sharpest aperture nikon 18-105 ED VR
Started Jan 3, 2012 | Discussions
tarandenis New Member • Posts: 4
hey guys
what is the sharpest aperture of the Nikon 18-105 ED VR lens?
The Big One Veteran Member • Posts: 4,508
Re: sharpest aperture nikon 18-105 ED VR
http://www.slrgear.com/reviews/zproducts/nikon18-105f35-56vr/tloader.htm
(Results may differ slightly based on sample variation and technique, but it is a good start at least. For best results do some tests with your own gear).
Cheers
--Wyatt
http://photos.digitalcave.ca
All images (c) unless otherwise specified, please ask me before editing.
 The Big One's gear list:The Big One's gear list
Nikon D60 Nikon D7000 Nikon AF Nikkor 50mm f/1.8D Sigma 10-20mm F4-5.6 EX DC HSM Sigma 30mm F1.4 EX DC HSM +3 more
DRode
DRode Senior Member • Posts: 2,815
Most, if not all, lenses have a sweet spot in or around a particular aperture setting. For me, I find the 18-105 is sharp from wide open (f/3/5-f/5.6 depending on the focal length). If you look very (unreasonably) closely, mine is sharpest at about f/8. I'd assume that most copies are like mine, so yours is probable sharpest at or around f/8.
Don't get too hung up on shooting at the sharpest aperture. Technique makes a much bigger difference in the sharpness of an image.
tarandenis wrote:
hey guys
mbecke Regular Member • Posts: 381
On the wide end, f9 - f11 sharpens things up beautifully. Don't need to stop down quite as much on the telephoto end; f5.6 to f8 normally produce very good results.
comoxbrit Contributing Member • Posts: 702
F7 to F8 for me.Check the images below.
schaf Contributing Member • Posts: 731
Check the image resolution analysis section of the review of the 18-105mm at lenstip.com. They plot out image resolution by focal length and aperture. it appears sharpest between F3.5 and F8 through most of its range.
As another poster noted.....I don't worry too much about trying to hit the sharpest point on this lens. It is sharp as sharp as I need everywhere.
Schaf
