is there a book or a webpage to learn how shoot physical defects?
Started Apr 1, 2012 | Discussions
mantra
Contributing MemberPosts: 705
Apr 1, 2012
hi
i'm looking for a book or a web resource to learn how avoid or reduce physical/visage defects , like a light squinting, strabism ,or squinting or for example double chin , or a light crooked nose
in short how reduce the impact of face/visage defects during shooting
i would appreciate it alot
thanks in advance
cheers
macbob3
Regular MemberPosts: 470
Re: is there a book or a webpage to learn how shoot physical defects?
In reply to mantra, Apr 2, 2012
Author Jeff Smith has covered this fairly well in his book "Corrective Lighting and Posing Techniques for Portrait Photographers"
Pretty good book with lots of images and descriptions.
mantra
In reply to macbob3, Apr 2, 2012
thanks a lot!
very interesting!
on amazon i found different edition , is the Third Edition, Third edition the last?
thanks
cheers
RPC92026
Junior MemberPosts: 46
Here are some very quick tips...
These tips won't make you an expert but might help you out a bit...
FACIAL ISSUES - PORTRAIT CORRECTIONS
BLEMISHES OR SCARS
• Shadow problem areas
• reposition
CHIN , DOUBLE
• Raise the main light
• Tilt chin upward
• Use a high camera position
• Stretch neck
• Lean head toward camera
EARS , LARGE
• 3/4 pose
• Only show one ear
• Shadow second ear
EYES, BLINKING
• Time shot after subject blinks
EYES, DEEP SET
• Light into eyes
• Lower Main Light
• Lower light ratio
EYES, DIFFERENT SIZED
• Largest eye close to camera, other in shadow
• Largest eye away creates evening effect
EYES, EYE GLASS WEARERS
• Shoot with empty frames
• Position glasses away from lights
• Bring lights in from very high, or bounce off ceiling
• Use small light source
EYES, PROTRUDING
• Have subject look downward
FACE, BAD COMPLEXION – FEMALE
• Proper make up can cover some problems
• Diffuse image
FACE, BROAD, ROUND OR FAT
• Raise the camera position
• Use short lighting
• Turn the face at a 3/4 position
FACE, NARROW
• Lower the main light
• Use broad lighting.
FACE, THIN
• Pose model facing the camera
FACE, WRINKLED
• Use diffused frontal lighting
• Use a 3/4 pose.
FACE, DEFFECTS
• Scars/birthmarks keep hidden on the shadowed side of face
• reposition
FOREHEAD, PROMINENT
• Tilt chin upward
• Lower camera position.
HAIR, BALDNESS
• Blend the top of the head with the background.
HAIR, DARK
• Check to make sure that background doesn't merge with hair
• Restyle if necessary.
HEAVYSET FIGURE-
• Use short lighting, use low key lighting,
• Dark clothing
• Blend body with background tone.
JAW, SQUARE
• 3/4 pose, higher camera angle
NARROW CHIN
• Tilt chin upward.
NOSE, ANGULAR
• Minimize feature by turning the face directly toward the lens.
NOSE, BIG
• Raise chin slightly
• Pose nose straight into lens
NOSE, LONG
• Tilt chin upward, position face directly toward lens
• lower the main light
• lower camera position.
NOSE, SMALL
• Pose nose at an angle to camera
Best of luck - I hope some of these help!
Richard
mantra
Re: Here are some very quick tips...
In reply to RPC92026, Apr 3, 2012
wow
thanks a lot!
really
lots of very useful advises!
i will try to create a pdf of them
really i appreciate it a lot!
cheers
