AVCHD Acronyms?
Started Feb 24, 2012 | Discussions
21st Hermit
Veteran MemberPosts: 5,326
AVCHD Acronyms?
Feb 24, 2012
AVCHD acronyms, what do they mean?
GPH? PSH? GFS? FSH?
FHD = Full HD?
This chart was from a Panasonic ZS20 product page.
Lost in the Colorado Mountains!!!
jralbert
Senior MemberPosts: 1,008
Re: AVCHD Acronyms?
In reply to 21st Hermit, Feb 24, 2012
I think FHD is indeed Full Hi Def. The others remain a mystery to me--
joel albert
FFS
FFS
Senior MemberPosts: 1,757
Re: AVCHD Acronyms?
GPH? PSH? GFS? FSH?
FHD = Full HD?
AVCHD: Advanced Video Coding High Definition
All the others acronyms are lost in meaning as they are not explained. They seem to mean differences in video coding, bit rate, screen resolution, interlaced vs progressive, etc..
jrsva
New MemberPosts: 9
Re: AVCHD Acronyms?
GPH? PSH? GFS? FSH?
FHD = Full HD?
FHD does refer to Full HD, meaning 1920 x 1080, in contrast to not-quite-so-high HD, which is 1280 x 720. I'm pretty sure the other 4 acronyms refer in some way to image quality. They ought to be explained somewhere in the Panasonic owner's manual that used them in the table you posted. Greek to me.
Best Regards, JRS
Cy Cheze
Senior MemberPosts: 2,028
AVCHD Acronyms, according to Cameralabs
In reply to 21st Hermit, Feb 27, 2012
Contrary to some light-centric theories, these acronyms are not exactly self-illuminating.
Basically, video at a given bitrate might be in progressive or interlaced form. Or it might be NTSC (60 / 30) or PAL (50 / 25). In some markets, I presume you get NTSC or PAL, but not both.
Don't take my word for it.
Cameralabs:
Set the TZ20 / ZS10 to AVCHD and you have the choice of GFS, FSH, GS and SH quality options. GFS and FSH both record in 1080i, while GS and SH record in 720p; the difference is the GFS and GS modes additionally include GPS location details which are absent on the FSH and SH versions. You may prefer to record AVCHD movies without GPS data to maximise their compatibility.
All four AVCHD modes encode their video at the same rate of 17Mbps. GFS and FSH take a 50 or 60fps output from the sensor (depending on region) and encode 1920x1080 video in a 1080i interlaced format at 50i or 60i respectively. GD and SH take a 50 or 60fps output
jrsva
New MemberPosts: 9
Re: AVCHD Acronyms, according to Cameralabs
In reply to Cy Cheze, Feb 28, 2012
Good explanation Cy. I'm still curious as to what the acronyms actually stand for . . .
Best Regards, JRS
kcphotos
New MemberPosts: 4Gear list
Re: AVCHD Acronyms?
In reply to 21st Hermit, Jul 1, 2012
I wanted to know the same info since I just ordered a Lumix ZS20. Found this table on their online "brochure"
http://panasonic.net/avc/lumix/compact/zs20_tz30/specifications.html
Sean Nelson
Forum ProPosts: 10,590
Re: AVCHD Acronyms?
In reply to kcphotos, Jul 2, 2012
Every camera manufacturer comes up with different acronyms to describe their various resolution and bitrate selections. If you look in the manual there may be some indication of what they stand for, but there's no industry-wide standard. And in actual fact it really doesn't matter what the letters stand for - they're just labels which serve as a shorthand for the quality level. The important thing isn't the letters themselves, but the spatial resolution (1080 x 1920 vs 720 x 1280, for example), temporal resolution (24p, 30i, 60p) and bit rate (17Mbit/sec vs. 28Mbit/sec) that the letters correspond to.
KonaBlend
New MemberPosts: 5
Re: AVCHD Acronyms?
In reply to 21st Hermit, Jul 9, 2012
There is some minor consistency. But then letter-drops come in to do things like keep it at 3-chars or less, or avoid confusing the poor customer by using the letters GPS . Here's a list that is consistent across at least several Panasonic models.
AVCHD
H - high [1280x720, 60p, 13mbps]
FH - full, high [1920x1080, 60i, 13mbps]
SH - super-high [1280x720, 60p, 17mbps]
GS - GPS, super (high) [1280x720, 60p, 17mbps]
FSH - full, super-high [1920x1080, 60i, 17mbps]
GFS - GPS, full, super (high) [1920x1080, 60i, 17mbps]
PSH - progressive, super-high [1920x1080, 60p, 28mbps]
GPH - GPS, progressive, (super) high [1920x1080, 60p, 28mbps]
24H - high [1920x1080, 24p, 24mbps]
24L - low [1920x1080, 24p, 17mbps]
MP4
HD - high-definition [1280x720, 60i, 10mbps]
FHD - full, high-definition [1920x1080, 60i, 20mbps]
TheBitCrusher
New MemberPosts: 1
Re: AVCHD Acronyms?
In reply to KonaBlend, 9 months ago
KonaBlend wrote:
AVCHD
So what then is the difference between PSH and GPH as the above just causes a lot of confusion in my eye's.
Sincerely,
TheBitCrusher
pew pew
Contributing MemberPosts: 683Gear list
Re: AVCHD Acronyms?
In reply to TheBitCrusher, 9 months ago
TheBitCrusher wrote:
KonaBlend wrote:
AVCHD
Sincerely,
TheBitCrusher
theres a mistake there, its 60p or 60i (which is interlaced), both with 28mbps and in my experience the 60i gives better image quality, but theres occasions when you need smooth footage where the 60p is a better option.
 pew pew's gear list:pew pew's gear list
Sony Alpha NEX-3N Canon EOS 100D
lancespring
Senior MemberPosts: 2,521Gear list
Why on earth
KonaBlend wrote:
AVCHD
Sincerely,
TheBitCrusher
would you resurrect such an extremely old thread? It is over 2 years old. That model camera that is being discussed is not even being sold anymore. So why would you be interested in info about its specs??
Sean Nelson already gave a very detailed explanation of the situation. Did you not read his reply?
 lancespring's gear list:lancespring's gear list
Sony Cyber-shot DSC-RX10 Nikon D600 Panasonic Lumix DMC-GH3 Tamron SP 24-70mm F/2.8 Di VC USD Panasonic 12-35mm F2.8 +1 more
Sean Nelson
Re: Why on earth
In reply to lancespring, 9 months ago
KonaBlend wrote:
AVCHD
Sincerely,
TheBitCrusher
He likely has a newer model camera that uses these same abbreviations and has stumbled across this thread while trying to understand their meaning.  The typo confused him, so he asked the question and got an answer.   Seems perfectly cromulent to me...
lancespring
Re: Why on earth
In reply to Sean Nelson, 9 months ago
There is nothing whatsoever in his post to indicate that.   No reference of any kind whatsoever.
All he complains about is his eyes hurting when he read this post here in the forum.   Seems a rather pointless and meaningless comment to me.
And it is the only post that he has ever made on DPREVIEW.
I know that resurrecting the dead is currently popular in some of the new ABC TV shows this season like RESURRECTION and AGENTS OF SHIELD.  But here on DPREVIEW it is often a useless thing to do.
At least that is my opinion of bringing such old threads back to life.
dad_of_four
Veteran MemberPosts: 7,449Gear list
Re: AVCHD Acronyms?
In reply to 21st Hermit, 9 months ago
GPH? PSH? GFS? FSH?
FHD = Full HD?
Not to be pedantic, but none of those are "Acronyms", they are "Initialisms"
What's the difference?
With Acronyms, we pronounce the Initials as a word
With Initialism, we pronouce the Initials as letters
NASA, LASER, RADAR - Acronyms
IBM, AVCHD, CPU - Initialism
 dad_of_four's gear list:dad_of_four's gear list
Nikon D70 Nikon D2Xs Nikon D700 Nikon D5000 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF +10 more
Sean Nelson
Re: AVCHD Acronyms?
In reply to dad_of_four, 9 months ago
Sorry, but that's being pedantic.  IMHO it would have been worth drawing attention to if it the misuse had the potential to cause confusion or misunderstanding, but I really don't think that was the case.
dad_of_four
Re: AVCHD Acronyms?
This criticism coming from a man who uses the word cromulent ?
Ohh, now that's rich - LOL
p.s. In case you can't tell, I am purposefully being a nerd.
Sean Nelson
Re: AVCHD Acronyms?
Well, in my defence I think my use of "cromulent" shows that I treat the rules rather lightheartedly...
...although I misspelled it as "crumulent" for many years until someone pointed out my mistake!  Ironic, no?
