D4 dxomark result is here
Started Mar 20, 2012 | Discussions
KLO82
Contributing MemberPosts: 663
Mar 20, 2012
Nikon D4
ssmumich00
Regular MemberPosts: 413Gear list
Re: D4 dxomark result is here
In reply to KLO82, Mar 20, 2012
The D7000 still bests it for Landscape shots?!?!
Interesting read, thanks!
(w): http://www.neilphotos.com
(p): http://www.suneil.net
 ssmumich00's gear list:ssmumich00's gear list
Nikon D7000 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 20mm f/2.8D +3 more
commiebiker
Senior MemberPosts: 1,388Gear list
Nikon D4: The best Full-Frame overall score ever measured on DxOMark
that's a nice way to start a review
 commiebiker's gear list:commiebiker's gear list
Nikon D3S Sony Alpha NEX-7 Nikon D4 Nikon D800 Sony Alpha 7R +8 more
Horshack
Veteran MemberPosts: 3,920
DxoMark site is down, so my prediciton was correct..
sebastian73
Contributing MemberPosts: 585
Re: DxoMark site is down, so my prediciton was correct..
In reply to Horshack, Mar 20, 2012
Horshack wrote:
http://forums.dpreview.com/forums/read.asp?forum=1021&message=40815405
lol good prediction
Nikon D3s, AFS 16-35/4.0G, AFS 35mm/1.4G, AFS 24-70/2.8G, AFS 85mm/1.4G, AFS 105mm/2.8VR, AFS 70-200/2.8VRII, AFS 200/2.0VR, TC-1.4E II, TC-2.0E III, SB-800
Gitzo GT3541LS tripod with Markins M20, Gitzo GM3551 monopod with RRS MH-01 head
mattr
Veteran MemberPosts: 3,443
You are a genius!
Could you now please predict when I will receive my D800?
DSPographer
Senior MemberPosts: 2,231
Re: D4 dxomark sensor parameters
This data shows significant improvement in the sensor performance from the D3s. For base ISO the full well increased from 84000 e- to 118000 e- while the noise decreased from 26.0 e- to 18.8 e- resulting about a 1 stop increase in base ISO DR. The per pixel read noise at high ISO also improved from about 3.5 e- to about 2.5 e- : but instead of using all that improvement to lower read noise per area, Nikon used some of it to increase the pixel count.
  • Sensor Paramaters Derived From DXOmark.com Data *
ISO: Manufacturers ISO rating
m: Pixel saturation count in electrons
n: Pixel read noise in electrons
g%: Standard deviation of gain error in percent
res: Worst case difference between fitted SNR curve in dB and SNR data points in dB
NikonD4
ISO: 100 200 400 800 1600 3200 6400 12800 25600 51200 102400 204800
m = 118339 60724 29881 14349 7058 3571 1754 912 529 264 125 55
n = 18.83 10.14 5.98 3.39 2.27 2.55 2.41 2.62 2.78 2.67 2.70 1.82
g% = 0.31 0.33 0.35 0.31 0.20 0.00 -0.00 0.57 0.00 0.00 0.00 0.00
res= 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
NikonD3s
m = 84203 80184 40167 19916 10233 4981 2474 1222 745 367 177
n = 25.96 24.21 12.74 7.39 5.36 3.72 3.52 3.45 3.23 3.03 2.82
g% = 0.37 0.32 0.34 0.37 0.44 0.39 0.48 0.35 0.50 0.00 -0.00
KLO82
In reply to DSPographer, Mar 20, 2012
Thanks for your analysis, but D3S does not have ISO 100, right?
DSPographer wrote:
This data shows significant improvement in the sensor performance. For base ISO the full well increased from 84000 e- to 118000 e- while the noise decreased from 26.0 e- to 18.8 e- resulting in a big increase in base ISO DR. The per pixel read noise at high ISO also improved from about 3.5 e- to about 2.5 e- : but instead of using all that improvement to lower read noise per area, Nikon used some of it to increase the pixel count.
NikonD4
NikonD3s
DSPographer
The DXOmark D3s data shows ISO 100 as having slightly higher saturation than ISO 200. So from the DXOmark data you could say that ISO 100 is really equivalent to ISO 190.
knickerhawk
Veteran MemberPosts: 3,115
In reply to mattr, Mar 20, 2012
mattr wrote:
You are a genius!
Screw that! Please predict the winning numbers for this week's Mega Millions lottery. It's up to $240 million!
Horshack
Full D4 vs D3s SNR ISO 12,800 comparison
rhlpetrus
Forum ProPosts: 22,874Gear list
Re: Full D4 vs D3s SNR ISO 12,800 comparison
One has to take into account the margin of error of these measurements, including sample variation, then SNR is a very close tie, actually, just like Marianne predicted. DR is not, as we have been seen from Bill's data.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +3 more
Horshack
D4 vs D3s color sensitivity
perhort
Regular MemberPosts: 133Gear list
In reply to rhlpetrus, Mar 20, 2012
Really nice to see how the dynamic range lingers so that between iso 100 and 1600 there is a drop of just one stop!
 perhort's gear list:perhort's gear list
Nikon D700 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 35mm f/2D Nikon AF Nikkor 85mm f/1.8D
KnightPhoto2
Senior MemberPosts: 1,332Gear list
NikonD4
NikonD3s
Thank you for that analysis!
 KnightPhoto2's gear list:KnightPhoto2's gear list
Nikon D4 Nikon D800E Nikon 1 V3 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +19 more
rhlpetrus
Re: D4 vs D3s color sensitivity
I don't see much difference, it's all within measurement margins of error + sample variance. COncluding from the data, it looks like only DR one has a significative difference, in favor of D4, all the rest is a tie, which is a good thing.
Renato.
OnExposure member
(after Ed Murrow)
perhort
In my view, Nikon did the right thing. Low-light performance was already insanely good with the D3s. What was needed was more dynamic range for high contrast conditions. Hence the more "balanced" approach. It will now be interesting to see what the 1DX can do. If the D4 is one stop better in DR then perhaps only the London rain will be able to save Canon at the Olympics :-).
Renato.
OnExposure member
(after Ed Murrow)
bobn2
Forum ProPosts: 27,817
NikonD4
NikonD3s
I just did the sensorgen run for D4
http://www.sensorgen.info/NikonD4.html
Pretty much the same as yours (not surprising, it uses your method)
Bob
bobn2
Rather, Nikon obtained that improvement by scaling down the pixel. Under strict scaling, read noise reduces with pixel area. 3.5x(7.21²)/(8.4²)=2.5. Not a coincidence.
Bob
DSPographer
In reply to bobn2, Mar 20, 2012
But they could have kept the same active area with the new smaller source follower transistor. That would have kept the new lower read noise in e- now over the larger pixel but raised the minimum ISO setting and of course left the pixel count at the old 12 MP value. I think they made the right choice to keep high ISO performance the same because the result is they get a bigger increase in base ISO SNR and DR along with more resolution instead of a tiny reduction in noise for the deepest high ISO shadows.
