Was trippling mp count worth it?
Started Mar 15, 2012 | Discussions
ohmydentist Senior Member • Posts: 1,918
I saw resized comparisons between D800 and D700. D800 seems to have little more detail. But hardly justifying 3x mp count and file sizes.
300% jump on mp count for 3% more detail? I don't think D800 would allow aggressive cropping as some hoped.
Just Shoot !
Nikon D700 Nikon D800
xrdbear Veteran Member • Posts: 3,885
Re: Was trippling mp count worth it?
Well you must be able to crop two thirds of the picture away and still get 12Mp. In my book that's a pretty substantial crop.
Brian
Fine Art Print sales of the Isle of Skye at:
http://www.eyeofskye.co.uk/
u007 Senior Member • Posts: 1,681
Just Shoot !
Huh?
You looked at resized shots and didnt see much more detail? That's not so surprising is it? Especially as the detail is limited by the viewing size (I guess your monitor isn't larger than 30 inches) and resolution (I guess your monitor isn't more than 100dpi)
And how does resizing have anything to do with cropping?
Look at the imaging resource comparisons, and check out the white paper wheel on the right. At 100% I see FAR more detail in the d800 shots. And I could crop that little piece out and have a significantly more detailed photo of the wheel than I could with the d700.
I don't understand how you made the jump between a resized image and making a statement about cropping. Those two things have almost nothing to do with each other. A crop is taking a piece of the original file. Resize is changing that original file and downsampling it.
ohmydentist OP Senior Member • Posts: 1,918
what good is resolution, if detail is not there?
Just Shoot !
wombat779 Regular Member • Posts: 210
ABSOLUTELY worth it for me. At low ISO, the D800 has much more detail (3X) at full resolution than D700 at full resolution. At high ISO, I can downsize and get detail and noise performance that exceeds the D700 and gets close to D3S/D4 levels. I can also use the DX crop mode and get performance that equals or betters the D7000.
In short, the D800 gives me massive flexibility, and the only downsides are (i) a bit lower FPS, which doesn't matter to me at all, and (ii) bigger filesizes. With respect to bigger filesizes, hard drives are now cheap as chips, and in fact are about 1/6 the price per GB than they were when the D700 was released.
Zlik Contributing Member • Posts: 990
Why don't you compare the D700 upscaled to 36 MP to the D800 at 36 MP and then come back and tell us your conclusions ?
Don't you need fine details, in order to do aggressive cropping?
Just Shoot !
Fearless_Photog Senior Member • Posts: 1,250
People use re-sized images for comparison because it's a logical way to compare how the images will look at when printed or uploaded to the web at the same size. That doesn't mean every D800 owner is going to be re-sizing their photos to 12 megapixels. With the D800 you'll be putting a lot more pixels on the same area of your subject, and consequently a lot more detail will be resolved. Whether you need or want to use that detail, and whether it's worth it is up to the individual photographer.
The D800 also has better DR, high ISO performance, and color accuracy with all it's extra pixels. Asking if it's "worth it" makes it seem like you're sacrificing something as far as image quality.
http://www.flickr.com/photos/mcullenphoto/
shifting goal . . . .
Now, D800 shows superiority only when D700 photo is blown up 3x? Not when D800 is resized to D700 size anymore?
Just Shoot !
Exactly. That's what I've always said to myself. But a lot of people don't get it.
Why would you re-size your D800 image to 12 megapixels before cropping it?
There is no need to upscale the D700 up 3x to see the difference. Have you actually seen comparisons between the two?? The D800 shows details that you can't even imagine when looking at D700 photos.
JosephD05 Regular Member • Posts: 215
If someone cannot see how the d800 will destroy the 700 in overall image quality then they are in denial.
lanef Forum Pro • Posts: 10,317
My advice to you, the D800 is going to be a bad camera and a flop, don't even bother to compare or to read anything about it, you have your precious D700 which is way better, just keep shooting, don't lose sleep over those who want to chose a camera which is not justified according to you. Have a good sleep.
kenwj Contributing Member • Posts: 573
Were these images jpegs posted on the web resampled down to 72ppi which essentially blows away the bulk of the fine detail?
My final outputs are prints. My D700 will give me a 12" x 18" print at 230-240 ppi. The D800 will give it to me at 300ppi and I need to down sample the D800 files by about 20% to get to 300 ppi at 12" x 18" This is a 25% increase in print resolution even with having to blow away 20% of the information I captured in the D800.
I'm thinking 36 megapixel, based on everything I have heard from 24 mp D3X users, will be a substantial boost in resolution.
 kenwj's gear list:kenwj's gear list
Nikon D800
Maybe I wasn't clear on that. I meant I saw the comparison where D800 is downsized to match D700 size.
Just Shoot !
Fullframer Contributing Member • Posts: 731
Not if your 300 dpi prints are 8x12 or smaller, you will see no diff going from D700 to D800. D800 will only notice a dif once you exceed 8x12 printing size.
Yes, once you exceed 8x10 / 8x12 prints or have to crop.
Otherwise if you print a max size of 8x12 or smaller and aren't cropping you aren't going to notice a diff from D700 vs D800.
cluna Senior Member • Posts: 1,403
It will be slightly sharper since the higher MP is reducing the AA's blur to what is ultimately sub pixel. So you have a result that is like a 12-16MP with and AA filter.
-C
Leos Senior Member • Posts: 2,067
Cropping has always been a bad idea, so I dont know why that would change with a new camera model. As soon as you start to crop, you basically throw away precious light that you paid huge amounts for in camera and lenses to be able to collect.
What the D800 will definately do better than the D700 or probably any other 35mm DSLR, is making really large prints from shots taken with careful technique and an excellent lens.
What the more techincal minded persons in here are discussing and showing is that the D800 will be the equal to the D700 (or the D7000) or even a little better (your 3% comes to mind) after you have :
a) paid for upgrade to the D800 with your own money
b) learned to live with the slower frame rate
c) learned to live with the file handling or upgraded your computer
d) applied various PP
If you need reach (or "crop") buy a D7000 to go with your D700 or even a 1-series. Cheaper, and does the same thing without the hassle.
