New Tokina m4/3 300mm f6.3 lens
Started Feb 3, 2012 | Discussions
Chris_in_Osaka
Chris_in_Osaka Veteran Member • Posts: 3,799
Posted today on Japan's DCWatch site:
http://dc.watch.impress.co.jp/docs/news/20120203_509653.html
Canon 5D Mark II, 24-105mm L, 70-200mm f/4L IS, EF 50mm f1.4, Tokina 16-28mm f2.8.
Olympus E-PL1, E-PL2, 9-18mm, 14-42mm II, 17mm, 45mm f1.8 & FL-36R.
Ricoh GR-D
Sony DSC-V3 (used for IR)
 Chris_in_Osaka's gear list:Chris_in_Osaka's gear list
Olympus PEN E-PL3 Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ
JosephScha
JosephScha Veteran Member • Posts: 4,491
Re: New Tokina m4/3 300mm f6.3 lens
Wow, it's almost cute! A miniature mirror lens!
If the price is as low as some of the existing mirror lenses I just might try it.
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S +4 more
Brian D. Schneider
Brian D. Schneider Forum Pro • Posts: 18,225
Ricoh GR-D
Sweet, is it AF?
Brian Schneider
LincolnB
LincolnB Veteran Member • Posts: 4,082
Comparison to the Pana 100-300mm
At 300g and 6.6cm long it's about half the weight and length of the Panasonic 100-300m.
The Tokina mirror is manual focus, but at least it transmits EXIF to the camera body.
F/6.3 so it's a tad slower than the f/5.6 on the Panasonic.
Close focus is much better at 0.8m vs. 1.5m for the Panasonic.
The Panasonic 100-300mm is $500. The Tokina won't be anywhere near that expensive. I'm going to make a wild guess of $180-$200.
I like the samples I've seen from the Panasonic. I doubt the Tokina will be quite as nice (lower contrast, donut-shaped bokeh). Still, it looks like it would be a useful super tele and close focus lens for travel.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Sony Alpha 7 II Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
Chris_in_Osaka
Chris_in_Osaka OP Veteran Member • Posts: 3,799
Brian D. Schneider wrote:
Sweet, is it AF?
Appears to be manual focus.
Ricoh GR-D
tjuster1
tjuster1 Senior Member • Posts: 1,672
Maybe I'm wrong, but I thought the reason you rarely saw AF mirror lenses was because of PDAF issues. I certainly can't see why CDAF should present any problems whatsoever. Given how darn difficult these lenses are to focus (600mm equivalent!) it sure would be nice if someone built an AF version--is it really that hard to do?
Kuppenbender
Kuppenbender Senior Member • Posts: 1,979
I was just looking at the Tokina/Kenko 400mm f8 mirror lens thinking nice idea, but 300mm, a little smaller, a little faster would be better.
The shorter focal length would make it easier to use handheld, same goes for the wider aperture (faster shutter speeds). 'Smaller' is obviously the USP for mirror lenses, unless you have a particular fondness for doughnut bokeh.
Now there just remains the price and whether it's more like the old Tamron SP or the current Rokinon junk.
 Kuppenbender's gear list:Kuppenbender's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 +3 more
bloodycape
bloodycape Senior Member • Posts: 1,448
Seems pretty tempting. Is there any samples from this, at least based on other their other mount versions?
 bloodycape's gear list:bloodycape's gear list
Panasonic Lumix DMC-GF3 Fujifilm X-E1 Panasonic Lumix G 14mm F2.5 ASPH Fujifilm XF 27mm F2.8 +1 more
tpani
tpani Regular Member • Posts: 188
Agree. There would be enough demand if the price and size stay low. 300mm, 400mm, 500mm. Mirror lenses match the m43 idea perfectly: small lenses, possibly with some compromise in image quality if the smaller size can justify it. There is always a trade-off: in one end there are optically good lenses (like the 100-300mm) and in the other smaller and cheaper with more compromises, which would be the mirror lenses.
The cost of adding AF may be an issue to some extent. The lens is otherwise pretty cheap, so how much can the AF motor and electronics increase the price without making the lens uncompetitive? I am also wondering AF with the combination of f8, very long focal lengths, and camera+lens being hand held: how much camera shake can CDAF handle? If the CDAF sees only an image blurred by shake, it is not going to AF to anything.
technic
technic Veteran Member • Posts: 8,932
Re: Comparison to the Pana 100-300mm
no real aperture control, no AF, lower image quality than real bright tele primes without a doubt, and ugly bokeh. But yes, it could still be a nice lens for travel and casual tele shooters, if the price is right and the in-camera IS works. For the donut-bokeh, maybe in some years we can have in-camera processing that corrects this
technic
no AF
from what I remember there is only one AF mirror lens, for Sony Alpha - and it's far more expensive. Probably the cost is high because you have to move some of the small internal elements (sec. mirror?) in the lens, inside the optical path that is. You can't just move a complete segment (lens unit), which makes it mechanically more complicated.
MadsR
MadsR Senior Member • Posts: 2,235
Nice, it is a tad slow though... My current 300mm is 5.6, but it is huuuuuge, like... a freight train... hauling a space shuttle... (Old Tokina for Canon FD)
If the price is right, I will get one... 600mm equiv in something that is basically pocket size, that is nice... Anyone knows if it will have electric connection? So it will tell the camera what focal length its got?
 MadsR's gear list:MadsR's gear list
Olympus PEN E-P1 Panasonic Lumix G 20mm F1.7 ASPH +2 more
JoannaK
JoannaK Contributing Member • Posts: 637
Cute! ... Teleconverter or filters (at rear?)
I like the balanced look. Of course it's a bit big and thick, but it's 300.
I do hope it has electronics, so MF-zoom will be automatic.
Also the possibility to add 1.4 or 2.0 teleconverter would be interesting.
Any info of tripod-ring or real filters? I do hope they have thought about those.
 JoannaK's gear list:JoannaK's gear list
Olympus E-510 Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 +1 more
spacenegroes
spacenegroes Regular Member • Posts: 135
what's the macro magnification for this? 0.8m min focusing distance @ 300mm seems like it could be close to 1:1 couldn't it? i tried finding a calculator online but the only one i could find didn't seem to work properly.
tjuster1
On the other hand, AF seems to work pretty well with the 100-300mm and 75-300mm. As far as the sensor is concerned (where AF is adjusted) it doesn't know how whether that image was produced by a mirror or conventional lens.
I agree about the price, but is AF really contribute that much to the cost of a lens? The 14mm costs about $250 (street); the 17mm less; the kit lenses, some of which have IS in addition to AF, sell for about $100. I'm not saying you're wrong, but I wonder how much it would actually cost to engineer in AF. Given the nature of a long telephoto lens, I'd think you could sell it at a significant premium if it could AF.
Buchan-Grant
Buchan-Grant Senior Member • Posts: 1,976
now THAT looks interesting...
who cares if its MF, its a compact prime 600mm lens, if the quality improves upon the Zuiko MD 75-300, I'll be down for one:)
another string to M43's bow if you ask me!
Neil
http://about.me/buchangrant
 Buchan-Grant's gear list:Buchan-Grant's gear list
Olympus OM-D E-M5 Olympus PEN E-P5 Olympus E-M1 Sony Alpha 7S Panasonic Lumix DMC-GM5 +19 more
tjuster1
I think the site said 1:2; still pretty darn good.
CharlesB58
CharlesB58 Veteran Member • Posts: 7,451
The lens may simply be an existing mirror design with the mount retooled for m4/3. I doubt at this time that Tokina would opt for a dedicated m4/3 design mirror lens. They probably asked the actual manufacturer to retool an existing line for m4/3 "make it silver because Olympus is doing that" and ouila, they are instantly in the m4/3 lens game.
Some people operate cameras. Others use them to create images. There is a difference.
http://ikkens.zenfolio.com/
http://sarob-w.deviantart.com/
JoannaK
I have no idea if Tokina manufactures this lens on some other brand name, but it's not (yet) mentioned on their own web page. So it may in time appear to some other formats Besides µ4/3, but at the moment there seem to be none.
http://www.tokinalens.com/products/tokina/index.html
kenw
kenw Veteran Member • Posts: 4,891
Re: Cute! ... Teleconverter or filters (at rear?)
Mirror lenses are usually not optically that sharp, so I wonder if it would really be any good with a teleconverter.
Way too small and light for a tripod ring. 55mm thread on the front for filters though, that's nice!
Ken W
See plan in profile for equipment list
 kenw's gear list:kenw's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GM1 Olympus E-M5 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +29 more
