5N and poor man's macro
Started Mar 24, 2012 | Discussions
Eduardo Lohmann Regular Member • Posts: 136
I think this is a nice example of what one can get with cheap extension tubes...
Maybe the focus area is not OK (shallow DOF!), but I am amazed at the details...
This is a macro of a 10 brazilian "reais" bill (R$10.00). For those who don't know here's the bill: http://www.bcb.gov.br/htms/mecir/seguranca/seg010.asp?idpai=REALSEGUR
taken with nikkor 50mm 1.8 (from the 80's I think) and an extension tube very much like this one http://www.ebay.com/itm/Macro-Extension-Tube-Ring-For-Nikon-D5000-D3100-D90-D300-D700-D7000-D5100-Camera-/350550904325?pt=LH_DefaultDomain_0&hash=item519e764e05#ht_3290wt_682
Of course this is not for the pros or "serious hobbyst", just for you who love to have a little fun with macros..
 Eduardo Lohmann's gear list:Eduardo Lohmann's gear list
Sony Alpha NEX-6 Sony DT 16-105mm F3.5-5.6 Sony DT 55-300mm F4.5-5.6 SAM Sony DT 35mm F1.8 SAM Sony E 16-50mm F3.5-5.6 PZ OSS +7 more
D Cox Forum Pro • Posts: 13,572
Re: 5N and poor man's macro
The out of focus parts are just because you are shooting the bill at an angle. Get the camera (the sensor) parallel to the bill and it will all be in focus.
Extension tubes are fine with an f/1.8 or f/2.8 lens. You might get less good results with an f/1.4.
Eduardo Lohmann OP Regular Member • Posts: 136
Thanks for the tip!!!
twald Contributing Member • Posts: 502
Another tip; get a camera cap and glue a 49mm filter thread to it. Then attach the 16mm to it by the filter threads, so that it is mounted to the camera in reverse. The kit zoom works too, but a wider lens will give you more magnification mounted in reverse.
You can also cut a hole into a lens cap and glue a filter glass over the hole; that way you can protect the back of the lens from dust
Here's what it can do;
DuncanDovovan
DuncanDovovan Senior Member • Posts: 1,277
What is the focus distance in this combination? How close is the ballpoint to the back of the SEL16F28?
golfpan Regular Member • Posts: 258
Can you give us a picture of the cap and glued filter? This sounds interesting, and the results are impressive, I'm just having trouble visualizing exactly what the modified part looks like.
 golfpan's gear list:golfpan's gear list
Sony Alpha NEX-6 Sony a6000 Sony E 16mm F2.8 Pancake Sony E 30mm F3.5 Macro Sony E 50mm F1.8 OSS +12 more
photoholiko Contributing Member • Posts: 988
There are also reverse adapters that lets you stack two lenses, one in reverse.
I also own a 52mm thread to Nikon mount adapter which lets you mount any brand lens in reverse directly to a Nikon camera.
 photoholiko's gear list:photoholiko's gear list
Canon EOS 400D Olympus PEN E-PL1 Canon EOS 70D Epson PhotoPC 850 Zoom Minolta DiMAGE 7 +25 more
This is a Sigma/Minolta mount lens on a Nikon DSLR mounted in reverse.
My cheap extensiontube allows me to reverse the lens too, but not stacking i believe...
Having trouble to visualize this, please post a pic (you have to cut a hole in the camera cap??)
Sorry for not being clearer. I have included some pictures to help explain what I did.
Here's an original NEX cap that fits on the camera body, along with one that I modified to construct an adapter. I used superglue to fasten the filter ring to the cap. Since the cap was just a shell, I filled the back with JB Weld and then drilled a hole to accommodate the NEX lens locking pin.
Here's a back view. Note the JB Weld.
To protect the back of the lens from dust, I cut a hole through a lens cap and glued a filter over it. Here's another picture showing the original alongside the finished product.
Mounted:
Here's the whole deal. Note that the rectangular opening at the back of the lens is not oriented to match the sensor; you could align these at the time of assembly. It shows no vignetting, though, so I'm not worried about it.
The plane of focus is about an inch from the end of the lens (about 3/4" from the cap shown here) . Theoretically, you could move it farther away by bringing the lens closer to the sensor, but that would decrease your image magnification. I have not experimented with back or front focusing the lens before using it, but it should make at lest some difference. The diffraction characteristics seem to hold in reverse too, so diffraction will start degrading the image at smaller than f10. You want a small aperture because the DOF gets too small at close focus distances.
Penny.
I think the 16mm is especially well suited for this, for several reasons. The lens has excellent center sharpness and it seems that the center is all that is being used when mounted this way. Also, as a wide lens, it provides a good deal of magnification and its compact size helps to keep the system small.
Anyone try this with the UWA converter?
Here's another penny picture with the 16mm. I tried to match the color to the original. There may be some motion blur on these ...
Great!!!
I would never have the skill to do something like this! Congratulations. Great results.
.. and now....please make another pair and tell how much would you want
jazzroy1972 Regular Member • Posts: 172
Maybe all of you ignore the NEX mounte reverse adapter, which does exactly the same thing, costs 10 bucks, and is on ebay since one year ago..
http://www.ebay.com/itm/49mm-reverse-macro-adapter-for-SONY-NEX-5-NEX-3-NEX-5-3-/140454192515?pt=LH_DefaultDomain_0&hash=item20b3b8e583
I used it for some fun tests, and it works pretty well, but.. focus range gets really short, like a couple of millimiters.
There you go, Eduardo Lohmann !
jazzroy1972 wrote:
... NEX mounte reverse adapter ... costs 10 bucks, and is on ebay since one year ago..
txabi
txabi Regular Member • Posts: 435
OK, I'll bite. I just got myself some extension tubes and will soon try them on my 5N. 10 bucks for some macro work, no brainer. Can't wait to try it!
 txabi's gear list:txabi's gear list
Sony Alpha NEX-5N Sigma 30mm F2.8 DN | A +1 more
Charlie Lab
Charlie Lab Regular Member • Posts: 383
I picked up an old but pristine Vivitar 2x macro tele-converter for my Minolta lenses and tried it out for the first time this weekend. It's a pretty interesting piece of kit, acting as a 2x tele-converter, but also has a sliding macro (acts like an integrated macro tube) that allows you to focus from infinity to 1:1 macro. The picture below was taken with my 58mm f1.4 Minolta Rokkor with macro tele adapter attached (making it 116mm on APS-C, or 174mm full frame equivalent, but in macro mode).
Here is a very small sea anemone, a little less than 1" across... it's underwater in a tidal pool, so not ideal shooting conditions... it's also not very high res, as it's saved as a small jpeg since my gallery is full those are grains of sand on top of the anemone, to give you some idea of scale.
I'm new to macro photography, but I can see the appeal already. the one-piece adapter will make it a lot easier to keep my macro kit with me, I imagine.
 Charlie Lab's gear list:Charlie Lab's gear list
Sony Alpha 7R II
Charlie Lab
One more, less close-up, but taken through air instead of water...
Sony Alpha 7R II
Elite83 Contributing Member • Posts: 891
What lens/combination did you use? Reversed 16mm?
 Elite83's gear list:Elite83's gear list
Sony Alpha NEX-5 Sony Alpha NEX-6 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 35mm F1.8 OSS +3 more
DuncanDovovan
Did somebody try to reverse mount the SEL50F18 either to the kit zoom SEL1855 or to the SEL18200?
Does it pair nicely for Macro?
Working distance?
How is the vignetting at several focal lengths on the zoom?
Background: http://thehowzone.com/how/Micro-Photos/3
