28mm Sigma Mini-Wide awesome legacy bargain - tests
Started Jan 5, 2012 | Discussions
Les Hall
Les Hall Senior Member • Posts: 1,385
Think I paid $25 for this one. Great typical quality Sigma build. Fairly close focus at about 0.22M, 0.7' . Macro is stated as 1:4.5. Performs great straight from f2.8 all the way through.
The last shot is the closest focus at 100% AND at f2.8! All shot at ISO 200 with a Canon FD sample with a Fotodiox adapter on my new lens testing bench now with Windex Electronics, not recommended for use on lenses - for that get WIndex Lens.
OK now I really must go clean those f$%^&* gutters!
Les
"A child of five would understand this. Send someone to fetch a child of five."
Groucho Marx
http://www.leshall.com
El Matadurr
El Matadurr Senior Member • Posts: 4,988
Re: 28mm Sigma Mini-Wide awesome legacy bargain - tests
Very nice, always good to see a bargain that can take good pictures. Though I wouldn't consider an aerosol can an "exciting" subject.....but nonetheless.
 El Matadurr's gear list:El Matadurr's gear list
Sony Alpha NEX-7 Carl Zeiss Touit 1.8/32
Les Hall
Les Hall OP Senior Member • Posts: 1,385
Here is the lens on the 5N. Handles nicely. Focus and aperture a little stiff.
Groucho Marx
Les Hall
Oooh I have something special for the next test - Oh yes, you will like this one. Maybe tomorrow. Do you like things that go bang?
Thanks, Les
Groucho Marx
Letsgokoulos
Letsgokoulos Senior Member • Posts: 1,771
I have the 24mm f/2.8 Super-Wide II. Closest focus distance is 0.18m and macro stated at 1:4.
Similar build and size to the Mini-Wide, Good handling and the performance should be similar too. I will try to provide a few pictures whenever I find time and light... if you are interested.
Only the price is unfortunately slightly higher., but I felt more comfortable with this focal length.
I'll be expecting tomorrow's bang !
Les Hall
I would like your lens too. As far as I am concerned wider is better...
Yes tomorrow will be exciting.
Les
Groucho Marx
El Matadurr
That lens looks very nice on the 5n, I might have to consider this, if only they made it in f/2 or lower...oh well.
And yes! Me likey boom boom.
Thanks, Les
Groucho Marx
Letsgokoulos
As promised, and since I got good light, here are pictures of and from the Sigma Super-Wide II 24mm f/2.8 :
f/2.8 :
f/4 :
f/5.6 :
f/8 :
f/11:
f/16 :
f/22 :
picture taken at the minimum focus distance at f/2.8 (which is more 10-12 cm, rather than the previously announced 18 cm, as a matter of fact) :
and to finish, a low-light picture at f/2.8 :
As you can see, the lense is sharp even wide open, corners are sharp as well.
I got it for 60 € 3 months ago, although it is more expensive (150-200 €) on most regular sales sites.
Marc
El Matadurr
Hey thanks for those shots, it's a shame that wide open the bokeh looks odd (I see a lot of obvious rings with bright dots in the middle with highlights). Stopped down to f/4 and beyond it look very nice. I may have to pick up this lens if I can find a deal...again though, shame its max aperture isn't f/2. I would have loved that.
Letsgokoulos
I am afraid you will have a hard time finding a 24mm f/2, unless you are prepared to pay quite a high price... and I am not even sure those would be sharp wide open, so you most likely will loose the stop you had gained if not more.
With regards to the bokeh 'rings', I do not find that odd since it is in the middle of very dark areas with rather harsh light. Unless you pixel-peep, you would not even see the 'rings'.
Anyway, I sure have seen better bokeh, but mainly much worse, particularly for wide angle lenses.
Marc
El Matadurr
Figures...oh well. I'm really interested in the Nikon 50mm f/1.2 AI-s. Being manual everything anyway, it'd be just like using it on a Nikon camera with my 7. Nice they still produce it new today. Sharpest Nikon lens at f/2, period.
Perhaps my views were a tad subjective.
You make a good point. I kinda forgot how wide it was.
El Matadurr
I just realized the bokeh problem was an optical illusion. Upon viewing the f/2.8 at full-size, I now see they are very even circles, with minimal point light showing. Also, tack-sharp on that bird house. Great stuff!
Letsgokoulos
It is a nice little and easy-to-use lens. If you manage to get a good adapter or if you correct it properly to achieve infinity, it is a pleasure for street and landscape shooting.
Marc
