Fujifilm: Drop the EXR sensor
Started Feb 22, 2012 | Discussions
Photohobbyfun
Senior MemberPosts: 1,364
Feb 22, 2012
So much of the angst felt for the X10 is because of its "EXR" sensor. I know Fujifilm wants to market this as a unique feature but the truth is that the dynamic range of sensors of this type are already good enough.
The Pentax Q with its tiny compact size sensor has a DR of 11.1ev vs. FujiFilms 11.3ev.
http://www.dxomark.com/index.php/Cameras/Compare-Camera-Sensors/Compare-cameras-side-by-side/%28appareil1%29/769 |0/%28brand%29/Canon/%28appareil2%29/740|0/%28brand2%29/Fujifilm/%28appareil3%29/722|0/%28brand3%29/Pentax
Maybe the EXR sensor was really needed a few years ago but it appears that it has not become a burden.
I hope that for the next X10 and XS-1, that Fujifilm uses a normal sensor with their new pattern array that gets rid of the AA filter.
Fujifilm X10
Timur Born
Senior MemberPosts: 4,539Gear list
Re: Fujifilm: Drop the EXR sensor
In reply to Photohobbyfun, Feb 22, 2012
After gathering some experience with the pros and cons of EXR I tend to agree. The cons seem to outweigh the pros more and more.
 Timur Born's gear list:Timur Born's gear list
Panasonic Lumix DMC-LF1 Nikon D750 Olympus OM-D E-M5 Tamron SP 24-70mm F2.8 Di VC USD Olympus M.Zuiko Digital 45mm F1.8 +3 more
xoio
Regular MemberPosts: 339Gear list
In reply to Timur Born, Feb 22, 2012
Personally i think they should have continued to evolve their Super CCD technology.
The S100FS produces stunning results. It has the HR version (High Resolution).
The S5 Pro had the SR version, which gave SLR CMOS class low noise at higher ISOs.
4 years on, the sensors would probably have produced even more stunning results.
 xoio's gear list:xoio's gear list
Fujifilm FinePix S100fs Panasonic Lumix DMC-FZ1000 +1 more
buckshot
Veteran MemberPosts: 9,958Gear list
yes! like a sweet 4/3 or even bigger
Photohobbyfun
I hope that for the next X10 and XS-1, that Fujifilm uses a normal sensor with their > new pattern array that gets rid of the AA filter.
... then there is no need for over engineering
JB
I am not a photographer, I am just a guy that takes pictures.
http://buckshotsimageblog.blogspot.com/
Sunshine_boy
Veteran MemberPosts: 4,816Gear list
I have been saying that for the last 4 years!...
The success of the SCCD went straight to their heads to the point of self destruction. By all means try to improve DR but do not serve it in half-portions and force it down the customers' throats.
Best Regards
Sunshine
ps If you see someone without a smile on, give him one of yours...
 Sunshine_boy's gear list:Sunshine_boy's gear list
Fujifilm FinePix F31fd Fujifilm FinePix S6000fd Nikon Coolpix P7100 Olympus C-4000 Zoom Nikon D60 +3 more
aeneon
Senior MemberPosts: 1,063
In reply to xoio, Feb 22, 2012
Yes the Super CCD still puts a smile on my face, what a wondeful time i had with my SCCD cameras , still do actually
Photohobbyfun
Super CCD and Live View?
In reply to xoio, Feb 23, 2012
Were there any limitations to live view and super ccd? I thought I remember reading somewhere that CMOS has become more popular because it works better for live view. I believe the refresh rate for CMOS is much better and allows for better CDAF as well.
I'm not too sure on those details though.
Barry Fitzgerald
Forum ProPosts: 29,888
In reply to Photohobbyfun, Feb 23, 2012
I'd tread with some caution on DxO's numbers useful for a reference point but I would not hammer the results in stone either.
As for EXR well the F70 has no orbs so why the new ones do that's an interesting question.
alexisgreat
Veteran MemberPosts: 5,659Gear list
In reply to Barry Fitzgerald, Feb 23, 2012
Maybe because the sensor is too large for EXR or has too few pixels. One is left wondering if a 16 MP 2/3" sensor would not have this problem.
http://Alex_the_GREAT.photoshop.com
 alexisgreat's gear list:alexisgreat's gear list
Olympus C-7070 Wide Zoom Fujifilm FinePix HS20 EXR Fujifilm FinePix HS50 EXR Olympus E-520 Olympus PEN E-PL6 +3 more
Larry Winters
Veteran MemberPosts: 4,837Gear list
I'll second that
Hi PHF:
I prefer resolution over extended DR so the EXR sensor is not my cup of tea. But, if one wants a manual mega zoom, FF is all there currently is.
lw
 Larry Winters's gear list:Larry Winters's gear list
Fujifilm X-S1 Panasonic Lumix DMC-FZ1000
Wellington100
Veteran MemberPosts: 7,953Gear list
Disagree unless the new sensor is over 13ev
You have not added 2ev for DR mode.
11ev is simply not enough DR, I have a couple of 11ev cameras and they are no match (in terms of exposure flexibility) for the 13.5ev that my Fuji S5 achieves
I consider 13ev to be the gold standard and the X10 gets there easily in DR mode.
S100, S6500, S5, F300, F200, F70, F11, F31 (deceased), Z5, V10, D40, EX1
alexisgreat
Re: Disagree unless the new sensor is over 13ev
In reply to Wellington100, Feb 23, 2012
Wellington, how many EV of DR can our modern monitors display and can inkjets print out?
Wellington100
In reply to alexisgreat, Feb 23, 2012
As many as the camera can produce.
DR is nothing at all to go with printing or viewing on screen, its a property of the sensor.
Screens have only 1 level of brightness at any one time and printers have none, your prints only look as good as your ambient light. The screen and printer simply display the light and dark areas of an image from white through to black and everything in between.
A blown highlight is always white on screen and a totally unexposed area is always black. However much DR the sensor can sense will be displayed on the screen somewhere between white and black.
Screens and DR are 2 unrelated issues.
xeriwthe
Regular MemberPosts: 431
Hi Wellington,
Is there some source of information, or do you have tests, which can confirm an effective 13EV dynamic range when running x10 in ISO100 DR400 mode? or is this just based on the 11EV from test + 2EV in theory?
I'm just curious what the actual difference comes down to, in real life, how much better is it than say the canon s100?
i have the x10, love the camera, but I do wonder how much better the DR is, when using the DR modes. is the image quality and DR really up to snuff to justify the feature?
GaryJP
Veteran MemberPosts: 6,328Gear list
Canon cameras also have a DR400 setting for JPEG.
With both my Canon and my Fuji, I am not sue how much difference it makes realistically to most images.
That's why I'd rather control it myself in RAW.
“There is only you and your camera. The limitations in your photography are in yourself, for what we see is what we are.” Ernst Haas
http://garyp.zenfolio.com/p518883873/
 GaryJP's gear list:GaryJP's gear list
Sony RX100 II Canon PowerShot G1 X II Fujifilm X10 Canon PowerShot G7 X Canon PowerShot G5 X +14 more
alexisgreat
What about when LCD screen stats mention, let's say, that contrast is 1000:1... doesn't that correspond to 2^10 or 10 bits of DR? I havent seen similar figures published for printing though.
alexisgreat
glutamodo
Forum MemberPosts: 65Gear list
Re: Super CCD and Live View?
In general, how much of a huge difference between the EXR and the Super CCD sensors is there? They both are non-Bayer hexagonal arrays, aren't they? The EXRs have the color sites arranged differently so they can pixel-bin, but couldn't they just specify a backlit CMOS sensor in their old hexagonal array. I've wondered more than once what kind of sensors Fuji might have today had they never gone the EXR route and just migrated their S-CCD over to backlit CMOS.
No one ever mentions "interpolation" any more, but really, given the S-CCD and EXR atypical-arrangement arrays, aren't all such Fuji cameras having to do that? Wasn't that part of the reason for slower refresh rates on older S-CCD cameras, the bit of extra "crunch" needed to render images to a normal screen? I'm mostly asking, not saying that I know, I've always just assumed that was part of it.
 glutamodo's gear list:glutamodo's gear list
Fujifilm FinePix S9100 Fujifilm FinePix F30 Zoom Fujifilm FinePix E550 Zoom Fujifilm FinePix S100fs Fujifilm X-S1
Rachotilko
Contributing MemberPosts: 539
Curious
I am curious: what are the drawbacks of EXR technology ?
Wellington100
In reply to xeriwthe, Feb 23, 2012
xeriwthe wrote:
Hi Wellington,
DXOmark rated the X10 in full res mode at 11.3ev and we know from other tests that have been done that DR mode confers around a 2ev advantage over full res mode, hence 13+ev
This high ev is one of the reasons people are so impressed by the X10 and are comparing it to their DSLR's, it is performing like a DSLR in terms of DR and that is a big part of the reason why the images are so rich compared to compact and Oly and most M4/3 images.
In terms of DR its much better, the Canon has an ev of 11.6. I think that in real life, DR is a far more obvious issue than resolution. In the real world 6mp is plenty for computer screens and prints up to and even beyond A4.
However a lousy DR is issue at any and all resolutions. I would categorise anything in the 10's as lousy and the 11's as not enough. Bear in mind that that DR is a headline figure that degrades rapidly as ISO is increased so IMHO you can't have enough DR.
Its plenty better and I think it definitely justifies the feature in the real world where you don't actually use the full 6mp 99% of the time but being able to push and pull your image and adjust highlights and shadows with impunity, is a very big deal.
