How many shutter actuations do you REALLY get from a camera?
Started Feb 13, 2012 | Discussions
DocS
Regular MemberPosts: 255
Feb 13, 2012
Most cameras it seems have shutters that have been tested to 100,000 or 150,000 (or in the case of the D800, 200,000) actuations.
But how many actuations do we really get from a camera? Do shutters typically crap-out around 200,000 actuations?
And also, if they do crap-out, are they replaceable by Nikon?
Nikon D800
gnagel
Veteran MemberPosts: 6,709
Re: How many shutter actuations do you REALLY get from a camera?
In reply to DocS, Feb 13, 2012
Nikon replaced the shutter on my D300 for just under $300.
Glenn
gonzalu
Forum ProPosts: 10,373Gear list
My D3 has about 200,000 frames and the D2Xs
went out with almost 70,000 ... the D70 is not used much anymore and it only has about 20,000 ... high frame rates help the shutter get higher usage over its lifetime sadly
Manny
http://www.pbase.com/gonzalu/
http://www.thrustimages.com/
FCAS Member - http://fcasmembers.com/
 gonzalu's gear list:gonzalu's gear list
Sony Cyber-shot DSC-RX100 III Nikon D3 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +5 more
Deleted17
Senior MemberPosts: 1,899
110,000 from my D300...
Then, after investing $200 in the camera, it is back up and running again at 8fps...
kipourax
Contributing MemberPosts: 736Gear list
95K on my D300...
... that's when it started to be twitchy and the mirror sometimes stucked up. That was after being beaten up madly (freezing rain of Iceland, african desert sand, Canadian cold temperature and tropical humidity)
Fixed it by replacing the whole shutter. Should be good for another 100K-ish shots
-- Kipourax --
website : http://www.kipphoto.ca
more galleries : http://www.flickr.com/photos/kipourax/
 kipourax's gear list:kipourax's gear list
Nikon D300 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 16-35mm f/4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED +3 more
gtblackwell
Contributing MemberPosts: 587
Somewhere there is posted a summary of actual Nikon's , I remember reading just the 300 as that is what I have but of the several hundred examples they failed with as few as about 35,000 up two over 230,000 and in fact were all over the place. Now what is not given was the number that did not fail! My guess is that the 150,000 for a D300 was an average. I just shot away and not worry about it.
NA
KenEis
Veteran MemberPosts: 3,962
In reply to gtblackwell, Feb 13, 2012
Anyone remember the program you can use to tell you how many actuations a camera has done?
Ken Eis
http://keneis.zenfolio.com
DocS
Re: 110,000 from my D300...
In reply to Deleted17, Feb 13, 2012
Very nice photo!!
danharperphotography.com
Senior MemberPosts: 1,093
In reply to KenEis, Feb 13, 2012
I've currently got over:
-220000 on my D3
-72000 on my D3X and
-94000 on my D300
and none of them have needed any shutter work yet.
Yes, you can send it in to Nikon and they will fix or replace the shutter.
There are several programs you can use to get your shutter count, try "exif reader" in any search engine and you'll find one. Technically any program can read the info since it's just EXIF, however you need one that will specifically read that bit of info in the EXIF and correctly read it and translate it as shutter actuations.
I use "EXIF Viewer" for Mac.
-Dan
'Cameras don't take pictures, people do.'
'No one sees your camera when they're looking at your pictures.'
http://www.danharperphotography.com/ -BLOG/stock site
http://www.danharperphoto.com/ -Commercial portfolio
http://www.wpgphoto.com/ -My Winnipeg based photography community
badmoose
Contributing MemberPosts: 519
Ken Eis
You can find it in Photoshop.
Open a current photo in PS and click on File Info .. Scroll to the Advanced Tab ... Expand Schema under the Advanced Tab.. the shutter actuation cumulative total is displayed after aux:ImageNumber:
