LR or Capture One Pro for Nex5n Raw?
Started Apr 2, 2012 | Discussions
Arashi87 Junior Member • Posts: 40
I cannot decide between the two for pp raw from sony nex
Anyone got examples between the two and suggestions?
Sony Alpha NEX-5N
N13L5 Junior Member • Posts: 41
Re: LR or Capture One Pro for Nex5n Raw?
capture one can control the camera directly in a studio environment, giving you a much larger view of what you are going to capture, if that matters to you.
wictred Senior Member • Posts: 1,195
Tethering is not possible with Sony cameras
http://www.phaseone.com/Search/Article.aspx?articleid=2066&LanguageID=1
 wictred's gear list:wictred's gear list
Sony Alpha 7 II Sony FE 35mm F2.8 +3 more
Elandreth Regular Member • Posts: 196
I use C1 Pro with my 5N and love it.  Of course, I've never used LR, so I can't compare.  My assumption is that LR would have more built-in lens profiles, since C1 Pro only has the kit 18-55 and Sigma 30 built-in for the 5n.  This isn't a problem for me though because I just use the 18-55 kit and then a bunch of legacy glass.
The organizational structure in C1 is wonderful with its catalogue feature.  I also really enjoy the color controls, single-exposure HDR, clarity tool, adjustment layers, and perspective corrections.  It's easy to set up your own lens profiles for manual lenses, and to have batch adjustments saved for a large group of shots with the same setup.  I can't comment on LR, but C1 works for all my needs (primarily landscape work, but also some product shots, macro, and portraiture).
 Elandreth's gear list:Elandreth's gear list
Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS Leica Elmar-M 24mm f/3.8 ASPH Leica Summarit-M 75mm f/2.5 Carl Zeiss Distagon T* 4/18 ZM +27 more
