Nikon RAW Codec 64-bit
Started Nov 5, 2011 | Discussions
DezM
DezM Forum Pro • Posts: 34,282
Looks like we finally got a 64-bit version of Nikon RAW Codec, or did I misread this?
"Supports 64-bit versions of Windows Vista and Windows 7": http://nikonimglib.com/nefcodec/
Dez
http://dezsantana.com
rufusm
rufusm Senior Member • Posts: 2,929
Re: Nikon RAW Codec 64-bit
Thanks for the link Dez. I recently re-install my OS. I'm running Win 7 64-bit and the previous coded I installed didn't quite work for me. I'll give this one a try now.
http://www.cpetridis.com
rufusm
It finally works for me although the load times are slow.
Maraya Contributing Member • Posts: 500
Thanks for posting Dez....I had several crashes of the 64bit so I quit using it.
Barb
http://maraya.smugmug.com/
 Maraya's gear list:Maraya's gear list
Sony Cyber-shot DSC-RX100 IV Sony Cyber-shot DSC-RX10 III Nikon D750
expgatour
expgatour Contributing Member • Posts: 593
Hey Dez...
been using it for a while now ..its stable for me.
 expgatour's gear list:expgatour's gear list
Nikon D3S Nikon D4 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +2 more
lock Veteran Member • Posts: 6,183
not sure if it helped
I installed it but I had another 64-bit codec running already (fastpicture), and it worked oké.
lock
riveredger Senior Member • Posts: 1,472
Good find - thanks
 riveredger's gear list:riveredger's gear list
Olympus XZ-2 iHS Fujifilm X100S
TITCHY Senior Member • Posts: 1,101
Microsoft issued an image codec pack that included .NEF (64bit) back in july ,that works perfectly.
http://www.microsoft.com/download/en/details.aspx?id=26829
olyflyer
olyflyer Forum Pro • Posts: 23,919
Thanks. I needed just this for the V1 images.
REBlue Senior Member • Posts: 2,002
Sorry, but I must disagree. The Microsoft version does not show the edited version of the nef file. There are several situations in which I have to know whether a file has been edited, and it is aggravating to have to open the file to find out. Other than that, I've had no problems with the Microsoft version, even though I'm downloading the Nikon version as we "speak."
http://community.webshots.com/user/REBlue01
http://www.flickr.com/photos/reblue/sets/
 REBlue's gear list:REBlue's gear list
Nikon D50 Nikon D200 Nikon D300 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Flashlight Veteran Member • Posts: 6,188
The Microsoft version doesn't include the in-camera settings as rotation or picture control.
So you just see the basic image but when you made a portrait orientated one it's lying down or when for instance you set the camera to black and white you still see a colored image. So the Microsoft implementation ignores the camera settings just as ACR does. The new Nikon codec shows the actual camera settings in the thumbnail.
Philip
Where ?
I don't see any values. And i did when I used the Faststone codecs...
ar bee Regular Member • Posts: 489
ok installed the Codec, seems fine, BUT the windows 7 64Bit search function still doesnt pick up the meta-data I entered for the RAW- pics (whereas it picks up the meta data for jpegs)
Can anybody help please ?
best regards
 ar bee's gear list:ar bee's gear list
Nikon 1 J1 Nikon Df Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +7 more
b2martin_a Contributing Member • Posts: 601
If you already had the Microsoft codec installed do you have to do anything other than install the Nikon Codec for it to work properly?
If the Microsoft already made thumbnails they will not be recreated by the Nikon codec until you delete them as indicated on the download page.
Philip
Re: Where ?
I don't see any values either, I meant the camera settings (like B&W picture control) are visible in the thumbnail image.
So when you take a portrait orientated photo with the camera's B&W picture control active the Nikon codec generated thumbnail shows a portrait orientated B&W image while the Microsoft codec generated thumbnail shows a landscape orientated color image for the same photo.
Philip
brettchris Contributing Member • Posts: 505
thanks for the link, i too have been using the microsloth version ( without any issues on 2 W64 machines) but did not realize nef updates were not included in the previews.
loading up the nikon version as i write this.
 brettchris's gear list:brettchris's gear list
Fujifilm X-T1 Nikon D7200 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +5 more
