D800 = 2xD7000 - I was dead right...
Started Mar 29, 2012 | Discussions
Grig
Grig Senior Member • Posts: 2,139
About a week ago - I posted this thread with no responses...
http://forums.dpreview.com/forums/read.asp?forum=1021&message=41027725
Now I can tell to all that may be interested as I was - I was dead right... It looks pretty much the same...
Shot with 50mm at F2, 1/200, ISO3200. D800 is in crop mode.
You can guess what where, but to me - they look the same...
Real photography - it's just the ability to see what was already created by God!
http://www.grigphoto.com
 Grig's gear list:Grig's gear list
Panasonic Lumix DMC-ZS3 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-LX100 Nikon D3S Nikon D800E +14 more
Nikon D800
Fearless_Photog Senior Member • Posts: 1,250
Re: D800 = 2xD7000 - I was dead right...
On my monitor the one on the right is very clearly less noisy in some areas, but is also exposed differently.
http://www.flickr.com/photos/mcullenphoto/
Marianne Oelund Veteran Member • Posts: 5,399
Nice job matching the focus
One of the most frustrating and difficult aspects of making comparison images like this, is achieving precisely the same focus in each image. Looks like you've done very well here.
hoof Senior Member • Posts: 1,780
Makes sense. Both sensors were made by sony. Take a D7000 sensor, multiply the area by 2.25x, and voila, D800 sensor.
So far, all the 1:1 images I've seen support the idea that the D800 is a tweaked D7000 sensor scaled up.
Now where you get the FX advantage is downsampling the two sensor's images to a common output resolution. There the D800 does better because you're binning more pixels per final pixel.
Glad to see all these new D800 owners finally enjoying what us D7000 owners have had for a while now
 hoof's gear list:hoof's gear list
Panasonic Lumix DMC-LX100 Nikon D750 Nikon D7100 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Tamron SP 150-600mm F/5-6.3 Di VC USD +19 more
Grig
Grig OP Senior Member • Posts: 2,139
D7k is on the right... It wasn't scientific test though since I was shooting handheld, but exposure settings are absolutely the same...
Grig
Re: Nice job matching the focus
Well, Thank you for kind words, but in my opinion - I still missed it a little...
Grig
Yep... And it's not a bad sensor by all means... although I like D3s sensor better for low light...
I had D7k from that BestBuy super early deal in 2010 before it's official release date... So I had enough time to enjoy it, but D800 is a totally different animal... D800 as it is a one amazing high resolution camera with D7k inside for extra 16mp reach in crop mode...
Yeah, I can see that the exposure settings are the same, the exposure isn't though. Just look at the shadow area on the top of the second set of photos, it's pretty apparent.
Frank C. Veteran Member • Posts: 6,644
the d800 is obviously the d7000 sensor upsized to FX size
Horshack Veteran Member • Posts: 5,803
That's why I sold my D7000 a while ago
That and the D7000's strong mirror vibration. I do miss the U1/U2 mode dial settings though
Lance B Forum Pro • Posts: 28,904
I have been saying the same thing as well.
I have been eagerly awaiting the D800 simply because of the fact that cropped, the D800 would be the equal or better than the D7000 that I have. This means that I can sell off my D700 and D7000 and have two cameras in one.
 Lance B's gear list:Lance B's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +16 more
Zlik Contributing Member • Posts: 990
Re: That's why I sold my D7000 a while ago
Is the mirror vibration better on the D800?
I haven't done a fully analogous test yet but initial results look promising: http://forums.dpreview.com/forums/read.asp?forum=1021&message=41036625
larrywilson
larrywilson Veteran Member • Posts: 4,718
Lance, this thread makes me feel a little better knowing that my d7000 has similiar resolution as the d800 when it is in dx mode. I have a d3s for my main camera and the d7000 for telephoto work in shooting birds mainly whenever the light is decent to where I can stay at 1600 or less iso.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 85mm f/1.8G Carl Zeiss Makro-Planar T* 2/100 Nikon AF-S Nikkor 500mm f/4G ED VR +7 more
PatrickP Contributing Member • Posts: 716
You folks are right. But that's disappointing. I was expecting [or may you say dreaming] the per pixel sharpness/noise similar to D700 in the same ISO. Guess such an improvement is not doable within 1.5 years.
Low light in-door shots that were achievable with a f/2.8 zoom on the D700 now seem to require the f/1.8G or f/1.4G primes for a similar per pixel noise level.
 PatrickP's gear list:PatrickP's gear list
Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 85mm f/1.8G +4 more
GlobalGuyUSA Senior Member • Posts: 1,683
ISO 3200?
I want to see ISO 12,800 and 25,600.
Then let's compare.
Not sure that FX is meant to be compared at the (these days regarded as) mid-ISOs.
Sincerely,
GlobalGuyUSA
 GlobalGuyUSA's gear list:GlobalGuyUSA's gear list
Nikon D810 Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Nikkor 135mm f/2D DC Nikon AF-S Nikkor 85mm f/1.4G +4 more
lock Veteran Member • Posts: 6,183
Indeed. And take iso 6400 with it.
You will see a difference. If you really keep the exposure the same.
That looks WAY better than the D7000, even if you consider the shorter focal length. Not the final scientific test yet, but looks promising. Thanks !
This is a huge issue with the D7000. In low light, I am often around 1/30 at f/1.8 (35mm ISO 3200) and sharpness will be improved with the D800 at similar parameters.
Are you planning more tests at longer lengths, Horshack ?
I'm less worried about this issue with wide angle lenses really. It's more the macro and tele end range that interests me.
Btw, although I only had it in my hands for one evening, I cannot really say the standard shutter-mirror of the D800 (so not the q-mode) is more silent than my d300. So, if there is a better dampened shutter-mirror, it's not transfered into sound.
So you do not mind the smaller viewfinder?
I thought you would prefer a real viewfinder.
