Quality of Noise Reduction in Lightroom 4?
Started Mar 7, 2012 | Discussions
kidcharles
Regular MemberPosts: 245
Mar 7, 2012
Hi all,
I've recently started using LR3 to process my Canon RAW files. (I'm on Windows XP at the moment so I can't use LR4 until I upgrade.) Frankly I don't like the effect it has on my photos when using Contrast Noise Reduction higher than about 25 on the slider, you get that plastic look very quickly above that, and if you sharpen afterwards you get terrible artifacts. I've tried out Topaz Denoise 5 and while the algorithm is fantastic, it strips off the EXIF data which is just obnoxious, and of course I have to go to TIFF to use it and would rather stay in RAW if I can. Also you can't batch process with it, and assorted other annoyances. (To me Denoise seems like someone put a Maserati engine into a rusty old school bus.)
Can anyone who has used it comment on the quality of the noise reduction feature in LR4? Is it different or improved over LR3? How does it compare with Topaz Denoise 5? Thanks.
bpatient
Forum MemberPosts: 75
Re: Quality of Noise Reduction in Lightroom 4?
In reply to kidcharles, Mar 7, 2012
I've used LR3 since the beta version as well as the LR4 beta. I purchased the LR4 upgrade this morning, but I haven't had a chance to compare it to the LR4 beta version. As far as I can tell, the noise reduction in LR4(beta) is the same as in LR3, although the new process conversion seems to produce, by default, somewhat higher local contrast and seems to be, therefore, somewhat sharper than the LR3 version. I don't understand what you mean by "Contrast Noise Reduction" in Lightroom, since (although the luminance noise reduction does include an adjustment for contrast) the two main means of noise reduction in Lightroom are luminance and color.
Noise reduction and sharpening interact in Lightroom. Perhaps you should try various differing parameters in an attempt to find something that suits you. Many people seem pleased by what they can accomplish in Lightroom.
IanSeward
Regular MemberPosts: 301
kidcharles wrote:
Hi all,
I suggest you have a look at this article:
http://www.sansmirror.com/articles/proper-noise-reduction-in.html
Ian
DUMB4SS
Regular MemberPosts: 470
At the risk of being patronising
Are you exposing correctly, as I've not seen any issues with LR noise reduction on reasonably well exposed images.
Reilly Diefenbach
Veteran MemberPosts: 9,486Gear list
The new LR noise reduction seems unchanged to me, as in it destroys detail when you dial it up enough to smooth a background compared to Topaz. The good news is that you can brush it selectively, cleaning up your background (somewhat) while maintaining detail in the subject, although the max setting isn't strong enough, at least in the Beta.
kidcharles
In reply to bpatient, Mar 7, 2012
Thanks for the info. My mistake, yes I was referring to "Luminance" NR not "Contrast."
kidcharles
In reply to Reilly Diefenbach, Mar 7, 2012
Yes, that selective denoising is something I'd be very interested in. I do a lot of bird photography and typically this means I've got a subject that has an enormous amount of fine feather detail with a completely blurred background. Typically I want basically no noise reduction on the bird and max on the background. Currently you can do masking with sharpening, which is perfect, but you can't mask the noise reduction. It would be great if they had an inverse mask for NR, where it would only do NR in areas of low local contrast/detail.
My dream scenario would be that Topaz licenses their algorithm to Adobe to free it from the confines of it's clunky external interface.
kidcharles
Re: At the risk of being patronising
In reply to DUMB4SS, Mar 7, 2012
Oh yes, I know about exposing correctly (ETR, etc.), but even images that are exposed correctly can require NR, especially higher ISO shots (for example BIF shots which I do a lot of).
Reilly Diefenbach
Photoshop with Denoise/Topaz Remask does exactly what you want, at a price...
Eric Chan
Senior MemberPosts: 2,800
Lr 4 noise reduction and sharpening is the same as in Lr 3. (Entire Detail panel is the same.)
Eric Chan
http://people.csail.mit.edu/ericchan/photos/
http://people.csail.mit.edu/ericchan/dp/Epson3800/index.html
DUMB4SS
Maybe a dual export then
Export one version with the noise reduction as you need it and then another with all the detail visible.
Overlay them in photoshop and mask out the areas you require.
You could also try After Shot Pro, as that has Noise Ninja built in.
Just had to google BIF BTW.
Gregm61
Forum ProPosts: 14,415Gear list
In reply to Eric Chan, Mar 7, 2012
The controls are the exact same, but the overall processing differences in the new ACR 7 in LR4 have me adjusting some of the sharpening and NR values I was using ACR/CS5. No doubt, once CS6 is out with the new ACR the same adjustments will have to be made just as I had to make adjustments moving from CS4 to the new ACR in CS5.
Photoshop and Lightroom use the exact same ACR program, the programs just lay out the controls differently on the screen. Last night was my first go in Lightroom. Nice program, but looking at it for the first time after using ACR in Photoshop exclusively for a few years, it took more than a few minutes finding my way around.
 Gregm61's gear list:Gregm61's gear list
Leica M9 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +17 more
RetiredInFlorida
Senior MemberPosts: 1,303
bpatient
you will see this if you click on - contact Adobe
ALERT - We are experiencing high call volumes due to the demand for Adobe® Photoshop® Lightroom® 4. We apologize for any delays this may cause.
Mike
DUMB4SS
FYI Greg
In reply to Gregm61, Mar 7, 2012
Eric is one of the team who developed Lightroom, so he may know a bit about it.
Gregm61
Re: FYI Greg
Don't doubt it. I am sure they are exactly the same, but, as I said, the other new processing being done in LR4 vs. ACR in CS5 has affected how much noise reduction I use. Noise reduction is just one part of the process, and the other "stuff" can have an affect on how much of the same thing you have to use.
Royi Avital
Regular MemberPosts: 493Gear list
In reply to Eric Chan, May 22, 2012
Eric, what about the demosaicing algorithm?
 Royi Avital's gear list:Royi Avital's gear list
Olympus PEN E-P3 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +2 more
joey_B
Veteran MemberPosts: 3,080
In reply to Reilly Diefenbach, May 22, 2012
could you post the unprocessed original of that image alongside with your edit, so the OP can see what the actual improvement is?
