Wow, 15-85 sharper than 24-105 4L?
Started Mar 21, 2012 | Discussions
Shift7
Junior MemberPosts: 29Gear list
Mar 21, 2012
Hello, made comparison shots. Camera 50D. 15-85 shot as is, 24-105 was even micro af via cable and pc via lifeview on pc screen. i always raved by my 15-85, but wouldnt believed that it will beat 24-105 even at f5,6. shots were taken from tripod, and 70 mm focal length and f5,6.
Comparison shots:
http://www.photobucket.lt/image.php?id=AE27_4F6A5626
 Shift7's gear list:Shift7's gear list
Canon EOS-1Ds Mark III
Canon EOS 50D Panasonic Lumix DMC-F5
007peter
Forum ProPosts: 10,132Gear list
I find EF-S lens are "generally" sharper than EF (FF) on APS-C body
In reply to Shift7, Mar 21, 2012
You photo show off well my own experience. When I compare:
  • EF-S Canon 17-55 f/2.8 vs EF 24-70 f/2.8
  • EF-S Canon 60mm f/2.8 vs EF 100 f/2.8 Macro
I reach the same conclusion. The EF-S is ever so slightly sharper. Not Big, but just enough extra sharpness
Comparison shots:
 007peter's gear list:007peter's gear list
Canon EOS M Panasonic Lumix DMC-GF6 Canon EF-M 22mm f/2 STM Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Panasonic Lumix G 25mm F1.7 ASPH
meatatarian
Junior MemberPosts: 30Gear list
Re: I find EF-S lens are "generally" sharper than EF (FF) on APS-C body
In reply to 007peter, Mar 21, 2012
One thing you need to keep in mind is that EF lenses are designed for full-frame cameras, whereas EF-s lenses are designed for crop sensors. EF-s sensors have SIGNIFICANTLY higher pixel density than any Canon full frame camera. Lenses resolve to a certain sharpness, and that sharpness requirement is significantly higher for EF-s sensors. The pixel size on a 5dII is 6.4µm vs. 4.3µm on the modern Canon crop sensors. Less resolving power is therefore needed for the EF lenses.
When you look a 100% crop on a crop sensor camera with 1 EF and 1 EF-S lens, you're comparing apples and oranges. Some EF lenses work brilliantly on EF-S sensors (70-200L, 50 f/1.8, ...), while others will work no better than the $150 18-55 kit lens.
I am a strong proponent of buying EF-S lenses for crop sensor cameras, since they are usually cheaper and smaller. Just buy the full-frame zooms like the 17-40, 24-70, and 24-105 once you actually do upgrade to full-frame.
 meatatarian's gear list:meatatarian's gear list
Canon EOS 5D Mark II Canon EF 28mm f/1.8 USM Canon EF 50mm f/1.4 USM Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm f/4.0L USM +1 more
Peter Kwok
Senior MemberPosts: 2,257Gear list
Agree 100%
In reply to meatatarian, Mar 22, 2012
As a happy owner of EF-s 17-55 & 10-22 lens, I agree 100%. I will get the 24-105 once the price of the 5DMk3 drops.
Peter Kwok
http://www.pbase.com/peterkwok
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5D Mark III Canon EOS M Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm f/4L IS USM +2 more
Eric X10
Forum MemberPosts: 78Gear list
Re: Wow, 15-85 sharper than 24-105 4L?
In reply to Shift7, Mar 22, 2012
Comparison shots:
My eyes are not so good and maybe they're getting worse but after looking at the comparison, IMHO, letters from the 24-105mm showed more sharpness than the 15-85. I could read from the former better than the latter. If you zoom in, the letters are bolder in the 24-105 than in the 15-85. I may be wrong. Just thought I might share these thoughts.
kidcharles
Regular MemberPosts: 245
In reply to Eric X10, Mar 22, 2012
I disagree. I concur with the original poster that the 15-85 is somewhat sharper. It's particularly noticeable on the part of the label that says "Open and Use." Of course this is one test with two particular copies of these lenses but going just by these images, the 15-85 one is definitely sharper. The "boldness" you see may be because the 24-105 image is slightly darker.
Legion5
Senior MemberPosts: 1,047
In reply to kidcharles, Mar 22, 2012
The 24-105mm is a FULL FRAME lens. People just don't seem to understand that concept. Just because it has an L in the name doesn't make it the end all of quality.
The 18-55mm KIT lens has more resolution than the 17-40mm f/4.0 L on crop.
The 24-105mm has 70% more resolution than the 15-85mm on full frame, but with both on crop the 15-85mm is the clear winner of course because it's designed for crop. A full frame lens needs to be more than twice as good as a dedicated crop lens to match it.
Don_D
Forum ProPosts: 15,624Gear list
Yep... and my 17-55 EFS is sharper still..
I did have to get a second copy of the 15-85 as the first copy was soft on the right side.
 Don_D's gear list:Don_D's gear list
Sony RX100 Canon EOS 40D Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +3 more
Suave
Senior MemberPosts: 1,180Gear list
All it tells me that with this particular pair of lenses, on this particular body, before microadjustment, with underexposure, single shot, at this particular focal length, and did you move the target in the process (?) 15-85 does a better job.
 Suave's gear list:Suave's gear list
Olympus PEN E-PL2 Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM Canon EF 70-200mm f/2.8L IS USM +5 more
carlk
Forum ProPosts: 15,940Gear list
Re: Agree 100%
In reply to Peter Kwok, Mar 22, 2012
+1. Even the reason one might buy a full frame in the future is not valid. Get the best lens for what you're shooting now is the wisest thing to do.
Peter Kwok
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm f/1.2L II USM +6 more
MAC
MAC
Forum ProPosts: 13,209Gear list
Re: Agree 100%
In reply to carlk, Mar 23, 2012
I just got a 60d = 15-85 is
$3500 isn't worth FF - $4300 for the heavier kit
WOW- sharp across the frame even wide open, light weight, and true 4 stop IS with 24 -136.
best all around 1 lens set-up I know of for the value per dollars with LR3.6 that does all the corrections-- I got my combo for $1500
I'm a believer
now eyefi, ipad, and OCF next
Peter Kwok
 MAC's gear list:MAC's gear list
Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EF 70-200mm f/2.8L USM Canon EF 100mm f/2.8L Macro IS USM Canon Extender EF 1.4x II +6 more
Astound
Regular MemberPosts: 153
15-85 on crop sharper than 24-105 on FF?
In reply to Shift7, Mar 23, 2012
I hired a 5D mkII with a 24-105 a while ago. After finishing my shoot I did a bit of a test against my 60D and 15-85 lens.
I thought the 15-85 seemed sharper at similar 'equivalent' focal lengths. The 5D dealt with noise much better (which was my main reason for the test). I was very suprised at the sharpness results though.
I may have the images somewhere. If so, I'll try and post them.
Dale Buhanan
Veteran MemberPosts: 3,974Gear list
I also have a 24-105L and a 15-85. In the comparison shots that I took, I found that in the overlapping focal lengths at 24mm and 35mm, the 15-85 had the edge, It was sharper, with less CA, and less distortion. At 50mm it was pretty much a toss up. The lenses looked identical, and you couldn't tell which lens took which picture. But at the long end, at 70mm and 85mm and of course 105mm, the 24-105L had the edge. It was sharper, and had less CA and distortion than the 15-85.
In summary: At the wide end, the 15-85 wins on all counts. Middle range, they are very close to the same. At the long end, the 24-105L wins on all counts -- sharper, less CA and less distortion.
Color was ever so slightly different between the two lenses, with the 24-105L being slightly warmer, but that is easily evened out in PP.
Comparison shots:
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 7D Canon EOS 70D +34 more
MAC
MAC
In reply to Dale Buhanan, Mar 23, 2012
the 24-105 IS is known to be a FF lens. The 15-85 is for hi mpxl 1.6
you are right, the 24-105 has soft issues beyond the center at 24mm - see below
but the crop vs ff - the 15-85 wins 106 - 136 mm fov -it is longer fov by 36 mm so it should be worse everywhere - right? NOT
and the 15-85 has a later, better, 4 stop IS
and the 15-85 is lighter and a great combo with 60d handheld
and it is smooth low sound for video
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=675&Camera=474&Sample=0&FLI=0&API=1&LensComp=355&CameraComp=453&SampleComp=0&FLIComp=0&APIComp=0
Comparison shots:
kind regards
Dale
mermaidkiller
Regular MemberPosts: 427Gear list
Re: Agree 100%
In reply to MAC, Mar 24, 2012
For me the same. I thought about a 5d3 but $3500 for body only is too steep for me as well.
I got a 7d + 15-85 and the lens produces razor sharp images. Of course if I had a FF body I'd use the 24-205 as standard lens, but the 15-85 has more zoom range as 24-105 = 15-65 crop equivalent.
Hopefully Canon will release a 24-135L lens as a FF equivalent of the 15-85.
BTW according to this site the 15-85 wins slightly on the most wide angle side:
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=355&Camera=453&Sample=0&FLI=0&API=0&LensComp=675&CameraComp=0&FLIComp=0&APIComp=0
Canon EOS 7
Canon EF-S 15-85 f/3.5-5.6
Sigma 10-20 f/4-5.6
Canon EF 85 f/1.8
Canon EF 50 f/2.5 Macro
Canon Powershot S100
 mermaidkiller's gear list:mermaidkiller's gear list
Canon PowerShot S100 Canon EOS 6D Canon EF 85mm f/1.8 USM Canon EF 200mm f/2.8L II USM Canon EF 50mm f/2.5 Macro +5 more
Suave
You did notice that those 24-105 test shots were taken on a FF body, right? And the corner softness comes from the parts of the lens that would never have been utilized by a crop body?
MAC
MAC
In reply to Suave, Mar 24, 2012
of course I see this. I have both crop and FF bodies.
The 24mm FOV is better with the 15-85 IS.
The 106 - 136 FOV is better with the 15-85 IS
MAC
MAC
Re: Agree 100%
In reply to mermaidkiller, Mar 24, 2012
had there been a 5d3 that was packaged with a 24-135 4 stop IS F4 L for $3500 for that kit, that is where I'd be right now.
Canon EOS 7
Sigma 10-20 f/4-5.6
Canon EF 85 f/1.8
Dale Buhanan
I completely agree.
kind regards
Dale
