Flash photography on streets
Started Dec 22, 2011 | Discussions
nanashi Regular Member • Posts: 102
Hi all;
I came back to street from documentary project. I need a break...
I wanted to do something new so I start using a flash on street photography. Let me know how do you think these images.
Thanks!
SATOKI
SATOKI NAGATA PHOTOGRAPHY
http://www.satoki.com
Documentary project "Cabrini-Green: Frances Cabrini Rowhouses."
http://www.satoki.com/archives/1155
intruder61
intruder61 Veteran Member • Posts: 3,064
Re: Flash photography on streets
i like your perspective. cheers.
Eric Kim does some nice street flash work... http://www.youtube.com/watch?v=J9vI79uflMY
Irakly Shanidze
Irakly Shanidze Veteran Member • Posts: 4,498
this is outstanding
Irakly Shanidze
http://www.shanidze.com/en
 Irakly Shanidze's gear list:Irakly Shanidze's gear list
Leica M9
hughf
hughf Senior Member • Posts: 2,749
Hello satoki,
this first one is simply magique...
My Best .
Hugues.
nanashi OP Regular Member • Posts: 102
Thanks.
Eric Kim does some nice street flash work... http://www.youtube.com/watch?v=9vI79uflMY
This is the style pf Bruce Gilden. I like his work. I am trying to do a different style.
In these my shots, flash was on the stand behind the main subject, and shoot from front.
I wanted to see how candid street photography looks like if I use flash like studio. Sounds Winogrand...
SATOKI
Prosophos
Prosophos Senior Member • Posts: 1,709
Wow.
There is so much going on in that first image that I'm astounded. If it had been planned to the last detail, I still would have been astounded, but the fact that it wasn't is even more impressive.
Wow.
Peter.
Peter | Prosophos
http://www.prosophos.com
Knorp
Knorp Veteran Member • Posts: 3,004
SATOKI
Aha, that explains it, I really was puzzled how you deployed flash here and suspected an alternative setup.
That first shot is certainly complex and intriguing. Very good.
Kind regards.
Bart
 Knorp's gear list:Knorp's gear list
Olympus E-M1 Leica Nocticron 42.5mm
Leo33 Senior Member • Posts: 2,858
Somehow I can't image you using flash for any subject, either indoors or outdoors. I find your second image interesting, but prefer your original imagery more,
Leo33
 Leo33's gear list:Leo33's gear list
Fujifilm XF1 Canon PowerShot G11
keats Regular Member • Posts: 134
Very strong work. Wonderful to see someone experimenting and developing a unique style. You are really onto something.
Not knowing anything about off-camera flash, what is the setup? Is there a remote, a cord, something else? Does the M9 have TTL flash metering, or is this all old school manual?
Thanks,
Keats
Thanks!
Irakly Shanidze wrote:
this is outstanding
Irakly Shanidze
SATOKI
Hi, Hugues.
Thanks.
hughf wrote:
Hello satoki,
My Best .
Hugues.
SATOKI
Re: Wow.
Hi Peter;
My initial plan was simple, I wanted to make silhouette of person by flash with nice background. My movement was limited by flash so I needed to have some idea. I put flash on stand the other side of sidewalk, framed these poster, and wait until person passed between flash and me.
SATOKI
Wow.
Peter.
Peter | Prosophos
Hi Leo33
Leo33
The transparency of the person's head is the effect of using flash for first one which I like a lot. Second one is the image I was expected.
SATOKI
Hi keats,
keats wrote:
Very strong work. Wonderful to see someone experimenting and developing a > unique style. You are really onto something.
Thanks! I did not used flash on street before. I am an available light person for many many years, but now Chicago become really dark after 4:00PM and wanted to do something new so I decided to use flash. Still initial experimental stage now.
Not knowing anything about off-camera flash, what is the setup? Is there a remote, > a cord, something else? Does the M9 have TTL flash metering, or is this all old > school manual?
Remote system I am using is radio transmitted type, YONGNU RF-600TX for Nikon camera ( for Canon camera does not work) on M9, and RF-602RX on flash (Canon 580EX2). They are almost as cheap as cable, one set is about $35. I tried SF20 and SF24D (auto and manual mode not TTL) and both works fine, too. M9 has TTL but can not use it because the limitation of cheap radio transmitter as well as I am mainly using Canon flash. 580EX2 has own meter system (built-in meter measures reflected light) so it is possible to use that function like TTL but i like a consistency and want to control the strength of light so I use fully manual mode. I do some test shot, check monitor and change the setting.
Flash is on the stand Manfrotto 1051 BAC Mini Compact Stand, with adapter Manfrotto 026 Swivel Lite-Tite Umbrella Adapter. They are light weight so no problem to carry.
RF-602RX is cheap ($25), and having several this, we can fire multiple flash. I do not know I will use multiple flash on street, though.
That's about it.
SATOKI
Thank you for such generous sharing of your developing technique. I've been itching to use flash again with my M, it's been years. Very different way of thinking/working.
I must also say that I am impressed with the work on your website. Your commitment and dedication to your vision and craft is very evident, and very human! Lovely and touching dedications to your dear sister. I am moved.
Thank you.
Keats
Bart;
Thanks for comments.
Oh, it is possible but a bit scared to leave M9 in distance:)
SATOKI
Paul Amyes
Paul Amyes Senior Member • Posts: 1,645
When people talk of using flash in street photography Bruce Gilden's name inevitably pops up. But I think that this work shares a similar methodology to that used by Philip-Lorca diCorcia. He would position remote controlled flash out of sight of passers by and then wait for suitable subjects to walk through. The resulting work made up his portfolio called "Heads".
http://www.guardian.co.uk/culture/2002/jan/30/artsfeatures4
Here's a video article where he discusses the work
http://streetreverbmagazine.com/2010/10/27/video-philip-lorca-dicorcia-discusses-heads-series/
I prefer this concept to that of Gilden's, mainly because I'm not pushy or abrasive like he obviously is, and his intention is to provoke a reaction. diCorcia's work is more subtle and relies on the interplay of the light on the subject which is what I think the OP is trying to achieve here.
nanashi wrote:
Thanks.
SATOKI
Hi Paul;
I remembered Philip-Lorca diCorcia's "Heads."
Honesty speaking, I do not like the sneaking style of that work on street. If I want to do head shot, I will interact with people. And when I take photos on street, I do not hide from subjects.
Bruce Gilden seems like as you said using a flash to interact with people. That is not what I want to do either.
I want to find images on street which can be done only by using flash. That is what I am thinking now.
SATOKI
markforce Contributing Member • Posts: 509
Way cool! Wish I had taken the first one, amazing! Refreshingly different, great stuff, thanks for sharing, Mark
mskuma Forum Member • Posts: 93
Satoki, this is a really impressive - well done. The impact of the first image is strong.
Michael.
http://www.flickr.com/photos/22402633@N06/
