Landscapes with the WATE on the NEX7
Started Jan 19, 2012 | Discussions
Jono Slack
Jono Slack OP Forum Pro • Posts: 20,220
Re: Landscapes with the WATE on the NEX7
Thank you António
AntnioGM wrote:
Jono, the third one is almost tri-dimensional. A fine capture.
António GM
http://www.flickr.com/photos/91908602@N00/
 Jono Slack's gear list:Jono Slack's gear list
Leica M Monochrom (Typ 246) Leica M9 Leica M-Monochrom Leica M Typ 240 Leica T +6 more
Jono Slack
l_objectif wrote:
Wonderful set, as usual, Jono! No matter what camera you are using, your work is always a treat!
Thank you Louis - truth is that the NEX7 is a lovely fluid camera to use - especially when you've forgotten all about the menus!
all the best
Jono Slack
Re: Nice!
Hi There Clint
that damn 50 summilux is pretty tough to find! There are a few WATEs around - I was lucky to get mine with the discount program after I got the M8 (all those years ago). It's always been a favourite.
all the best
Clint Dunn wrote:
Jono I really like that last one....great shot. I've wanted to get my hands on a WATE to pair up with my M8, but that damn 50mm Summilux keeps calling my name...
Clint
http://www.flickr.com/photos/60455482@N00/
Jono Slack
Many thanks Hugues - I was pleased with that one, but some of the credit should go to NIK software for silver efex pro2 - a great program for this kind of conversion.
all the best
Jono
hughf wrote:
Hello Jono,
thanks for sharing your experience with this combo, and for your great propostions here.
I enjoy this set very much, but i have one wich i like a bit even more....
This one is beautifull IMHO.
Hope to see more very soon .
Kind Regards.
Hugues.
Jono Slack
Hi There Gianluca
.. and many thanks -
Jono Slack
http://www.slack.co.uk
efix Senior Member • Posts: 2,028
Jono Slack wrote:
efix wrote:
Any problems with colour shift in the corners? If yes, how did you cope with it? CornerFix?
Hi there
not a problem with the WATE - or at least, if it's there it's so minimal as not to be a bother. I think that the WATE is actually a fairly retrofocal lens, and they seem to cause less issues.
Cornerfix is really good . . . but I'm really lazy, and in the end I don't use lenses which cause issues.
all the best
Ah yes, of course - I guess the WATE is a retrofocus design, thus no rays hitting the sensor at steep angles, thus no colour shift.
 efix's gear list:efix's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-G1 Olympus PEN E-P1 Olympus OM-D E-M5 Sony Alpha 7 +17 more
Paul Richman
Paul Richman Veteran Member • Posts: 3,160
Have you tried the MATE on Nex 7?
I'm really curious if it has any ray angle, color cast, corner sharpness issues on the Nex 7. I suspect it will be fine, but would really like confirmation....
Paul Richman
Pixels By Paul
 Paul Richman's gear list:Paul Richman's gear list
Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +8 more
sunhorse Senior Member • Posts: 1,512
I'm a huge fan of the WATE, and you've done a terrific job with it. Very nice series!
 sunhorse's gear list:sunhorse's gear list
Fujifilm X-E1 Fujifilm X-Pro2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Sigma 35mm F1.4 DG HSM Art Fujifilm XF 23mm F1.4 R +1 more
Jono Slack
Re: Have you tried the MATE on Nex 7?
I'm sorry Paul - I haven't tried it - I had one of the very last MATEs . . sold it, then moved heaven and earth to find another one . . got one at last . . and then found I didn't like the apparently random veiling flare, so sold it again (only to find that Leica could have fixed it!).
However - I really can't see how it could possibly be a problem on the NEX
all the best
Jono Slack
Jono Slack
Thank you.
Lovely lens isn't it!
Neil Contributing Member • Posts: 624
I really like this series. Especially no 2 & 4. Excellent.
Neil
 Neil's gear list:Neil's gear list
Leica APO-Summicron-M 90mm f/2 ASPH Leica M9 Nikon D800 Leica M Typ 240 Nikon D810 +6 more
Steven-T
Steven-T Veteran Member • Posts: 3,353
6-bit coding and lens selection in menu?
With a 6-bit coded WATE, when we set "Auto" lens selection, the "info" always shows 16-18-21/4. When we use "manual" lens selection, you have to select one of 16-18-21@16, or @18, or @21, and the info will show the selected value.
I have a non-6-bit coded MATE. It seems the auto/manual lens selection behaves the same. It's a bit cumbersome to keep on changing the manual lens selection as we "zoom". So I intend to take the bite, and send the lens for coding. Comments?
Jono Slack wrote:
Jono Slack
 Steven-T's gear list:Steven-T's gear list
Leica M9 Panasonic Lumix DMC-GH4 Sony Alpha 7R II +6 more
Re: 6-bit coding and lens selection in menu?
Jono Slack wrote:
Jono Slack
I have the 6-bit encoded WATE. With the Lens Detection function on the M9 set to "Auto" the EXIF info will always show 16mm. There is no way for the camera to know what focal length setting you have made on the lens. Without lens electronics and mount contacts such as on a DSLR, there is no way to convey this information to the camera. The indicated aperture setting in the EXIF is just a calculated value, not exact.
Manual setting would be a pain, especially if you are in a rapidly changing environment. The focal length info doesn't bother me at all. While traveling in India two years ago, this was the lens on my M9 most of the time.
Ramesh
Jono Slack
Thank you Neil
Neil
Jono Slack
HI Steven
I think it's always worth coding lenses - if not for any other reason, at least because it means you won't forget to change back from manual when you put that 18mm elmarit on (and ruin a whole batch of photos).
all the best
Jono Slack wrote:
Jono Slack
Steven-T
Thanks Sunhorse and Jono.
The MATE is at Leica NJ for coding.
But I still have 4 more non-coded. One at a time, one at a time . . .
Jono Slack wrote:
HI Steven
all the best
Jono Slack wrote:
Jono Slack
Viramati Contributing Member • Posts: 913
Re: Thanks Sunhorse and Jono.
hi Jono
Am really considering this camera. have you tried it with the 135 apo-telyt
David
http://www.dpsampson.zenfolio.com
http://www.flickr.com/photos/viramati/
 Viramati's gear list:Viramati's gear list
Sony Cyber-shot DSC-RX100 III Leica Q Sony Alpha 7 II Sony Alpha 7R II Fujifilm X-Pro2 +9 more
petercom New Member • Posts: 21
Just waiting for my WATE to arrive and be joined with my NEX-7. Nice to have confirmation that there are no issues with color casts, as also noted on the Luminous Landscape.
After seeing these pics I can hardly wait.
Don't suppose you've tried using filters with the WATE to see if they introduce color casts with the NEX-7? I'm particularly interested in a polarizer but don't want to shell out for a filter holder/adapter if it is likely to cause problems.
Steven-T
NEX-7 + APO-135-Telyt, from last weekend.
Viramati wrote:
hi Jono
David
Viramati wrote:
hi Jono
David
