SD/SDHC/SDXC card, via external media (USB v.2.0 hard drive, or via Wireless LAN (Eye
Started Mar 1, 2012 | Discussions
baneling
baneling Senior Member • Posts: 1,644
Hi all, I need to get a media card for my T3i. Under the specs of the camera, it says:
SD/SDHC/SDXC card, via external media (USB v.2.0 hard drive, or via Wireless LAN (Eye-Fi card*))
what exactly does Canon mean when it says "via external media (USB v.2.0 hard drive, or via Wireless LAN (Eye-Fi card*))"? does it mean I can plug in a USB hardrive into the camera and transfer the pictures onto it?
 baneling's gear list:baneling's gear list
Canon EOS 600D Canon EOS 5D Mark III Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 Canon EF 70-200mm f/4L IS USM +4 more
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
Lemming51
Lemming51 Forum Pro • Posts: 14,007
Re: SD/SDHC/SDXC card, via external media (USB v.2.0 hard drive, or via Wireless LAN
No.
Note on p. 210 of the instruction manual: "Even if the camera is conntected to a hard disk recorder with a USB cable, movies and still photos cannot be played or saved."
The camera can write files directly to the SD/SDHC/SDXC card installed.
It can also write them to a computer either via an installed Eye-Fi card or a USB connection. The computer acts as a "host" to control the data transfer from the "slave" camera.
Both the camera and USB hard drives are "slave" USB devices. Neither has the "master" or host abilities to enable data transfer between them.
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM +5 more
baneling
baneling OP Senior Member • Posts: 1,644
you didnt' write anything.
Unapologetic Canon Apologist
Lemming51
Sorry, I inadvertently double-clicked on the response link. Try now, I edited it.
