If the OM-D is too DSLR sized for you
Started Feb 8, 2012 | Discussions
wolfie
Senior MemberPosts: 2,522
Feb 8, 2012
then consider the canon rebel a beached whale by comparison
Shoot the Light fantastic
Avaron
Regular MemberPosts: 481
Re: If the OM-D is too DSLR sized for you
In reply to wolfie, Feb 8, 2012
The hump is still ugly and unnecessary. It's just a bad design idea to make it more similar to the old OM. But without any function to it its just really really bad.
dgrogers
Veteran MemberPosts: 6,650
In reply to Avaron, Feb 8, 2012
It's got function. EVF, Accessory port, hot shoe.
texviddy
Regular MemberPosts: 123
Wouldn't be too DSLR sized ..... it's tiny .
Maybe too DSLR shaped...
wolfie
No its not ugly - I like it.
No it's not unecessary - it houses the internal EVF
No - its a great idea to tie into an iconic design the company is famous for
And - gosh again - you really are hung up on not seeing the plainly obvious - it DOES have a function. Here's a hint: the OM series were SLRs and this follows that design form - and another hint, they even put OM-D just so you might begin to understand that.
Believe it or not not everyone likes RF design with the VF on one corner - plenty of people are left eye dominant and hate that set up. But then what do you care?
And heck, all those millions of DSLRs with middle-placed eye pieces - you read all the time about people hating that, don't you?
Sheesh - get over it and buy a PEN.
Jorge M
Forum MemberPosts: 58Gear list
For the THIRD time tonight........
This is the reason for the 'ugly' hump:
"The newly developed 5 axis IBIS unit is a huge element compared to E-M5´s volume. I have outlined it here with red. It contains also Olympus SSWF sensor cleaning unit. I have not seen the units or pictures of them side by side but I think this structure is some three times as big as the one in E-P3. IBIS unit forces EVF electronics situated above EVF, which together with accessory port dictates the height of EVF box"
http://www.pekkapotka.com/journal/
You people are hillarious, go back to your hump hate .
Avaron
In reply to dgrogers, Feb 8, 2012
Not really. The hump is 1-2cm above the EVF, the accessory port could be somewhere else and the hot shoe could be lower as well. I think the reason for it is pure design and that is a bad decision.
Gregm61
Forum ProPosts: 13,600Gear list
In reply to Jorge M, Feb 8, 2012
By the time you've posted this answer TWENTY times, there will still be people who just don't get it....
I am....going to get one, that is.
 Gregm61's gear list:Gregm61's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +10 more
Avaron
Some like it some don't. I don't
Its too big for that. Far to big.
I don't care about that. If the iconic design was a 20cm bulge would you like that as well because its "iconic" ? I prefer function to some pointless design choice which this clearly is.
Why don't you get off your high horse you pompous douchebag? I said nothing about RF design nor about the DSLR formfactor. So don't go about projecting your preconceived notions on other people without making sure you know what you're talking about which you clearly are not .
Avaron
No its not, its just what some dude (and probably you) thinks.
And unless someone cuts an em5 in half or at least opens it and posts some pictures of the inside, there is no credibility to it.
At all.
Andy Wilson
Senior MemberPosts: 1,538
One possible extra advantage of the pyramid...
..and we will have to wait and see if this is the case but...
perhaps it lifts the little add on flash unit that comes with the camera high enough to not be blocked by lenses like the 12-50
Avaron
In reply to Gregm61, Feb 8, 2012
What? Some dudes opinion? I have a better one. There is a little lead block in it to make it heavier. Yay, great function, right ? Prove me wrong...
Avaron
Re: One possible extra advantage of the pyramid...
In reply to Andy Wilson, Feb 8, 2012
That would be an idea. I sometimes had a lens shadow with a big lens when I wasn't careful back in the days. But then, why not just make the flash bigger or maybe even extendable ?
Andy Wilson
well I can't always answer for why camera manufacturers do certain things (tis often a mystery cap'n) but this does at least mitigate the complaints of no built in pop up flash
it seems that the principle uses of the little flash are mainly for outdoor fill (it is weatherproofed) and as a trigger for off camera optical wirelss flash
juiciness
Junior MemberPosts: 41
http://www.pekkapotka.com/journal/2012/2/8/olympus-om-d-e-m5-hands-on-preview.html
Stop whining, the hump is actually smaller than the EP-3 and VF-2 combo
Gregm61
"I don't get it, I don't get it....
http://www.youtube.com/watch?v=iY2enNCbyZo
Jon Ragnarsson
Veteran MemberPosts: 5,263Gear list
Although I would have preferred the 'cigar-box' design of the earlier E-Ps, I think Jorge is right.
Here is a close up:
The hot shoe and the accessory port go together, where else would you put it?
Remove the hotshoe/port combination?
Maybe they could have moved the viewfinder to the left, and then be able to lower the hotshoe/port assembly into the body, and just add a cm to the overall height of the body.
Of course, there might be some extra viewfinder circuitry in there...
At all.
Melbourne Park
Senior MemberPosts: 2,405Gear list
Quite right.
Stick with another camera.
The Queues are forming.
And the school bell just rang too ...
paultakeda
Senior MemberPosts: 1,782
AP2 matches hot shoe and most want a higher hot shoe.
You can't split up the AP2 and hot shoe ports and you want the flash to sit higher, now lower.
The reason is both design and function. Not liking it is a matter of opinion. Luckily, the E-P3 remains a nice option for you.
Yohan Pamudji
Senior MemberPosts: 2,859
Oh really?
Where's all this extra space you're talking about? And the accessory port has to go there because the accessories that plug into it also plug into the hot shoe.
