packing the DA21, the M28/3.5 and the FA50/1.7. A bit ironic, having spent good money on the 40 and the cheapo DA35.
tim
http://www.pbase.com/timotheus
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 +1 more
Roland Karlsson Forum Pro • Posts: 24,304
The fish in the water barrel
This question reminds me of the fish in the water barrel riddle.
The riddle is something like this.
If you have a barrel full of water and put something in, e.g. a stone then some water from the barrel will spill over on the ground/floor.
The riddle is then - why does this not happen if you put a fish in the barrel?
Hard one - after some time some usually start to come up with explanations. Maybe the slime on the fish changes surface tension? Maybe the fish swallows the water? Maybe its magic?
But the answer is more simple than that. The riddle is false. There are no such effect.
And --- back to the 40 mm lens. You asked why it is not a good focal length. Yes?
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax K-1 +12 more
Ishpuini Veteran Member • Posts: 6,130
It comes down to personal preferences really.
I must agree that I never found 40mm an ideal focal length. But I never really liked 35mm on APS-C either. I always wanted slightly wider, hence the FA31 is better for me.
However, since I started increasingly shooting in the square format my preferences changed. Now I prefer the DA21/3.2 for a slightly wider standard, and my FA43 (close to 40mm) has become my mild tele of choice.
Wim
Belgium, GMT+1
 Ishpuini's gear list:Ishpuini's gear list
Pentax Q Pentax K-3 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +16 more
sterretje Contributing Member • Posts: 840
Tom_ Brown wrote:
... Why is it so useless?
Simply because it's not your focal length. And neither mine. And for others, it's a perfect focal length.
WimS
 sterretje's gear list:sterretje's gear list
Pentax K100D Pentax K10D Pentax K-5
OK - is it bad on both FF and APS-C?
In that case would 60 mm be bad on FF and 28 mm bad on APS-C. Is that so?
LWW Contributing Member • Posts: 509
Stop moaning, get over it, chuck it in the bin, sell it. If you are not up to getting the most from it - your problem
 LWW's gear list:LWW's gear list
Sigma dp2 Quattro Sigma dp1 Quattro Sigma dp3 Quattro Sigma dp0 Quattro Pentax *ist D +32 more
Hmmmm .. evidently I was not clear enough.
I have no problems with 40 mm lens - neither on FF nor on APS-C.
I was just asking the guy that had. If it was the focal length or the FOV he did not like.
snake_b Veteran Member • Posts: 4,680
The DA21 is nice, but too slow, really.
The X100 made it especially obvious that the DA21 is too slow, especially for the price that is being commanded for it.
Apologies Roland,
Did not intend to direct my reply to you, more the original post. I can not understand how the focal length really is of any consequence once you are the owner. Just move the feet a bit. My DA40, hardly ever is used for a single frame, but as a optic for a vertical (portrait) stitched panorama - superb. both for image quality and perspective.
Just a matter of fit to purpose.
13thBagel
13thBagel Senior Member • Posts: 1,108
Huh??
You can compare a complex part to a system and expect to make a categorical judgment that's credible...? Kinda like comparing a MINI headlight to a Volkwagen...? OK, they're German products, but what's your point?
Help me understand... M
 13thBagel's gear list:13thBagel's gear list
Pentax Q7 Pentax K-1 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax 08 Wide Zoom HD Pentax DA AF 1.4X AW Rear Converter
Re: Huh??
Ok. The DA21 is a slow lens.
Paphios Regular Member • Posts: 395
For years in film photography a MicroNikkor 55mm was my main prime lens rather than the usual 50. For me the 40mm focal length on APS-C seems pretty natural
Matthew Miller
Matthew Miller Senior Member • Posts: 1,306
Re: Huh??
The X100 has a 23mm f/2 lens.
Matthew Miller « http://mattdm.org/ »
 Matthew Miller's gear list:Matthew Miller's gear list
Pentax K-5 II Fujifilm X-T10 Pentax smc DA 40mm F2.8 Limited Pentax smc DA 70mm F2.4 AL Limited Fujifilm XF 23mm F1.4 R +5 more
Matthew Miller
I like it.
Exactly. For me, it's very convenient; it's within the range of
"normal", but slightly narrow, tending to make composition more focused. And that same extra length makes it a bit nicer for portraits than a wider normal would be. Altogether, this means that it stays on my camera most of the time.
mervis50 Regular Member • Posts: 214
Try it. You'll like it.
You're asking a question based on an opinion which is based on a fallacy. Yes, it's unusual compared to what we think is standard, but in and of itself, it's just another focal length. Just because it's not widely popular doesn't make it wrong or 'irrelevant.
It's really a marvelous piece of glass - a pleasant surprise. And only $150 as part of the K-01 kit. I'm finding it to be a very nice street lens. Brings you in a little closer when necessary; gives more focal separation between subject and background than a standard; mild foreshortening for portraits.
Don't diss this lens!
Cheers from Vancouver, Canada
Ari Aikomus
Ari Aikomus Veteran Member • Posts: 7,275
Yep, and 55mm Takumar...
I agree. 55-60mm is quite nice FF (fullframe) focal lenght range .
I use my old m42 Takumar 55/1.8 all the time with FF Canon 5D:
cheers,
Ari
  • Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
Photonom Regular Member • Posts: 133
Ari Question
Ari,
Do you have any problem with the mirror of the Canon 5d hitting the back of this lens or any other M42's you may have.
Thanks, Robert
  • Ari Aikomus -
 Photonom's gear list:Photonom's gear list
Pentax K110D Pentax K20D Pentax smc DA* 200mm F2.8 ED (IF) SDM
