D4 x 5D3 ISO series in ACR, IR raws (large file)
Started Mar 8, 2012 | Discussions
rhlpetrus
Forum ProPosts: 22,874Gear list
Mar 8, 2012
Same post as in Nikon forum (hope DPR doesn't ban me ;).
ACR default, chroma NR=0. D4 shifted by 1 stop at right for the differential analysis.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +3 more
Nikon D4
rhlpetrus
Remark: 5D3 res = 16MP
In reply to rhlpetrus, Mar 8, 2012
To simulate same printing sizes.
Renato.
OnExposure member
(after Ed Murrow)
altenae
Regular MemberPosts: 377
Re: D4 x 5D3 ISO series in ACR, IR raws (large file)
Till 6400 ISO they are pretty close.
Enjoy Photography
Kevin Coppalotti
Veteran MemberPosts: 7,978
D4 is better but bang for your buck 5D3 would get my money, 6400 iso would be plenty enough for me.
Kevin Coppalotti
http://maxhr.zenfolio.com/
kuklukklak
Junior MemberPosts: 31
When everyone saw the 5D3 to be 1 stop better on IR, Nikon folks tried to tell the forum that there're dif in speed. And now they come up with images that show 1D4 one stop better. Hahaha. Nice try. It must take you lots of time to do this, but sorry I dont give it my credit, cause I downloaded the files myself and the 5D3 images looked much better.
BTW, if I upgrade from my 5D1, it'll be the D800 cause I want resolution more, but it seems that the ISO advantage Nikon once had has vanished, the fact remains to be seen anw.
rhlpetrus
In reply to kuklukklak, Mar 8, 2012
Jpegs, lots of NR.
It took exactly the amount of time needed to convert, crop and put on canvas, +- 20 min.
Why don't you post yours?
D800 should be close to D4 up to 3200, then D4 will be better. Re 5D3, D800 should be close up to 6400. Take your pic.
Renato.
OnExposure member
(after Ed Murrow)
VivaLasVegas
Senior MemberPosts: 1,210
Not bad for a 22mp sensor VS a 16mp, it is now safe to say 1DX will be crowned the new lord of darkness.
garyknrd
Contributing MemberPosts: 607Gear list
I think this is a great thread. And believable for me. Thanks for the trouble. Both cameras are first class.
 garyknrd's gear list:garyknrd's gear list
Canon EOS 7D Canon EOS-1D Mark IV Pentax K-5 Pentax K-3 Canon EF 300mm f/2.8L IS II USM +3 more
Tim O'Connor
Veteran MemberPosts: 4,438Gear list
Thanks...
Much love for this - Thanks for taking the time.
 Tim O'Connor's gear list:Tim O'Connor's gear list
Canon EOS 7D Nikon D600 Canon EF 400mm f/5.6L USM Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.8D +8 more
Andre De Angelis
Senior MemberPosts: 2,189
In reply to VivaLasVegas, Mar 8, 2012
No it's not. 1DX will only be a stop better than the 5D3, so at the end of the day, there will be no difference between the D4 and the 1DX. Both superb cameras.
aftab
Veteran MemberPosts: 7,499Gear list
ACR default looks nosier for both cameras. I did with all ACR adjustments set to zero. 100% crops. 5D3 size reduced to 16 MP.
aftab
In reply to aftab, Mar 8, 2012
Another 5D3 ISO6400 pic here. ACR default makes pic look uglier than they are.
http://forums.dpreview.com/forums/readflat.asp?forum=1032&thread=40842458
Daniel from Bavaria
Contributing MemberPosts: 726
Hello,
based on that pictures it is quite obvious for me:
  • from Iso100 on, there is more reslolution and equal noise with the mkIII
  • from Iso6400 on, there is more grain in the mkIII pictures, but still a higher reslolution with the mkIII.
But to put into a correct relation - the differences are quite minor.
Very good!
Best regards,
Daniel
BigG30
Regular MemberPosts: 256
Renato.
OnExposure member
(after Ed Murrow)
Great work.
Both great cameras, looks identical up to 6400 and then the D4 is better (but only by a small amount) at 12800 and 25600. Given that the 5D3 has a higher resolution, it's to be expected that it won't be quite as good.
Rob
Rob
Contributing MemberPosts: 513
Thanks for the post. I'd give the edge to the D4 a bit for noise, but its the ugly Canon noise pattern that bothers me more. There is less blotchy-ness and "banding" with the Nikon.
BillCat
Contributing MemberPosts: 948
Is the 5D3 a little brighter?
That would be a plus for the 5D3 results.
-Bill
spidercrown
Regular MemberPosts: 133Gear list
Re: Is the 5D3 a little brighter?
In reply to BillCat, Mar 8, 2012
don't worry, 5D3 is very close, only a stop or less worse, and just half the price of D4.
 spidercrown's gear list:spidercrown's gear list
Nikon D90 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR
DarkShift
Regular MemberPosts: 208Gear list
LSC converter was used
The thing that makes this complicated is that they used 50mm/2.5 macro with LSC (1.4X 1:1 extender) for Canon which means around 1 stop light loss that they had to compensate with exposure time.
And according to web sources the effect of the LSC aperture is not shown on the exif data.
So unless the exposure correction was spot on for the converter its hard to say.
-Bill
 DarkShift's gear list:DarkShift's gear list
Olympus OM-D E-M5 Nikon D800 Canon EOS 5D Mark III Sony Alpha 7R
Taikonaut
Senior MemberPosts: 2,513
From your samples it looks like the 5D3 has about 2/3 stop more chroma noise than D4. However 5D3 is sharper and has more details, colour is also stronger. On the 5D3 if you reduce saturation, add a touch of chroma NR and reduce sharpness to match the D4 you will probably find they are very similar across all ISOs.
Andre De Angelis
Still irrelevant - F8 is F8
In reply to DarkShift, Mar 8, 2012
What web sources?
