How do you frame your 13x19 prints?
Started Jan 28, 2012 | Discussions
Darkroomdude
Darkroomdude Regular Member • Posts: 141
I just bought a wide format printer, just wondering where you guys get your frames and mats for this size paper.
 Darkroomdude's gear list:Darkroomdude's gear list
Sony Cyber-shot DSC-RX100 III Canon EOS 7D Mark II Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 28-135mm f/3.5-5.6 IS USM +2 more
Ray Ritchie Veteran Member • Posts: 3,960
Re: How do you frame your 13x19 prints?
If you print with a 1/2-inch margin all around (12x18), and then mat with 3 inches all around, you will have an 18x24 matted print, which is a stock frame size found in most art supply stores. I sell mostly 12x18 prints on 13x19 stock for exactly this reason. You can get pre-cut mats for this size from a number of online sources. One I have used, clearbags.com, sells show kits that include mats, backing boards, and a resealable clear bag that allows customers to handle the prints without getting their finger prints all over the product:
http://www.clearbags.com/mats-backing/show-kits/clearbags-18-x-24d-show-kit.html
Ray
My blog: http://www.rritchie.com/wordpress
TomWret
TomWret Senior Member • Posts: 1,977
I print a lot of that size also. You might also try http://www.framedestination.com http://www.americanframe.com or http://www.dickblick.com .
Tom W(ret)
...a bad picture is like a missed putt, it's never your fault.
 TomWret's gear list:TomWret's gear list
Pentax K-3 II Tamron SP AF 90mm F/2.8 Di Macro Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 Epson Stylus Photo R3000 +4 more
sjwolfhope Regular Member • Posts: 435
Michael's Craft Stores sell a nice 13"X19" frame in their Home frame collection. That is what I use - print borderless and no mat. Frame is flat black and looks nice - at least to me. They often have them on sale or use the 40% off coupon that is in every Michael's ad.
Steve W.
Ramonn Regular Member • Posts: 111
I usually will print 12 x18 on a sheet of 13 x 19 and then matt to size 18 x 24 as suggested by R. Ritchie. Michaels has a nice 18 x 24 black or brown frame in their Home Collection series that is very nice. For a stock frame it is nicely constructed with considerable heft. The frame retails for $45 but if you buy during their frequent 50% off sales with an extra 25% off you can get a good frame job for next to nothing. The total for my last frame with single matt was $42.38. There is usually an additonal fee if you wish Michaels to assemble , but it is easlily done by me.
Vibrio Veteran Member • Posts: 4,004
Ikea ribba frames
you'll not find 13x19 inch frames very easily -
RedFox88 Forum Pro • Posts: 24,703
One warning about frames from Michael's is their frames generally have a very small rabbit, so you can't fit a nicely mounted and matted print inside.
Another thing if you print on 13x19 paper, borderless and frame the print you'll lose about 1/2 of the image all around . This is because putting it in the frame will hide some of the edge of whatever you put in, and the borderless print function enlarges the image to ensure no white left so that makes 3/16" or so being lost of the image.
Whenever I do print borderless, I prepare my image for printing with a 1/8" white border around the outside so that when the printer enlarges the image I lose very little of the image to the borderless print image enlarging process.
Darkroomdude
Darkroomdude OP Regular Member • Posts: 141
Thanks for all this information, being new to large format I find it all very helpful ...
tman1991 Contributing Member • Posts: 742
check this place out for mats also:
http://www.webpictureframes.com/
I print borderless 13x19s and get the 12 1/2 x 18 1/2 matted to fit in 18x24.
I have over 50 prints up in Michaels frames the home collection $21.99 each (before sales and coupons).
 tman1991's gear list:tman1991's gear list
Fujifilm X-T1 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +4 more
RDoc Regular Member • Posts: 180
Depends a lot on your taste. I frame with very thin gold metallic frames, no mat, no glass, just a protective spray. I leave a 1/8" border and the frame overlaps the image by 1/4" all around. Obviously the image surface isn't very protected, but it looks a whole lot better than with glass, particularly if you're printing on matte paper. If one got damaged I can just reprint it, although it hasn't actually been a problem at all in practice. Anyway, no one mats canvas inkjet images or mounts them under glass and the surface is at least as delicate as paper.
I generally get my frames from American Frame.
plantdoc Senior Member • Posts: 2,287
I print with a slight margin and fit the print into a frame that has precut 3D matt at 12x18. I forget the name of the frames but they are made in LA USA out of metal and easily slide open to mount the print. The advantage is you can easily swap out prints by popping off the end of the frame and sliding out the matt assembly. Inserting in a new print takes just a couple of minutes. Also, a quick hanger can be changed from horizontal to vertical in a few seconds. After all, who want to see the same print for months when you have fresh pics to display... unless you have lots of wall space. A very innovative frame system for rotating your display. Frames are thin, black, white, 3D matt and metal. I can look up the name if interested. I buy them at Cheap Petes in San Francisco. Note, not the cheapest frames, but found nothing like them.
Greg
Chas
Chas Contributing Member • Posts: 948
B&H...
http://www.bhphotovideo.com/c/search?Ntt=13x19&ci=892&N=4294204017
I just bought 4 yesterday
chas... Zenfolio user... Panasonic Lumix DMC-LX3, Canon EOS 7D, Canon EOS 30D
brentis New Member • Posts: 6
I've found that Michael's is great as well!! Their non matted 13x19 usually go for under $25 each.. I use an Epson 2880, and the largest size it prints is a 13 x 19..works out well for me!!
Brent Bellamy
http://www.brentsphotographictips.blogspot.com
Slimforu Regular Member • Posts: 142
A lot of great info in this thread. I appreciate it.
Kim R Forum Pro • Posts: 17,895
Ditto
Ditto -
I just printed out my first image larger the 8x12 on a epson 4900 I got the first of the year. Printed a 12x18 as per the first reply in this thread and will matte and frame as 18x24 as per the reply too. Wow! Cool!
Thanks for the thread and all of the suggestions and help too.
KimR
'The very fact that I find myself in agreement with you other minds perturbs me, so that I hunt for points of divergence, feeling the urgent need to make it clear that at least I reached the same conclusions by a different route.'
Framatic is the name of the frame with quick change capability. Check their offerings at framatic.com. Not the cheapest frames, but I just switched 4, 11x14 prints in about 20 minutes in 16x20 frames with white, 3D type matts. Now I can print and rotate prints as a display of recent trips, photo outings etc. Only a few family type pics are a permanent wall hanging.
Greg
DotCom Editor Veteran Member • Posts: 6,791
Print at 12x18 for 18x24 frame with 3-inch mat border
On your 13 x 19 paper, print the image at 12x18 for mounting in an 18x24 frame. That way, you'll have some white area that underlays your mat. When you cut the window in your mat to 11.75 x 17.75 inches (overlapping your image by 1/8 inch on all sides), you'll have a mat width of (about) 3 inches on all sides. Looks great. Of course, if you're lazy like me, print the image at 12.25 x 18.25 inches, then you can eliminate the fancy math and cut the window in the mat to exactly 12x18.
mimmo Junior Member • Posts: 36
Re: Print at 12x18 for 18x24 frame with 3-inch mat border
I have limited wall space .I buy 13 x19 at aaron bros in socal just 1/2 in blk wood frame
they have sales buy one at about 22.00 get one for a penny.
I then print 12 x 18 on 13 x 19 with half inch border and a 4 pt blk rule
no mat they look great. careful positioning is needed when printing I have a canon pro 9000 mk2
also do on 11x 14 paper 8x12 with 12 x 16 matt in 12 x 16 frame.
archival matts are expensive but aaron bros has many frames and good sales.Also custom framing. Good info here thanks guys
 mimmo's gear list:mimmo's gear list
Nikon D750
AusPic Regular Member • Posts: 331
I trawl through Salvation Army outlets, also Opportunity Shops, and all manner of Charitable resellers of pre loved goods where folks donate items they no longer have a use for. I get some REALLY good frames with suitable matting and glass for next to nothing, All I have to do is print to a size if not an exact match, or often I can find a perfect fit!
Cheers
Andrew G
detectorman
detectorman Regular Member • Posts: 135
Would you explain how you center your prints with the Canon PixmaPro 9000mkII please. Mine are centered in the short dimension, but offset in the long dimension when printing 8.5x11 or 13x19.
I like your black border idea. How do you set that up. I guess one could use any color in principle.
Thanks!
