D3s v X-Pro 1 comparison
Started Mar 25, 2012 | Discussions
MPA1
Veteran MemberPosts: 3,298Gear list
Mar 25, 2012
Here are two JPEG files.
Both OOC, AWB, f2, ISO 250. The Nikon is shot on a D3s set to Vivid and the Fuji on an X-Pro 1 set to Velvia.
The Nikon was using a 50mm f1.4 D and the Fuji a Fujinon 35mm f1.4
Both are available light only and within a few minutes of on another. They are not perfectly aligned - sorry - because my tripods are all set up to use only QR fittings and I do not yet have a QR plate for the XP1. I used a monopod braced against the front of the table, so apologies for the not quite exact match.
Both files are Large Fine and the file ending in 173 is the Fuji one.
Nikon D3S
jzzmusician
Regular MemberPosts: 237
Re: D3s v X-Pro 1 comparison
In reply to MPA1, Mar 25, 2012
Okay, I picked my favorite and looked to see what I picked.
I'm going to wait awhile before I say which one I liked.
Thank you for posting this.
MPA1
MPA1 OP
In reply to jzzmusician, Mar 25, 2012
I'll tell you what, they are seriously not that easy to tell apart, are they?!
CriticalI
Senior MemberPosts: 1,777
Darn close, at least at that size. I kind of prefer the Fuji shot because of the greater tonal range in the background.
DOF difference quite obvious too.
But yes - very very close.
Steve
theNeverKings
Regular MemberPosts: 173
Colour
Hi.
The colour looks far more pleasing and realistic in the Fuji example. Think "honey". I noticed the same difference between my D90 and x100.
Robert Holloway
Veteran MemberPosts: 3,859Gear list
In reply to MPA1, Mar 26, 2012
Hi there
I looked at both and was disappointed that I preferred the Nikon and then realized that I had assumed your order and actually had picked the Fuji
That said, they are both excellent and we are in the weeds on preference
Rob
 Robert Holloway's gear list:Robert Holloway's gear list
Sony a6000 Sony Alpha 7R II Sony E 55-210mm F4.5-6.3 OSS Rokinon 14mm f/2.8 IF ED MC Sony FE 35mm F2.8 +2 more
xchric
Junior MemberPosts: 33Gear list
What are you comparing?
 xchric's gear list:xchric's gear list
Leica M Typ 240 +1 more
MPA1
MPA1 OP
In reply to Robert Holloway, Mar 26, 2012
Quite obviously they are very different beasts and each camera has strengths and weaknesses in terms of the overall package.
But on IQ and price, I would say Fuji have pulled off a small miracle myself. There's around NZ$5,000 difference in the price of the two setups!
Robert Holloway wrote:
Hi there
Rob
oking23
Regular MemberPosts: 208Gear list
The colour appears to be better on the Fuji.
 oking23's gear list:oking23's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +10 more
rdub
Regular MemberPosts: 155Gear list
In reply to oking23, Mar 26, 2012
WoW I would love to see this same setup with ISO 2500 if you have time.
 rdub's gear list:rdub's gear list
Fujifilm X-Pro1 Nikon D810 +2 more
Mannypr
Veteran MemberPosts: 3,363Gear list
In reply to rdub, Mar 26, 2012
Fuji has always distinguished itself by excellents colors and all of their latest cameras have the fuji trait on them so it doesn't come as a surprise that the colors on the fuji seem with a richer tonal balance. That being said what this comparison talks about is the cameras JPG engines . Professional Cameras per se are design from the get go to give you very neutral results by default and that is exactly what we are seeing here in this comparison .
It would have been interesting to see what the cameras could do with raw files which is the real creme de la creme of cameras . Thanks alot for the trouble of doing this comparison.
 Mannypr's gear list:Mannypr's gear list
Canon PowerShot A640 Nikon D90 Nikon D7000 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G II Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +8 more
MPA1
MPA1 OP
In reply to Mannypr, Mar 26, 2012
I agree and as soon as I have a RAW converter for Apple, I'll do just that!
Ignoring that though it shows that the Fujinon lens is extremely good.
smatty
Senior MemberPosts: 1,923Gear list
Thank you for doing this test
I did a similar test with the Canon 5D MK II with both cameras in camera defaults JPEG. But I shot the Fuji at f/1.4 and the Canon at f/1.8 to compensate for the shallower DOF on the full frame.
Did you also happen to test them out against each other in that setting? And you could rest the cameras on the same spot on a table (maybe on top of a book if you need more height) to cut out the tripod fiddling.
Smatty
Homepage => http://www.PhotosdeLux.com
Recent Flickr Photos => http://www.flickr.com/photos/internationalphotos/
 smatty's gear list:smatty's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100S Fujifilm X100T Canon EOS 5D +18 more
Asylum Photo
Senior MemberPosts: 1,277Gear list
The thing I keep noticing is how aggressive the highlights are in the Fuji image.
Everything else, though, is amazingly close and/or competitive.
Very impressive coming from an APS-C sensor.
http://asylum-photo.com
 Asylum Photo's gear list:Asylum Photo's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R +2 more
MiTaka
Regular MemberPosts: 353
Fuji needs 1/250 and nikon 1/640 to expose equally the same scene.
Maybe fuji were a bit too optimist setting ISO?
This will also explain their "excellent" high ISO results. Olympus took the same route with om-d.
Dimitar Ivanov
ohmydentist
Senior MemberPosts: 1,913
In reply to MiTaka, Mar 26, 2012
I don't know what "route" you speak of, but if there's no IQ trade-off with that approach, does it matter?
Just Shoot !
hellocrowley
Senior MemberPosts: 1,254
In reply to ohmydentist, Mar 26, 2012
It is possible that Fuji sets their ISO lower than what is displayed.
So if you're using A mode at ISO6400, Fuji might actually set the sensor to ISO3200 and use a slower shutter speed. In a well-lit studio test, you wont notice this, you will just go "woah my camera kicks ass". In dim lighting, you will notice the shutter being too slow and just switch to 12800, and still go "woah clean 12800!!".
Notice I'm just explaining the possible theory and not asserting anything. More tests need to be carried out.
Just Shoot !
