Leica Tri-Elmar 28-35-50mm f4
Started Jan 9, 2012 | Discussions
l_objectif
l_objectif Forum Pro • Posts: 19,633
Re: Got the lens just now....
Check on Ebay; you may be lucky!
I don't have this lens, but I am considering it if I decide to go for a Nex camera.
I can't wait to see your test and your impression about it.
I hope you will like it.
Good luck,
Louis
My DPR Gallery (Dlux3, Dlux4,Dlux5, Nikon D300)
http://www.dpreview.com/galleries/6584690903/photos/slideshow
My contributions to DPR Challenges:
http://www.dpreview.com/members/6584690903/challenges
 l_objectif's gear list:l_objectif's gear list
Leica D-LUX 3 Leica D-LUX 4 Leica D-LUX 5 Leica D-Lux (Typ 109) Nikon D300 +8 more
l_objectif
Re: Thanks again, Louis...
I just responded to you on top.
My pleasure, my friend; I hope you will like it!
I am sure WATE and MATE are great lenses; no doubt about it; but there is a big difference in the price!
Let us informed about your expereince with this lens.
Louis
Steven-T
Steven-T Veteran Member • Posts: 3,348
Paul,
I have no real experience using R lenses. In the past, I have looked, in vane, for some R for my Canon EOS.
Leica Rs are great lenses, no doubt, whether made by Leica or outsourced (to Minolta, Sigma, Kyocera). For wide zoom, the 21-35/3.5-4Asph, and for medium zoom, the 28-90/2.8-4.5Asph, are popular (both Made in Germany), which I considered seriously; but too pricy and I opted out. Oh, Asph, oh, APO. The 35-70/4 is very small, light, and affordable.
Enjoy your toys, and have a great trip, my friend.
-Steven
Paul Richman wrote:
... I think I might like it. It's not too big or heavy, even with the Novoflex R adapter on my Nex. However, it did not come with the E60 screw in hood, and I can's find one anywhere. Do you know where I might get one?
Again, thanks for this idea! I will now test the lens for IQ.
l_objectif wrote:
Take a look at this link. It looks quite small to me!
http://www.overgaard.dk/pdf/Vario-Elmar-R_35-70_mm_Technical_Data_en.pdf
Louis
Paul Richman
Pixels By Paul
 Steven-T's gear list:Steven-T's gear list
Leica M9 Panasonic Lumix DMC-GH4 Sony Alpha 7R II +6 more
Steven-T
Paul,
-Steven
Louis
Paul Richman
Pixels By Paul
david nix Regular Member • Posts: 301
Re: Leica Tri-Elmar 28-35-50mm f4
When attached do you need the finder that comes with the lens? If not most
lens even used come with the finder. This makes for an expensive, nonusable piece of equipment.
 david nix's gear list:david nix's gear list
Sony FE 35mm F2.8 +1 more
Irakly Shanidze
Irakly Shanidze Veteran Member • Posts: 4,498
Re: What about polarizers?
pretty soon you will find that with leica m lenses colors are saturated enough even without a polarizer. that is, of course, if you use the hood.
Irakly Shanidze
http://www.shanidze.com/en
 Irakly Shanidze's gear list:Irakly Shanidze's gear list
Leica M9
Paul Richman
Paul Richman OP Veteran Member • Posts: 3,160
Interesting! But I must admit to being somewhat skeptical about this, even from such an accomplished photographer as you.
Polarizers remove reflections, eg on leafs, which can make a dramatic effect.
However, I've now put the CP setup on the Tri-Elmar. What a pain! And the filter holder has holes in it, which let light in from the back!
I'm going to post questions about this wacko design soon, in another post, but what can you tell me, Irakly?
Irakly Shanidze
Paul Richman
Pixels By Paul
 Paul Richman's gear list:Paul Richman's gear list
Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +8 more
Paul Richman
It is a waste
No use for it whatsoever. Perhaps it could be sold on ebay?
Paul Richman
Pixels By Paul
Steven-T
Paul,
Use a duct tape (cut a small arch) to tape up those stupid holes in the adapter. I find no problem with using filters on the WATE, . . . Just used my GND on the WATE yesterday. Here is a quick pano on C3, at 16mm, casual, only one sweep, done.
What Irakly said about color saturation is (quite) true (my limited prudency), but that's different from what you said about metal/water/leaf/other surface reflections etc, which is also true. I agree with both of you.
-Steven
Irakly Shanidze
Paul Richman
Pixels By Paul
Paul Richman
Duct tape???
Thanks, Steven. i must admit that I hate the idea of using duct tape on this lovely gear. Ugh! Over time, I suspect gummy adhesive from the tape will get all over... Have any idea why they left holes there?
Nice pano, Steven. Done in-camera, right?
I don't find the color saturation and contrast all that different from the Zeiss and high end Nikon lenses I've been using. But they are a bit sharper, and way smaller and lighter.
Steven-T wrote:
Paul,
-Steven
Irakly Shanidze
Paul Richman
Pixels By Paul
Paul Richman
Pixels By Paul
Paul Richman
Better solution than duct tape...
... Well, I recalled a little circular piece of black paper that came with the Leica filter holder for the Tri-Elmar. The instructions, printed right on this black paper, say it's to be used only on M9 and only with the IR filter.
However, if you push it in place, it completely blocks the holes. Yes! It does have a smaller opening than the adapter, so I was worried that it would vignette. But no! Not even at 16mm. Probably because of the APSC sensor.
Paul Richman
Pixels By Paul
Steven-T
Re: Duct tape???
Paul,
Leica uses an OVF. Many M lens hoods block partially the view, particularly the lower corner near the lens axis. The holes aid to see through the hood for composing, very beneficial.
Yes, that pano uses C3's (in-camera) sweep panorama. Quite fun to play with. From my experience, the Leica M lenses on M9 can (depends, of course!), relatively speaking to e.g. Canon L's on 5D2, a bit more saturated. But I find not so on my C3 though.
Have fun finding a solution besides a quick effort with dirty duct taping.
-Steven
Steven-T wrote:
Paul,
-Steven
Irakly Shanidze
Paul Richman
Pixels By Paul
Paul Richman
Pixels By Paul
Irakly Shanidze
Of course there are situations when polarizer is indispensable, like when shooting through the glass against which you cannot press the lens hood. What happens though, you learn to avoid those situations
As to reflections on foliage, water, etc., as unbelievable as it sounds, Leica lenses do handle them better than any other glass. The reason is, high micro-contrast, which resolves detail under the reflection making glare visibly more transparent. Incidentally, it is the micro-contrast that also makes slightly out-of-focus Leica pictures look sharper than they are. People who shoot their Summiluxes mostly wide open are not familiar with the effect, as micro-contrast becomes sufficiently high at f/2.8 and further increases when stopping down to f/8. Since Tri-Elmars are f/4, you don't have to stop down to see this. Just try it
Irakly Shanidze
Leica M9
Paul Richman
Good point.
I will try this out. My only experience with this so far is with Nikon, where it does make a big difference.
Very cool! I love this sort of insight, Irakly. I will try it out to see for myself.
Again, kudos on your website! If's fabulous. Very different from what i shoot, which makes it doubly interesting to me.
Paul Richman
Pixels By Paul
