Just posted - EOS 5D Mark III low-light ISO series samples
Started Mar 2, 2012 | Discussions
Andy Westlake
Senior MemberPosts: 2,928Gear list
Mar 2, 2012
Hi all,
We've just published a quick set of full size JPEG ISO-comparison samples from the 5D Mark III. I'd like to urge everyone to read carefully and consider the text in our news story when assessing them - these are deliberately shot under demanding conditions (approx 3EV and 3000K):
We've had a chance to prepare a set of full-resolution studio-based JPEG samples from a pre-production Canon EOS 5D Mark III, at all available ISOs from 50 to 102800. We've chosen to shoot under low level halogen lighting, which provides a stern test of the camera's sensor and noise reduction systems. Note that these samples are not intended to replace, or even be comparable to our standard studio tests, which we'll publish as usual when we get our hands on a production camera.
At a colour temperature of about 3000K and low light intensity (approx 3 EV), these images are also neutrally white-balanced. This requires extreme amplification of the blue channel (and to a lesser extent the green) relative to the red, accentuating any noise or banding that might be introduced by the camera. This should therefore be considered close to the worst-case scenario - under many situations you'll see less noise at high ISOs, for example when shooting indoors in daylight. Also remember that this is a pre-production camera, so may not be entirely representative of final image quality.
You can look at the samples from here:
http://www.dpreview.com/news/2012/03/02/canoneos5dmarkiii-isoseries
Andy Westlake
dpreview.com
 Andy Westlake's gear list:Andy Westlake's gear list
Fujifilm FinePix F30 Zoom Olympus Stylus Verve S Olympus XZ-2 iHS Canon EOS 5D Panasonic Lumix DMC-GF1 +11 more
candleJack
Senior MemberPosts: 1,451Gear list
Re: much better than the first impression left by canon..
In reply to Andy Westlake, Mar 2, 2012
The DPR samples look a lot better to me than what canon has showed so far.
So these are jpegs generated by the camera? Any details on NR settings?
Best regards,
Alex
We make a stand now, or there will be nobody left to go to the chopper..
 candleJack's gear list:candleJack's gear list
Canon EOS-1D Mark II N Canon EOS 350D Canon EF 35mm f/1.4L USM Canon EF 50mm f/1.8 II Canon EF 85mm f/1.2L II USM +4 more
slerman
Regular MemberPosts: 182
I never thought I'd shoot at 25600
...but I will, when needed, with the 5DMKIII. Impressive.
Birdman7
Senior MemberPosts: 1,016Gear list
Re: 51200 looks pretty usable.
Must say im impressed. Details are not bad and noise well supressed.
There seems to be some hint of horizontal banding on the top righthand side of the next ISO 102400 image though.
Wasnt impressed by the ISO 3200 or even the ISO 800 image on the Canon sample page of the Aurora Borealis shots here http://web.canon.jp/imaging/eosd/samples/eos5dmk3/ the images looked to suffered from too much noise reduction and loss of detail, esp concerning at ISO 800!
Would have liked to see some weather sealing on the new vertical grip which seemed have suffered water leakage on the 5d2 in the Antarctic tests here http://www.luminous-landscape.com/essays/antarctica-2009-worked.shtml
but overall, thumbs up well done Canon.
Regards.
 Birdman7's gear list:Birdman7's gear list
Canon EOS-1D Mark IV Canon EOS 5D Mark II Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.2L II USM +7 more
SpartanWarrior
Senior MemberPosts: 2,876Gear list
Re: I never thought I'd shoot at 25600
In reply to slerman, Mar 2, 2012
Very impressive indeed.
 SpartanWarrior's gear list:SpartanWarrior's gear list
Nikon D610 Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +2 more
hunk
Veteran MemberPosts: 3,216Gear list
An end to banding as we know it
Shadows are so much better at every iso.
If this beauty had 36MP I would cancel the Nikon!
Thanks DP for the quick tests!
Andy Westlake wrote:
Hi all,
Andy Westlake
dpreview.com
 hunk's gear list:hunk's gear list
Leica M9 Canon Extender EF 2x II Sony 135mm F2.8 (T4.5) STF
Andy Westlake
In reply to candleJack, Mar 2, 2012
Out-of-camera JPEGs, default NR settings.
Andy Westlake
dpreview.com
d2d
d2d
Regular MemberPosts: 190
Re: Just posted - EOS 5D Mark III low-light ISO series samples
Thanks for you r fast posting. Much better than the other images I have seen.
candleJack
Re: Thank you for the clarification.. [nt]
nt
alexruiseco
New MemberPosts: 14Gear list
Great samples!
Thanks for posting this, it gives a very good idea of what this camera is capable for... will wait a few months for the prices to low...
It's good to be big, but it's bigger to be good.
 alexruiseco's gear list:alexruiseco's gear list
Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EOS M Canon EF 50mm f/1.4 USM Canon EF 300mm f/2.8L IS USM +7 more
Slideshow Bob
Senior MemberPosts: 1,475
Wow! That's quite a lot of NR.
Too much NR for my liking. I'd rather have the noise if it meant that more detail was retained. The wood texture changes quite dramatically at 3200, and the detail loss is shocking. I'd wager that a D3s holds considerably more detail at high ISO.
I hope that Canon aren't completely relying on NR for their "improved" high ISO performance, but in my opinion that seems to be the case.
Don't know what to make of the claimed DR improvement at moderate and high ISO. Either the sensor has better DR or it doesn't. Unless they're relying on NR, how can there be a DR improvement at higher ISOs without a base ISO DR improvement? I don't get that.
I suppose RAW samples (or direct RAW -> JPEG conversions) are what we need to see. Right now I'm not convinced by Canon's IQ claims. Low ISO is good, and I can't see any banding, so I guess it's somewhat better than 5DII. We'll see.
SB
steve88
Contributing MemberPosts: 905Gear list
Very Nice, Thanks for Posting These!
I'm in the market for a FF body and am looking at the 5D2/5D3 or D700/D800 and I have to say these images are very nice. I don't need the 36MP of the D800; I need good images in low light/high ISO situations. These shots from the 5D3 are very impressive. Thanks again for posting them!
 steve88's gear list:steve88's gear list
Canon EOS 7D Canon EF 28mm f/1.8 USM Canon EF 85mm f/1.8 USM Canon EF 200mm f/2.8L II USM
HSU
HSU
Regular MemberPosts: 345
Thanks. By far better samples than the Canon ones.
Pretty awesome performance of the mk3 I have to say--as far as the low resolution allows.
clk_walker
Senior MemberPosts: 1,045
Re: Wow! That's quite a lot of NR.
In reply to Slideshow Bob, Mar 2, 2012
SB
Who exactly cares if your are convinced or not??
A bird in the viewfinder is worth...
Hypoxic
Forum MemberPosts: 84Gear list
WOW...but...
All I can think is 'wow', it looks like they've hit the target of an amazing low light camera...but while I expected a price increase above the 5D Mark II, I didn't expect the $3500 price tag.
 Hypoxic's gear list:Hypoxic's gear list
Fujifilm FinePix X100 Ricoh GR Fujifilm X100T Fujifilm X-T1 Fujifilm XF 18mm F2 R +4 more
SpartanWarrior
In reply to clk_walker, Mar 2, 2012
You can say that again, the samples show that it is great.
SB
Marco
Senior MemberPosts: 1,851
Agreed.
And low ISOs aren't impressively "crisp".
Again we need to wait for the real images (Raw), as this result could pretty much depends on jpeg engine and NR applied.
SB
You can't depend on your eyes when your imagination is out of focus.
Marc Twain
treepop
Contributing MemberPosts: 628Gear list
It all comes down to what this camera can do in raw. We unfortunatly just have to wait. I am crossing my fingers for 2 stops better in raw performance, which would justify the price. If this camera is only 1 stop better it would still beat the d3s and be a beast of a camera, but about $500 overprices. If the noise is only marginally better or the same....well...hopefully the 5d2 drops in price
never stop learning
 treepop's gear list:treepop's gear list
Canon PowerShot S90 Canon EOS 5D Mark II Canon EF 50mm f/1.8 II Canon EF 100mm f/2.8 Macro USM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +2 more
ukat123
Contributing MemberPosts: 761
In reply to treepop, Mar 2, 2012
review by engadget
Canon cites the 1D X as being one stop cleaner than the Mark III, ensuring its reign as the top dog in the lineup. Of course, RAW images won't benefit from the in-camera noise reduction, but we're told that they should still be quite pleasing given the new internals.
not good isn'i it
meland
Senior MemberPosts: 5,467
Maybe for your particular tastes but these are only out of the camera JPEGs. We'll see more with RAW samples in due course won't we.
On what grounds can you possibly base that?
As far as I am aware all sensors reduce in DR as ISO increases above base sensitivity. But the extent to which DR falls off with ISO is also dependent on sensor design. It doesn't have to be just more NR applied.
Right.
