Is 12MP good enough to make 40x60 prints?
Started Nov 16, 2011 | Discussions
nikhgan
Senior MemberPosts: 1,551
Nov 16, 2011
What's the best way to prepare the image for printing at this large size?
Do I need to rescale the image to higher resolution (eg. 6000 x 4000 pixel) ? Or I just send the image to the lab and let them do everything for me?
thanks.
SeeRoy
Senior MemberPosts: 1,475Gear list
Re: Is 12MP good enough to make 40x60 prints?
In reply to nikhgan, Nov 16, 2011
I'd say it depends on how far away from the print a viewer stands.
Faintandfuzzy
Senior MemberPosts: 3,327Gear list
Depends
I've done 30x45 prints from weddings from the D700 that looked just fine. Portraits are very forgiving. I would find landscapes unacceptably lacking in detail at that size. You could get away with portraits at 40x60 from the D700....for landscapes, I'd look elsewhere.
Keep in mind that at 40x60, your lens, capture technique and post processing will be hugely important.
 Faintandfuzzy's gear list:Faintandfuzzy's gear list
Canon PowerShot G3 Nikon Coolpix 950 Olympus E-10 Canon PowerShot SX150 IS Canon EOS D30 +10 more
Raul
Veteran MemberPosts: 7,482Gear list
Subject? intended use of the print?
glass, technique, post-processing, and several more things are needed to be able to give you a reply.
regards
"The tragedy of old age is not that one is old, but that one is young."
O.Wilde
BuffaloSoldier
Forum MemberPosts: 62
Yes.
Faintandfuzzy
In reply to BuffaloSoldier, Nov 16, 2011
BuffaloSoldier wrote:
Yes.
Interesting. Without knowing the subject matter, the situation of shooting, the printing output media, and the viewing distance....you've come up with a recommendation.
Gotta love the internet....it lets everyone be a webexpert.
Peter Aczel
Senior MemberPosts: 1,868
From what distance do you look this print?
Bigger the print more far you have to look at it. Thus 12 mp must be enough.
http://www.aczelpeter.uw.hu
JosephD05
Regular MemberPosts: 215
Re: From what distance do you look this print?
In reply to Peter Aczel, Nov 16, 2011
For landscape I would just take multiple shots and use Photoshop's auto merge function. Works like a charm.
260684
Senior MemberPosts: 1,908
Re: Depends
In reply to Faintandfuzzy, Nov 16, 2011
Agree. I print my D700 landscapes at 18x12. I'll go about half larger and that's my max. Seriously would you need to print larger anyway? If you did you have the jusitification to get another camera for that task...
nikhgan
ok, it will be a portrait, print on canvas.
It will be viewed from the normal(best) viewing distance most of the time, just like a painting in the museum. But of course, sometimes the viewer will want to come close to examine the details.
Yes.
260684
In reply to JosephD05, Nov 16, 2011
I stitch alot, but seriously photoshop CS5 is rubbish for that task. It puts distortion all over and you loose half of the image to it. I use Ptgui...
nikhgan
Re: Depends
In reply to 260684, Nov 16, 2011
Yes, I also think 40x60 is too big for portrait.
I haven't printed it yet. I may go for smaller size, either
30x40 (4:3 ratio)
or
32x48 (3:2 ratio)
The photo I am printing will be in portrait orientation.
Which aspect ratio is best for printing portraits at this large size?
With 4:3 ratio, I need to crop my photo and will lose some data. It is not that convenient since the original composition was intended not for 4:3 ratio. With 3:2 ratio, it may be too long when hanging on the wall. I think most posters we see in stores are 4:3 ratio.
michaeladawson
Veteran MemberPosts: 7,259Gear list
If its a portrait why would someone come close to view details? Are they interested in viewing skin pore structure? Sounds like someone pixel peeping.
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +17 more
jean bernier
Veteran MemberPosts: 3,109
It can't really be answered as it depends on what you expect. We know it won't be as sharp as a medium format photo but if it's an excellent file, then I'd say yes, it will look plenty sharp for most viewers. I discovered some of my D3 hi ISO files were blown up that very size by the client, put up in a lobby, and was myself amazed at the quality. Cause I know I was using ISO 1600 and would myself probably shy away from such a huge size. That was a pleasant surprise.
I have had multiple billboards done from 12mpixels, and they looked just fine. The larger the print, the greater the comfortable viewing distance...A pro lab will extrapolate the file themselves in order to get best results if required by their set up...
Jean Bernier
All photographs are only more or less credible illusions
Art Jacks
Senior MemberPosts: 1,473
Resizing
In reply to jean bernier, Nov 16, 2011
For what I consider to be my special images I have an A2 print made and framed, I much prefer to do the up sizing etc myself and just hand the lab the file at exactly the size I require rather than let them do it, I have found in the past that this approach and careful examination of the enlarged image on screen has allowed me to see things I had missed noticing previously and being pedantic ( a character flaw ! ) I know I would have to make the corrections and then get another print made.
A selection of my images can be found at http://www.photo-genesis.net follow the galleries link then select the Jacks gallery
echelon2004
Veteran MemberPosts: 8,105
40x60 what? Centimeters? That is fine if you take great care through out the workflow and only use the very best lenses and techniques.
40x60 inches? Nope, not a chance.
Anders
'It is nice to be important but it is more important to be nice'
Faintandfuzzy
Being the output is to canvas, that surface is very forgiving. I'd still say you need more then 12mp, but of that's all you've got, then add a gaussian noise layer or mono color grain to provide a tiny bit of texture. This will give the appearance of slightly more detail in the printing stage.
Yes.
BuffaloSoldier
Yes.
For this kind of question the appropriate answer is "Yes"
I made a lot of prints 40x60 with the Epson Stylus Pro 24', taken with D700
rayman 2
Veteran MemberPosts: 3,166
If you dont have the money for a better camera....
In reply to echelon2004, Nov 16, 2011
you can buy perfect resize or S spline .. that can give you better upsizing
quality the bicubic from Photoshop...
JosephD05
Re: If you dont have the money for a better camera....
In reply to rayman 2, Nov 16, 2011
Rent a Sony a900
