hexanon on GRX
Started Jan 26, 2012 | Discussions
Reg Ister
Senior MemberPosts: 1,724Gear list
hexanon on GRX
Jan 26, 2012
Hexanon-m lenses are not cheap. Is there a way of mounting a Hexanon-AR lens on a M-mount?
Thanks.
Reg
Godfrey
Forum ProPosts: 27,167
Re: hexanon on GRX
In reply to Reg Ister, Jan 26, 2012
Try contacting RJ (seller jinfinance on Ebay). He might have a Konica Hexanon AR to Leica M mount adapter in development.
lenseye
Regular MemberPosts: 424
Re: hexanon on GRX
As far as I know none of the major known brands make this adapter, you'll have better luck trying some of the local U.S. brands maybe! The only Hexanon AR adapter I know is made by Discover Photo of China for M4/3 bodies and therefore of no use here!
By the way, the Hexanon AR lenses are among the more affordable lenses at least in Japan and can be acquired for very reasonable prices! Not so for Haxanon M lenses though! (arm and a leg!)
Godfrey
Re: hexanon on GRX
In reply to lenseye, Jan 26, 2012
RJ (jinfinance) on Ebay has a Konica AR to Micro-FourThirds adapter:
http://www.ebay.com/itm/Konica-AR-lens-Panasonic-G1-GH1-micro-4-3-adapter-/110398841410?pt=LH_DefaultDomain_0&hash=item19b448a242#ht_3270wt_1315
He was rumored to be working on a similar adapter for M-bayonet mount.
The Konica Hexar-M was a limited production camera with a relatively small number of units made. Very nice lenses by all accounts, but scarce and thereby somewhat pricey.
lenseye
Re: hexanon on GRX
In reply to Reg Ister, Jan 27, 2012
If you end up buying a non-major brand adapter, make sure you can return it in case the tolerances are off! That is known to happen with cheaper productions specially out of China. While most are pretty nice ( I have a couple) the percentage of bad units is much higher than, say, German or Japanese makers and hence the lower prices. If the maker allows you to send back units and swap with good ones, you will be safe as far as your purchase goes...
lenseye
Re: hexanon on GRX
In reply to Godfrey, Jan 27, 2012
Hexagon M-lenses have gone up in price over the years because of their scarcity, however, at least in Japan they can be found at almost every reputable used camera store. Example: http://www.mapcamera.com/shopping/search.php?condition_id=8936& it's all in Japanese but you get the picture...
Carl Schofield
Senior MemberPosts: 2,342Gear list
Re: hexanon on GRX
I asked RJ if he had this adapter and he said that he planned on making it. I sent a follow-up request for an update in early January, but no response so far (his shop was closed for the New Year holidays most of January).
Here was his first response about the Konica AR to M adapter on Nov 30 2011:
thank you... I'll be making it ... and keep you posted...
best,
R.J.
  • jinfinance
kanzlr
Contributing MemberPosts: 576
Re: hexanon on GRX
In reply to lenseye, Jan 27, 2012
actually, M-Hexanons are pretty cheap for what they are, and compared to the M mount competition.
They are usually half of comparable Leicas and similar to the price of a Zeiss.
lenseye
Re: hexanon on GRX
In reply to kanzlr, Jan 27, 2012
True, they are very good lenses but used to be a lot cheaper! Some of them go for over $2000 a piece in Japan! That's rivaling Leica... but they are almost as good I think, some Leica lovers debate that but nevertheless... if you find one at a good price... go for it, sooner or later there will be an M or L adapter for it!
tomkmem
Forum MemberPosts: 88Gear list
Re: hexanon on GRX
I once had a M-Hexanon 28mm 2.8 and really loved it. I wish I had not sold it now. Very nice build and all. One thing I find myself doing every now and again is looking out for the special 60mm f1.2 M-Hexanon. Quite rare but the sample pics I've seen have really made me want to buy one.
Ricoh GXR
Blog: http://www.kmem.org
 tomkmem's gear list:tomkmem's gear list
Ricoh GXR Mount A12 Leica Summicron-M 50mm f/2 Carl Zeiss Biogon T* 2,8/28 ZM Carl Zeiss Biogon T* 2/35 ZM Voigtlander 35mm F1.2 Nokton
kanzlr
Re: hexanon on GRX
In reply to tomkmem, Jan 27, 2012
the 28/2.8 m-hexanon is my favorite lens on the GXR.
Unfortunately, it is not that easy to focus, even wide open. Better than on the NEX, but still not easy without the loupe.
lenseye
Re: hexanon on GRX
They regularly have the 28mm f2.8 lens at MapCamera in Tokyo and in Mint condition, it sells for 71800 Yen which is equivalent to $936!!! Currently they are sold out though! They will have more soon I am sure!
http://www.mapcamera.com/shopping/item.php?map_code=3000004445026
tomkmem
Re: hexanon on GRX
Ah right now i'll hold off. The Hexanon I'm looking for is the 60mm f1.2
Ricoh GXR
lenseye
Re: hexanon on GRX
I am not sure if holding off will help though... at this shop in Osaka where I do a lot of my camera shopping they used to have it for well... errr... Mmmm... 588000 Yen which at today's exchange rate would be a whopping $7668!! See for yourself:
http://www.yaotomi.co.jp/products/detail/6522
They claim on this page that only 200 units were ever made and hence the high price! It's just rare... and good!
Reg Ister
Re: hexanon on GRX
In reply to Carl Schofield, Jan 28, 2012
Thanks Carl, and thanks all the others!
I will have a look in the RJ site.
best,
R.J.
  • jinfinance
