Nex-7 AF exactly the same as 5N...complete miss AF...
Started Jan 8, 2012 | Discussions
LTZ470
Forum ProPosts: 10,049
Jan 8, 2012
Really troubled by Sony's AF on the Nex System...Sony please fix this problem, you have an excellent camera and a great system with a very poor AF system...don't care if you hve to steal the technology from Panny & Oly, if they can get a FAST accurate AF you can too! Love the size of the 7 with 18-200 Tamron on...needs a better AF period...
Center AF Single Box...Spot Metering...Shutter Priority...1/320...ISO 3200...jpegs...
Sony Alpha NEX-7
technomad
Forum MemberPosts: 58Gear list
Re: Nex-7 AF exactly the same as 5N...complete miss AF...
In reply to LTZ470, Jan 8, 2012
Are you sure it's not a lens issue? I've just got my NEX-7 and 24mm Zeiss and went out to play yesterday - used the object tracking AF function to get this shot, tracking on the dog. For a compact system camera, I was blown away by its speed and reliability
Haven't tried similar with the 18-55 or 18-200mm yet.
 technomad's gear list:technomad's gear list
Olympus E-3 Sony Alpha NEX-5 Sony Alpha NEX-7 Sony Alpha NEX-6 Olympus E-M1 +10 more
jalimb
Regular MemberPosts: 301
In reply to technomad, Jan 8, 2012
wow nice!
gfrensen
Veteran MemberPosts: 3,627
Looked at your pictures and a few things I see:
1. The kids are very low contrast, compared to the bascground
2. The background looks sharp to me (So it is an AF problem, not an lens problem)
Some tips to try:
Put of the focus assist light, focussing will go better
Remember that the camera can't tell what you wat to be in focus, so look close when focussing where the focus point is. (In this case it should be on your kids fases)
When the large AF rectangle appears instesd of the small boxes then go to MF (you can put the camera in DMF, so you can focus when the big box appears
Rememberr to only shoot when the focus is confirmed (green box)
LTZ470
In reply to gfrensen, Jan 8, 2012
Some tips to try:
Did all of that...it still back focused...AF Light was working...running some test as well against the G3 and EP3...just like I stated before AF on te Sony's is very poorly executed...while the G3 and EP3 have no issues at all...proof on the way..
FlickR Photostream:
http://www.flickr.com/photos/46756347@N08/
LTZ470
Great shot, but only one thing is different you were in bright sunlight and well lit subjects...shoot a few of you dog indoors and post those with just indoor lights alone...
LTZ470
The camera is choosing wher it wants to focus...the Oly's can do this when shooting Macros and Close Ups...
FlickR Photostream:
stabilo
Regular MemberPosts: 155
Could it be that, only half of your kids face was in the focus rectangle, and the other half of the rectangle was the spring water? In that case, the camera has to make a choice on what to focus on, since there's two different "lengths" in the focus rectangle.
TEBnewyork
Forum ProPosts: 11,185
What about face detection?
LTZ470
In reply to TEBnewyork, Jan 8, 2012
Excellent point Terry...let me try that...I can tell you this my G3 and EP3 are getting much tighter in my grip! With the prime lens on and shot wide open it's a no contest the m43 at ISO800 looks better than Nex-7 at ISO 640...
FlickR Photostream:
gfrensen
Some tips to try:
But did you try it wit AF assist light OFF It is funny but ofthen AF gets better then.
Did you get the big focus confirm box or the small one? The big one confirms that focussing is done on the large picture, not on the focus point.
seachicken2000
Senior MemberPosts: 2,570Gear list
The camera seems to be focusing on the background rather than the subject.
The trick is to take away the camera's freedom to do so. My advice is to switch to flexible focus spot and either move it onto the subject or leave it in the center and focus then re-frame.
The flexible focus spot is very precise, and will give you control over what gets focused on. I have never had the focusing issue you're showing here on my NEX-5.
A rose by any other name is still a chicken.
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Fujifilm FinePix S2 Pro Sony Alpha NEX-5 Sony Alpha NEX-7 Sony Alpha 7R +17 more
Lars
Regular MemberPosts: 411Gear list
I can confirm this (using single AF with centered AF field, no AF assist light). The Nex AF will focus on the area with higher contrast in the AF field - so if your AF area covers both an object with good contrast in the background and an object with poor contrast in the foreground, it will choose the background.
Face Detection might be a workaround.
At least make sure that your subject is covered fully with the AF field.
Another option would be to use DMF and focus assist.
I'd love to ability top make the focus area smaller.
Also, the AF is poor on horizontal lines and needs vertical lines to work well.
As hapy as I am with my 5N, the AF is neither great nor fast under less than ideal lighting.
 Lars's gear list:Lars's gear list
Canon PowerShot S100 Nikon D600 Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Nikon AF-S Nikkor 70-200mm f/4G ED VR +1 more
Helen
Senior MemberPosts: 2,750
In reply to seachicken2000, Jan 8, 2012
I second that (and some of the previous posts) - and the two points raised need to be combined: flexible spot or a single centre spot AF are more precise (which the OP doubtless already knows) - but also, as previous posters have said, results get better for being more controllable and predictable when the AF assist light is permanently disabled. When it is on, the camera defaults far too readily to a really wide focus area (basically all of the multiple points), as indicated by the wide focus box with dotted edges. Also, when the AF assist is available, the AF system gives up far too easily and will signal the inability to focus at all if can't find anything illuminated by the AF light, whereas with it turned off and aimed exactly the same way, it will very often hunt a little and then manage a lock (on the correct target, too).
LTZ470
In reply to Helen, Jan 8, 2012
Good point Helen I will try without AF assist as well..it was set to Auto...OK that cured my problem... TURN off AF Assist!!!! ...Much better...
FlickR Photostream:
Helen
In reply to Lars, Jan 8, 2012
I've always missed this option in the NEX cameras, but have found a slight improvement with the 5N, at least - using the touch screen (but with focus tracking turned off as I find that a bit unpredictable), the box that appears on touching the screen (I have single, centre point AF selected most of the time, rather than flexible spot as it hijacks the bottommost customisable button) is both smaller than usual, as well as being placeable in numerous positions. It's effectively like an instant/temporary Flexible Spot AF, without losing your own customised setting on Button B.
I've noticed that with several other brands too. Someone recently stated on a forum (don't remember which one) that CDAF shouldn't technically need to be limited to vertical lines and I can see why they say that, but it does typically seem to be.
I agree with that - it's decent, but not as fast and sensitive as the latest Olympus models (though they do become more hesitant in low light without the AF light on), Panasonics, or the Nikon 1 cameras (which are near-instant in good light due to PDAF, and a shade faster in low light than the NEX).
loicc
Regular MemberPosts: 491Gear list
Peaking can hel you in these situations.
You could activate the peaking.
It can help you to control if your subject is focused properly.
 loicc's gear list:loicc's gear list
Nikon D2H Sony Alpha NEX-7 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +5 more
LoMiTy
New MemberPosts: 5
I've been getting great AF results with face registration of my kids and face detection. If I'm not taking pics of the kids and I have time then I often use DMF. With these two functions I almost never miss a shot. Thanks all for the AF assist lamp tip.
blue_skies
Senior MemberPosts: 6,339Gear list
Re: Ok. this is from my (empirical) findings:
Below is what I discovered on the Nex-5N - which I believe is the same software algorithms as on the Nex-7.
Daytime: usually no problem
Lowlight: many issues
1.AF assist light on
  • focus is center weighted. If anything appears in the center, the focus is on the center object - often not you (people) subjects
2. iAuto / face detect
  • if peoples faces are visible (torso) and bright, the face detect focus is perfect. If the faces are small (people full size), or the background is bright, the face detect focus often misses, and another focus mode is applied.
3. Bright background
  • if anything bright is in the picture, the focus point seems to be at the leftmost transition from dark to bright, with the focus on the bright spot
  • eg. the fountain is in perfect focus, the children are not
4. Flash mode
  • turning on the flash does not change the AF algorithms. In addition the flash is often over saturated as is changes the metering mode. Turn on flash compensation to -1.3EV or something like that. Even if (indoor) bounce.
How I increased my lowlight (especially indoors) keeper rate:
A. Turn off AF assist
  • the daytime algorithms maintain themselves, and you are very sensitive to aforementioned problems. But bright faces in darker background are in focus. Standing people in dark clothes often are not.
B. Forget iAuto
  • use A mode or P mode. In A mode, select widest aperture, in P mode select slow shutter speed. Auto ISO will (always) select 1600 (for Nex-7) and 3200 (for Nex-5N), unless flash is on.
C. Change AF mode to DMF or MF
  • verify focus manually by rotating the focus ring on the E-mount lens.
  • if multiple pics, use MF: you only have to adjust the focus a little, and focus is held
  • (in DMF mode, the AF algorithm is still throwing the focus off, each time you are not halfpressing the shutter button)
D. Get a faster lens
  • it helps a little with AF, but moreover, the MF gets to be a lot easier. Under proper (indoor lighting) condition, you will even see focus peaking
  • make sure focus peaking is turned on and set to low
E. People shots / face detect
  • the face detect focus on peoples faces is actually very good and works well.
  • if you compose a shot of people torso's (e.g. from across the table) AND the faces are well lit (light on their faces), you can turn on face detect and use AF, or DMF, (3), but leave iAuto (1) and AF assist (2) both off; you will now see two small squares around the two faces, one on each person. If so, your focus is good. If no two small squares are visible, do not use AF, but use DMF, or MF to find focus.
Below some people pictures to illustrate above. These pictures were all without flash under extreme lowlight. OOC, they were actually underexposed, used LR3 to fix. In fact, the pictures shown below suggest that lighting was brighter than it actually was - see the EXIF data.
  • (images are downsampled to 2Mp)
Henry
Canon PowerShot S95 Sony Alpha NEX-7 Sony Alpha NEX-6 Sony Alpha 7 Sony E 18-55mm F3.5-5.6 OSS +27 more
DezM
Forum ProPosts: 33,312
Same thing
Yes Sony, please fix this problem. I've had issues with AF on my NEX-5N as well. Whether it be in normal light, low light or with flash. In daylight, it's ok.
The NEX tends to backfocus or focus on objects brighter than the subject, even though you have the AF point (Center AF or Flexible Mode) on your subject. I also had issues with Xmas tree lights, a few weeks back.
My troubles:
http://forums.dpreview.com/forums/read.asp?forum=1042&message=40162407
http://forums.dpreview.com/forums/read.asp?forum=1042&message=40166889
Now, I use Focus Peaking with MF Assist. That's a solution for now, but the AF isn't acceptable and that's why I sent my kit (body and 18-55mm lens) back to Sony's Service Center a couple of days ago. I'm hoping for a repair or an exchange.
Dez
http://dezsantana.com
