Best Monitor For Photo Editing 2012?
Started Jan 1, 2012 | Discussions
bronxbombers
Forum ProPosts: 18,226
Re: Best Monitor For Photo Editing 2012?
In reply to chevysales, Jan 15, 2012
chevysales wrote:
bronxbombers wrote:
no need to go so blindlingly bright as 135/140 with some monitors though
my nec pa does fine 80-120 cd/m^2, you get deeper blacks by not going brighter than you need to for current room conditions too
chevysales wrote:
great info in this thread... the usual suspects but what catches my eyes are Ethan's recommended values of 135/140 first time I have read that and will give it a try as I can brighten or darken my working area and will love to see difference in colors if any.
my thoughts were matching prints and maybe washed out whites a bit?
will try and see. as spyder 3 elite recommends the 140 at 6500 when i have patio door levelors open and 5800 at 120 when i am usual night working setup and its also when i usually print.
D700 paired with 24-70 f2.8 and 70-200vr f2.8 along with an SB900 to brighten things up a bit....
thanx i actually went last nite from 5800 to 6500 leaving it at 120 and that in itself seems blinding...interesting enough my print came out too dark so back to 5800 i go.
but i will play around with the some settings just to see what Ethan is speaking of but it is the first time i have read this recommendation.
he was speaking of on site work so maybe thats out in a brighter world
odd that changing the color temp made it get brighter, i would stick with color temp that you want and play with brightness to change brightness
and yeah maybe he was speaking for the humans and not the molemen such as ourselves hah
NewsyL
Veteran MemberPosts: 5,634
In reply to bronxbombers, Jan 15, 2012
There still remain some manufacturers that state that having the brightness higher than 120 cd/m2 will void the warranty (80 cd/m2 for some older LCD models).
http://www.eizo.com/global/support/warranty/index.html
Newsy http://newsy.smugmug.com
Pictus
Veteran MemberPosts: 5,280
In reply to NewsyL, Jan 15, 2012
Interesting!
We should also expect longer life for the LED monitors...
http://ledhdtvtelevisions.com/lcd-and-led-tv-lifespan-expectancy/
Here http://ledhdtvtelevisions.com/lcd-and-led-tv-lifespan-expectancy/
they rate CFL TV for 50.000 to 75.000 and LED TV for 100.000+ hours.
pcunite
Senior MemberPosts: 1,397
In reply to CBEV Media, Jan 17, 2012
Here is a good list of monitors worth considering:
http://www.pchardwarehelp.com/guides/s-ips-lcd-list.php
fabrykanickow
New MemberPosts: 7
which one from those?
In reply to CBEV Media, Jun 18, 2012
Hi !
Sorry for getting between the words but maybe starting a new tread will be to much.
I'm thinking to buy a monitor. I've made selection of couple of them which are:
NEC MultiSync LCD2490WUXi2
NEC P241W
NEC PA241W
Dell U2410
Dell U2711
HP LP2475W
or ViewSonic VP2655WB
Can you tell me which one you would recommend as I' scratching my had for few days.
If you have any other ideas I would be more than happy!
I'm based in Europe, and I'm looking for 24-27' monitor 16:10(concerning 16:9 too), with at least 8-bit and quite large colour gamut.
Pictus
Re: which one from those?
In reply to fabrykanickow, Jun 18, 2012
NEC PA241W
NEC PA241W is the choice.
http://www.prad.de/en/monitore/review/2010/review-nec-pa241w.html
http://www.tftcentral.co.uk/reviews/nec_pa241w.htm
Here you understand the differences between the SV and non SV model http://www.tftcentral.co.uk/reviews/content/nec_pa271w-sv.htm#spectraview_profiler
For monitors check
http://forums.dpreview.com/forums/read.asp?forum=1004&message=41441835
fabrykanickow
New MemberPosts: 7
In reply to Pictus, Jun 19, 2012
Is it possible to get SV model in Europe? If yes than how about prizes compared to non SV?
Pictus
In reply to fabrykanickow, Jun 19, 2012
I am Brazilian and know nothing about your question.
rpps
Senior MemberPosts: 1,532Gear list
In reply to Pictus, Jun 20, 2012
http://www.overclock.net/t/1225919/yamakasi-catleap-monitor-club I got one of these off E-Bay a great glossy sIPS monitor for $300.
 rpps's gear list:rpps's gear list
Sony RX100 Nikon D600 Nikon D750 Nikon AF Nikkor 35mm f/2D Tamron SP 70-300mm F/4-5.6 Di VC USD +3 more
dengx
Contributing MemberPosts: 998
In reply to rpps, Jun 20, 2012
It is only SRGB.
It has no controls whatsoever except the LED backlight frequency unless you get the higher priced models.
Even after a hardware calibration the calibration quality is subpar compared to displays with full controls (white point, black point, RGB gain etc.).
Glossy is not preffered for retouching photos.
Now don't get me wrong, I have one (CrossOver to be exact), for its price and what it does it's fantastic, but it's not comparable to a good Eizo SX or NEC PA display.
Regards
iMars
Junior MemberPosts: 36Gear list
In reply to fabrykanickow, Jun 22, 2012
Hi!
I just purchased an 27" Eizo FlexScan SX2762W.
I do a lot of photo editing and it's prefect. It's 16:9 and 2560×1440 resolution. Pictures from my Nikon D3s shows in 24" inn full screen mode - you get black bars on each side, but this dosen't matter when you edit - the space is good for tools and palettes. The monitor is wide-gamut (adobeRGB) and can display 10-bit color from a 16-bit LUT:
http://www.eizo.com/global/products/flexscan/sx2762w/index.html
The 24" is in 16:10 aspect ratio:
http://www.eizo.com/global/products/flexscan/sx2462w/index.html
 iMars's gear list:iMars's gear list
Nikon D3S Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 135mm f/2D DC Nikon AF-Nikkor 80-200mm f/2.8D ED
Richard Katris
Veteran MemberPosts: 4,421Gear list
Re: Pixel density???????
In reply to Pultzar, Jun 22, 2012
and I am surprised by that....I assumed the 27 inch displays would use the same panel material as the 24 inch ones....and consequently would have the same pixel density....however a few minutes with Pythagoras....
and I came up with an approximate pixel density of 8814 per square inch for the 24 inch 1200x1920 monitors vs. 11853 pixels per square inch for a calculated 27 inch monitor with 2560x1440 pixels.... while not exactly the 1.44 ratio quoted...my measuring could be off on the displays themselves...and the significant thing is YES...the larger display does have significantly more pixel denisty.
On the other hand as soon as 4K displays hit the market even this will be considered low...
Surprised me alot!
Richard Katris aka Chanan
Pictus
In reply to iMars, Jun 23, 2012
iMars wrote:
Hi!
Wow! Excellent choice!!
Now for the 10-bit thing http://www.imagescience.com.au/kb/questions/152/10+Bit+Output+Support
iMars
In reply to Pictus, Jun 24, 2012
Now for the 10-bit thing: http://www.imagescience.com.au/kb/questions/152/10+Bit+Output+Support
Good link!
In this document Eizo explains the method for displaying 10-bit color on Windows using Photoshop CS5 and AMD (ATI) graphics boards that support 10-bit display (FirePro/FireGL):
http://www.eizo.com/global/support/compatibility/monitors/20.pdf
Melbourne Park
Senior MemberPosts: 2,512Gear list
In reply to Pictus, Aug 22, 2012
According to experts in Australia, the PA series that NEC supplies to the USA are not the top grade that Europe and Australia receive.
In Europe though, the NEC software that enables panel hardware communication, is not as good as the USA software. Meanwhile, Australia gets the Euro top panels, and the best (US) software for NEC.
So ... things are not always what they seem.
NEC PA241W
For monitors check
 Melbourne Park's gear list:Melbourne Park's gear list
Olympus E-1 Olympus OM-D E-M5 Olympus E-M1 Sony Alpha 7R II Panasonic Leica Summilux DG 25mm F1.4 +6 more
