Registering Custom Settings with an A77 in the Memory Recall (MR) Mode
Started Feb 3, 2012 | Discussions
Michael A Schwartz Forum Member • Posts: 51
When I register custom settings in the MR mode, how do I register Aperture Priority or Shutter Priority as a setting? MR1 defaults to A and MR2 and MR3 defaults to P. I can't figure out how to change this setting.
 Michael A Schwartz's gear list:Michael A Schwartz's gear list
Sony SLT-A77 Sony a7R II Sigma 18-250mm F3.5-6.3 DC OS HSM Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* Sigma 150mm F2.8 EX DG OS Macro HSM +8 more
Sony SLT-A77
Edward Sargent
Edward Sargent Veteran Member • Posts: 4,693
Re: Registering Custom Settings with an A77 in the Memory Recall (MR) Mode
Simply set the dial on whatever setting you want select menu / select memory / select the memory position and push the center position of the joy stick. If you navigate to the memory selection via the FN button you are only selting to use those setting not change them.
Sarge
A77, A700 8mm Bower, 50mm 1.7, 35-70 F4, 90mm Tamron, 18-250 Sigma & 50-500 Bigma
Fisheye photos at http://sony-snapper.com/Fish-Eye/index.html
Toy - Asus Transformer Android 3.2.1 tablet
Albums at http://www.sony-snapper.com
 Edward Sargent's gear list:Edward Sargent's gear list
Sony Cyber-shot DSC-QX10 Sony Alpha a99 Sony a77 II Sony 70-200mm F2.8 G Sony 70-300mm F4.5-5.6 G SSM +33 more
