Modifying a 49mm UV filter to fit the Z990 48.55mm lens
Started Dec 1, 2011 | Discussions
Dancheng
Contributing MemberPosts: 668
Dec 1, 2011
Here is an interesting thread in a Taiwanese forum with many images. You do not need to understand the Chinese language to read it. You need to click the URLs inside the posts to see the images.
It reports an interesting DIY project by a Z990 owner to modify the screw threads of a 49mm UV filter to fit the 48.5mm lens of the Z990:
http://www.mobile01.com/topicdetail.php?f=295&t=2337235&last=31866047
Kodak EasyShare Z990 (EasyShare Max)
Dancheng
Re: Modifying a 49mm UV filter to fit the Z990 48.55mm lens
In reply to Dancheng, Dec 1, 2011
The crux of the Taiwanese post is as follows:
Work around the 49mm filter's circumference, use a finger file to rub down the screw threads of the filter. Be patient. File a bit at one time and then try to fit the filter into the 48.5mm lens. If still too tight, file a little more. So on and so forth. Do not be too ambitious and file down the filter a lot in one go. This may lead to too loose a fit. In the end, a nice fit is achieved. There is no need to use any super-glue. There is also no need to file the rim of the 49mm lens.
Hope the above summary helps forumers who cannot read the Chinese language!
Dancheng
Further information regarding the lens cover discussed in the Taiwanese thread:
(1) One user bought an OEM lens cover for the 49mm filter. See the images in the post by "bill36112000" at the bottom of the thread.
(2) Another user filed down the two shutter arcs of the Kodak original cover. He also filed down the rim of the 49mm filter to shorten its height. See the images in the post by "asawang" near the bottom of the thread.
caucho
Regular MemberPosts: 212
In reply to Dancheng, Dec 3, 2011
Arghhh ! why did they not make the thread 49mm in the first place ?
Dancheng wrote:
(2) He also filed down the rim of the 49mm filter to shorten its height.
I suppose he was having problems with vignetting ? That is interesting, I have a polarising filter for the P880, but at full wide angle,there is slight vignetting, grinding down the filter could be a solution... thanks for posting this !
35mmGeek
Forum MemberPosts: 68
In reply to Dancheng, Feb 18, 2012
So there are 48.5mm threads on that lens, or is he just making the filter a "push fit?"
chiue
Veteran MemberPosts: 8,562Gear list
In reply to 35mmGeek, Feb 18, 2012
No, thread on the barrel. It is a push fit. They just file down a 49mm to 48.5mm.
chiue -
Nikon D5000 / Kodak Z990 P880 DX7590 Z915 DX6440 V803 M420 C190 C875 Zx3
Kodak Digital Cameras Galleries
http://www.wix.com/chiuestar/Kodak-DC
 chiue's gear list:chiue's gear list
Kodak EasyShare C875 Kodak DX6440 Kodak DX7590 Kodak EasyShare P880 Kodak EasyShare V803 +4 more
jomac77
New MemberPosts: 1
In reply to chiue, Jan 15, 2013
Hi. olympus c5060wz cameras have a 48.5 filter thread, they are still available on e/bay.
They should fit without modification
