SD card a little difficult to remove on new K-5.
Started Mar 27, 2012 | Discussions
LDBOK
LDBOK Senior Member • Posts: 1,039
Just got my new K-5 as I was waiting for the price to drop. Great camera and a huge step up from the K20D. The only thing that concerns me so far is that I have to grab the SD card and pull on it to remove it from the slot after it has been released. On the K20D it was only necessary to lift it out of the slot without applying any force to remove it. I would appreciate any feedback on this. Thanks!
 LDBOK's gear list:LDBOK's gear list
Pentax MX-1 Pentax K-5 Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +11 more
Pentax K20D Pentax K-5
Col K10d
Col K10d Veteran Member • Posts: 3,214
Re: SD card a little difficult to remove on new K-5.
There's a knack and you'll soon get it... push the card in a little and pull your finger away fast enough so as to allow the spring to pop the card out about 5mm.
 Col K10d's gear list:Col K10d's gear list
Pentax K-3 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited Carl Zeiss Distagon T* 2,8/25 Voigtlander 90mm F3.5 APO-Lanthar SL II +9 more
ayewing
ayewing Contributing Member • Posts: 641
This is not a problem, it is a feature of the K-5.
When removing the card, push it in as far as it will go then release it rapidly by flicking your finger off it. The card should pop out far enough to be grasped easily. Once you get the knack it ceases to be a problem.
 ayewing's gear list:ayewing's gear list
Ricoh GXR Mount A12 Leica M Typ 240 Olympus E-M1 Leica Elmarit-M 28mm f/2.8 ASPH Leica Summilux-M 50mm f/1.4 ASPH +4 more
Ogun Caglayan Turkay
Ogun Caglayan Turkay Forum Member • Posts: 98
This is a normal situation on a brand new body and solve after using many times. If it's a big problem for you, you can watch and try this -> http://www.youtube.com/watch?feature=player_detailpage&v=pHo9osdbNw0
Greetings...
http://www.ogunturkay.com
 Ogun Caglayan Turkay's gear list:Ogun Caglayan Turkay's gear list
Pentax K-5 Pentax K-3 Sigma 70mm F2.8 EX DG Macro Sigma 50-500mm F4.5-6.3 DG OS HSM
Wanganuilad
Wanganuilad Senior Member • Posts: 2,210
small piece of selotape folded back on itself to make a pull tab 8mm long.
K-5 some Len
LDBOK
LDBOK OP Senior Member • Posts: 1,039
Thanks everyone for your quick response. If I push down on the edge of the card with my fingernail and then slip it off quickly, the card pops up higher and makes it easier to remove. Problem solved! I'm loving my new K-5!
Thanks again and cheers, Larry.
photee
photee Junior Member • Posts: 38
My k5 does the same thing. I had a kx and the card would pop out without any effort. I then got a k200d as a backup and the card did not popout. It was just like my k5. But since the k5 is soooooooooooooo fantastic, I can live with it! I have taken lots of photos so it will not get easier with more use. But I am now use to it. Enjoy your k5. I love mine!
LDBOK
Thanks photee! N. T.
No text.
viking79
viking79 Forum Pro • Posts: 14,135
I post this whenever someone asks that question. I made this after I bought my K-7:
Seriously though, it sounds you already found a trick. I don't like the flick trick myself and just grip it on the short edge and pull (same place where I have the pliers in the pic).
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
