Q about 50mm/85mm on crop and FF bodies
Started Mar 9, 2012 | Discussions
maboleth Contributing Member • Posts: 661
I've been shooting with 7D and 50mm f1.4 for quite some time. I love this combo. It's basically a 80mm lens on a cropped sensor. Beautiful for portraits and closeups.
I'll probably switch to 5dmk2 in near future. So I thought about a good lens choice. Obviously, 85mm f1.8 comes to mind.
However, I don't know will I get the same "tightness" in closeup shots, because the closest focusing of 85mm is 0.8 metres, while 50mm is 0.45m.
Sometimes I really like to go closer and closer... many detail shots and baby portraits I do at approx. 0.5 - 0.6m from camera. Should I concerned on a FF with 85mm lens?
Thanks.
http://ivframes.com -- my official site
http://facebook.com/ivframes -- become a fan
http://travelingnome.ivframes.com -- bits of this and that
Canon EOS 5D Canon EOS 7D
Steve Balcombe Forum Pro • Posts: 11,610
Re: Q about 50mm/85mm on crop and FF bodies
If you're using the 50 in that way, then yes.
The best way to compare how the lenses fill the frame on their respective bodies is to take the maximum magnification from the specs on the Canon web site, and multiply by the crop factor:
50/1.4 on 1.6x crop: 0.15 x 1.6 = 0.24
85/1.8 on full frame: 0.13 x 1.0 = 0.13
So the 50 on the crop camera gets almost twice as tight as the 85 on full frame. The limited close focusing is a definite shortcoming of the 85/1.8.
BAK Forum Pro • Posts: 20,634
On a so-called full frame camera, a 100mm f2.8 Canon macro is a great head and shoulders, and other subjects too, choice.
New model or old model.
If the price is too steep, the 85 1.8 is still good; just crop the file a bit.
BAK
maboleth OP Contributing Member • Posts: 661
Thanks!
Just as I thought...
BAK said about 100 macro lenses. That could be an option. What do you think?
maboleth wrote:
Thanks!
I used to use my old 100 macro (the original non-USM 1990-ish model) as an occasional portrait lens on my film SLR. I would say it was pretty good - focal length was ideal and f/2.8 gives enough DoF control and background blur on full frame.
filmluvr
filmluvr Veteran Member • Posts: 3,196
On alternative...
You might consider the 100mm f/2 with a 12mm Canon extender. Infinity focus isn't necessary for portraiture, and I have always found the 100mm FL to be the most useful for full frame.
http://jackandkelly.zenfolio.com/
Canon 5D, 17-40mm, 70-300mm IS USM, 50mm f/1.8 II, 100mm macro, 28-135mm, 28mm f/2.0 Kiron, 135mm f/2.8 Rikenon, 200mm f/3.5 Komuranon, 500mm f/7.0 Komuranon
 filmluvr's gear list:filmluvr's gear list
Panasonic Lumix DMC-FZ200 Canon EOS 5D Canon EF 50mm f/1.8 II Canon EF 17-40mm f/4.0L USM Canon EF 28-135mm f/3.5-5.6 IS USM +7 more
