Just got my 24 f/1.4 and 35 f/1.4... wow, these are huge lenses
Started Mar 19, 2012 | Discussions
fabgo
Senior MemberPosts: 1,294
Mar 19, 2012
I have to admit I was surprised by how huge these lenses are. Not exactly for casual walking around. I haven't received the 85 f/1.8G yet. I hope that lens is of a more manageable size, similar to the 50 f/1.4G.
I'm intrigued by the rumored 28 f/1.8G, and hope Nikon will introduce more small, lightweight primes with (hopefully) excellent image quality in the future.
Fabian
nelsonal
Senior MemberPosts: 2,455Gear list
Re: Just got my 24 f/1.4 and 35 f/1.4... wow, these are huge lenses
In reply to fabgo, Mar 19, 2012
Aren't they about the same size as the zooms like the 18-105 and 24-120? It's difficult to make a fast retrofocal lens with decent corner performance without giving it a fairly large front element. Some review sites give dimensional specs, or consider AF-D/manual primes lenses for fairly compact bodies.
Phil Flash
Veteran MemberPosts: 4,176
Here's the cure: Voigtlander 40mm F2!
The Voigtlander is sharp, small, and pancakey!
I don't understand why manufacturers make such big honking lenses when the ISOs crank up so high now.
I'd love it if Nikon made a nice updated 35mm F2 for the rest of us.
Phil Flash
SF, CA USA
It's not the camera. It's you.
Stuff I own in my profile.
Palmguy
New MemberPosts: 23
Fabian
The 85/1.8G is kind of in between but feels to me closer in size to the 24 and 35 than to the 50. It is lighter than both though.
joejack951
Senior MemberPosts: 2,311Gear list
Re: Here's the cure: Voigtlander 40mm F2!
In reply to Phil Flash, Mar 20, 2012
If you are used to kit zooms, perhaps then the 35/1.4G might seem big but compared to any f/2.8 zoom, it's fairly compact. The 67mm front element alone makes it seem small next to a 77mm front element lens.
As far as high ISO being a replacement for a fast lens, I'd have to disagree. If I don't mind the loss of DOF (or want less DOF), I'll gladly shoot at a lower ISO even with the best high ISO cameras on the market. Likewise, I'll take the faster shutter speed at the same ISO. If high ISO fixed everything, we'd probably all shoot our lenses at f/8 and get away with much smaller and cheaper optics.
 joejack951's gear list:joejack951's gear list
Nikon Coolpix AW100 Nikon Coolpix P7700 Nikon D300S Nikon D3S Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
MrSkelter
Contributing MemberPosts: 630
In reply to fabgo, Mar 20, 2012
Smaller, lighter, better-quality? So say we all.
The primes are about as small as they can make them. There's no money in making things bigger without purpose. With the D4 and D800 Nikon have shrunk things as far as they can within their own constraints. I'm sure if they can bend the science they will.
fabgo
In reply to joejack951, Mar 21, 2012
joejack951 wrote:
Not really. The 24 f/1.4 and 35 f/1.4 are pretty much exactly the same size, both in length and width and weight. I don't understand why Nikon chose to put a 67mm thread on the 35mm. It would have been more convenient to keep them all at 77mm.
As for comparing them with zooms, they are almost the same size & weight as the 17-35 f/2.8. I certainly wouldn't pick the primes over the zoom because they are smaller & lighter.
Fabian
joejack951
In reply to fabgo, Mar 21, 2012
fabgo wrote:
The 67mm filter allows for a smaller diameter hood assuming you use one. The smaller hood does make the lens appear smaller (which is what I was referring to in my original statement).
They are about 20% lighter and an inch shorter than the 17-35 (not much in the grand scheme, I agree). The comparison heavily favors the primes when you sit them next to the 24-70 though. Again, I agree that size and weight are not the reason to choose the f/1.4 primes.
nathantw
Contributing MemberPosts: 904
Heck yea it's big. I carried around the 24 f/1.4 and D700 one night and it was as heavy and almost as big as the 28-300. It's HUGE and certainly not like the 24 f/2.8 I used to carry around on trips.
Fabian
http://www.flickr.com/photos/nathantw/
Always have a camera with you and make sure you use it.
r_k_t
Regular MemberPosts: 132Gear list
In reply to Palmguy, Mar 21, 2012
Here's a side by side of the 85 1.8G with the 105 VR ... and another of the older 85 with the 24 2.8D ... the new 85 is significantly larger ...
http://rohanthakursphotoblog.blogspot.de/2012/03/gear-big-new-85mm.html
fabgo
joejack951 wrote:
fabgo wrote:
Got it. I actually haven't taken the hood(s) out of the box yet.
Fabian
fabgo
In reply to r_k_t, Mar 21, 2012
It's big, but surprisingly light weight. Lifting it, I get the impression it's all plastic. Even the 50 f/1.4 feels heavier, but probably only because it's more compact.
Fabian
Windancer
Veteran MemberPosts: 4,732Gear list
I know as does Nikon you can't please everyone, but I have to agree the 67mm is an odd size and not a Nikon "standard" in years past (52,62,72 & 77).
I have had Nikon stuff for over 20 years and some of my many lenses are older than that, it has always be Nikon's practice to use filter diameters of 52,62,72 & 77, don't get me wrong I don't have a problem with 67mm size just means another polarizer needed
Terry
Graham Fine Art Photography
http://www.pbase.com/windancer
http://gallery.reginaphotoclub.com/TGraham
Remember, it's not the CPU that's in your camera that makes great images, it's the one located about 4" behind the viewfinder that does.
Disclaimer: This e-mail is intended to impart a sense of humor. Given e-mail's inability to carry inflections, tone and facial expressions it may fail miserably in its intent. The sender acknowledges the limitations of the technology and assigns to the software in which this message was composed any ill feelings that may arise.
 Windancer's gear list:Windancer's gear list
Nikon D100 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V2 +19 more
bogrod
Forum MemberPosts: 58
In reply to Phil Flash, Mar 22, 2012
Some photographers like shallow depth of field. To some, that may be a lost or dying art, but not to all of us.
joejack951
In reply to Windancer, Mar 22, 2012
I would like to know the whole story behind the 67mm filter. Something tells me it's along the same lines as the design of the 14-24 front element. Nikon would rather inconvenience a few than compromise the design somehow.
Can't you use a step down ring to mount a 72/77mm polarizer on a 67mm filter thread?
http://www.bhphotovideo.com/c/product/98934-REG/General_Brand_72_67_72mm_67mm_Step_Down_Ring_Lens.html
http://www.bhphotovideo.com/c/product/98936-REG/General_Brand_77_67_77mm_67mm_Step_Down_Ring_Lens.html
danidentity
Contributing MemberPosts: 737
Funny...
In reply to fabgo, Mar 23, 2012
Haha funny, I consider the 35 1.4G on my D700 my small and light walkaround kit. I guess it's all relative.
fabgo
Re: Funny...
In reply to danidentity, Mar 23, 2012
You know, part of it is I recently switched to a Panasonic GX1. When you own some m4/3 lenses, anything 35mm looks and feels humongous.
Still, 1.5 pounds is pretty heavy for a prime lens. Carry around a bag full of these and you're schlepping quite a bit of weight around.
Fabian
whoosh1
Contributing MemberPosts: 980
67mm filter size
In reply to Windancer, Mar 26, 2012
It looks like its becoming a standard size for Nikon - 35mm f/1.4G, 85 f/1.8G, 70-300mm VR, 24-85 AF-S (discontinued) - also DX zooms 16-85 VR, 18-70, etc.
CMalsingh
Senior MemberPosts: 1,557
...and do you like the quality?
In reply to fabgo, Mar 30, 2012
if the results don't justify the weight/size, it's an issue.
If they do, well...
I quite like the recent 35mm f1.4
Colin
http://www.pbase.com/celidh
fabgo
No, I returned them...
In reply to CMalsingh, Mar 30, 2012
If they do, well...
Colin
Hi Colin,
I ended up returning both. The 24/1.4 had weird focus/sharpness issues and the 35/1.4 had very unsharp corners even at f/5.6 due to field curvature. I asked for an exchange, hopefully the 2nd copy will be better.
Fabian
