Macro Flash Controller MFC-1000 and 1200 Ringflash with SLTs?
Started Oct 28, 2011 | Discussions
imarollingstone Veteran Member • Posts: 3,636
One of my last purchases during the Minolta days was a Macro Flash Controller. This is the controller that works with both the 1200 ringflash and the 2400 Macro Flash. It works fine on both my KM7D and A700, but seriously overexposes with the 1200. Is the A55 not compatible with this?
Has anyone tried the A77 with this combo? I have yet to try the 2400 on the A55.
Shawn
 imarollingstone's gear list:imarollingstone's gear list
Sony RX100 II Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony Alpha DSLR-A900 Sony SLT-A55 +24 more
WaltKnapp Forum Pro • Posts: 13,857
Re: Macro Flash Controller MFC-1000 and 1200 Ringflash with SLTs?
I've used the Minolta macro ringflash ever since long, long ago when Minolta first brought it out. It's a critical piece of equipment in my work. Just from time to time updating as controllers changed. I've several of the heads of both types and several of the MFC-1000 controllers. It's never failed to be highly accurate for exposure in macro and closeup work for me. That includes the a700. Only done a few test shots with the a55 in the store with it, but those were ok. Either using the 1200 as main light source or as secondary fill light with the a700 it's been right on as usual.
Are you using the 1200 for macro/closeup, or into trying other types of shooting with it? It's a specialist flash and rarely can be pushed much beyond about 10'.
I'll be interested in this, sooner or later Sony is bound to mess up on it and yet another area will die with Sony gear. It's critical equipment in my photography. I would not expect much difference between the 1200 and 2400 as the changes are in flashtube configuration and all the exposure control is in the controller or camera body.
Walt
imarollingstone OP Veteran Member • Posts: 3,636
I just picked up another used 1200 since I had one fail recently and I was testing it to make sure it worked. I found one of the light tubes doesn't work. I'll see if I can get the seller to discount it a bit.
I don't use them often and I hadn't remembered if I had done anything with the A55, but it was way over exposed on a shot from about 6-8 feet. The same shot was fine on the A700.
Walt
Shawn
Cetonid
Cetonid Senior Member • Posts: 2,486
I'll try the 1200/MFC-1000 on an A77 next week.
I'll post back rusults on this thread.
 Cetonid's gear list:Cetonid's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 950 Panasonic Lumix DMC-ZS40 (TZ60) Sony Alpha DSLR-A350 Olympus PEN E-PL1 +12 more
Thanks (nt)
Shawn
RutgerO New Member • Posts: 8
Re: I'll try the 1200/MFC-1000 on an A77 next week.
I tried the Minolta MFC-1000 and the Minolta Ring Flash on Sony SLT-A77 at MediaMarkt. I was disappointed: The flash is not supported on A77. They had the latest A77 firmware 1.03 installed. This version of the firmware is supposed to support the Sony Twin Flash (according to Sony's web page). The Sony flash controller looks identical to MFC-1000. I really hope that Sony will fix support for the Minolta Ring Flash.
Thanks, I was afraid of that.
Shawn
A small hope, perhaps: Maybe there was a technical problem with the A77 at MediaMarkt (but I doubt it). My Minolta Ring Flash works fine with my KM 7D. I suggest that you also do a test on A77. I have mailed a question to Sony. After a week no reply from them.
I have continued to find facts about compatibility of the Minolta MCF-1000 and Minolta 1200 Ring Flash on Sony SLT-A77. This is what Sony is saying at their web-site:
http://www.sony-asia.com/support/slt-a77v/checkcompatibility
select:
  • External Flash Compatibility Chart
  • Compatibility for SLT-A77V:
http://www.sony-asia.com/support/compatibility/206669/product/slt-a77v
Under Konica Minolta Flash select "Macro Ring Flash 1200"
then "Compatible Function". The answer is: P-TTL (Pre-flash TTL) = YES
So, according to Sony, the Minolta Ring Flash 1200 is supported (but it did not fire when I tested it on A77). Maybe a further upgrade of the firmware is needed?
tom Senior Member • Posts: 2,722
select:
When I went to that link and clicked on "compatible function" - it sent me to the compatibility chart for that flash. However, in the top row of the table there are 2 columns of cameras, the NEX (not compatible) and the a-mount. But the list of cameras in the a-mount section only shows for SLTs the A33, 35, and 55. There is nothing in the table that shows A77 (even though you get to the table from the A77 compatibility page.) So unfortunately, still a ??? until someone tries it and shows it works.
tom
OK Tom, you are right. The compatibility table does not include A77. But I came to this page from a page that talked about A77 compatibility. Sony has a few things to clear up: Their web-pages to start with. But most importantly to fix support for the Minolta Ring Flash on A77.
Interesting, it does say it is compatible with the A55, but it doesn't seem to work correctly with mine. I may have the camera set to ADI flash, so I'll mess around with it and report back.
Shawn
Mark K
Mark K Veteran Member • Posts: 5,201
I also have a Canon ring flash...
I believe all should be exposed manually, no matter what system are you using.
Besides, normal flash guns with diffuse reflectors are much better
Mark K
 Mark K's gear list:Mark K's gear list
Sony Cyber-shot DSC-RX100 III Sony SLT-A77 Nikon D800 Canon EOS 5D Mark III NEX5R +64 more
Cetonid
I have no problems on the A77
I did some tests with the A77, Tamron 60mm macro and MFC-1000/1200 ringflash and exposures were pretty good between 1:4 and 1:1.
I set it on A, rear sync, ISO at 200 or lower and I'm good. The metering only gets bothered by aiming straight at a highly reflective object (so far). I have yet to try it in the field, but I see no problems yet.
HopeSpringsEternal Regular Member • Posts: 484
If you don't want it, I'll buy it off your hands.
Shawn
Leon van Roosmalen Contributing Member • Posts: 563
I use the Metz Mecablitz 15 MS-1 and it's TTL. Uses the pop-up flash to control it ( comes with a cap to block the pop-flash contributing to the exposure ).
And it can be used with Sony, Canon, Nikon, Olympus and some other brands.
It can be used manual also.
Greetings Leon.
http://www.pictureshow.nl/
 Leon van Roosmalen's gear list:Leon van Roosmalen's gear list
Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-300mm F4.5-5.6 G SSM +7 more
I don't think so I have the 2400 and have been picking up used 1200s for a while in case on goes bad. It works great on my A700 and KM7D. It was pretty painful to purchase at the time, but I'm glad I did.
Shawn
Shawn
Photos-Mike Veteran Member • Posts: 3,984
Re: I have no problems on the A77
PS It's Front Curtain Shutter set to Off, not rear sync.
Agreed, works with the Sony 100mm macro as well, but thanks for the rear sync tip, I thought it was not working until I switched it.
Observations / Questions:
1) When you turn the camera on, the controller switches on automatically. It doesn't do this on the A900. It also does this with the Sony twin macro flash.
2) In A mode on the A900 the shutter speed is fixed at 1/100. On the A77, it's fixed at 1/60. Any reason for this that anyone can think of? Maybe because there's no mirror so you don't need the speed? I usually use manual, but 1/60 is slow for butterflies and flowers if there's wind.
3) I must say the A77 is much faster than the A900. I'm not sure whether it's just macro - my plan is to use the A77 exclusively for a couple of weeks and then go back to the A900 to evaluate the viewfinder, so I'll know for sure at that stage.
4) Focus peaking and zooming, combined with the option to view on the LCD, seems to make a huge positive difference to focusing. I'm going to the butterfly conservatory over the weekend, so I'll know for sure after that. HOWEVER, compared to the A900, the viewfinder is just not as clear. If you want to just manual focus without using peaking or zooming, I think the A900 is better. Subject to alteration after the weekend.
5) A question about using which flash for butterflies. I have both the Minolta Ring Flash and the Sony Twin Flash, and I've never been able to decide which is better. On both, I can get light speckles reflecting off butterfly wings, and I usually dial in -.7 flash compensation, which helps somewhat.
Also on both I find that colors sometimes reproduce horribly wrong. I shoot in RAW and try to adjust WB using the auto and manual settings, but reds in particular are wrong. I find that auto WB and flash WB yield identical results. To get the colors right I used to shoot without flash and then used that (blurred) shot as a color guide. Then I got wise and bought a book from the butterfly conservatory that shows all the species.
Any help on the above would be appreciated.
Mike
http://mikekatz.smugmug.com
It's usually the switches that fail on the ring. Sometimes takes nothing more than contact cleaner to fix them.
Walt
Papasha Senior Member • Posts: 2,148
Thank you Photos-Mike and Cetonid! Works Well Now!!!!
Works, if you switch Front Curtain Shutter OFF.
Somehow that allows the pre-flesh to work. Without it – pre-flesh is not activated and pics are not exposed enough, so everything is dark. Switching Front Curtain Shutter of OFF cures that – pre-flesh is fired and exposure is dead-on.
Worked in A mode with shutter being stuck at 1/60s, but switching to M I can move shutter up to 1/250s independently whether SSS is ON or OFF. So, works pretty well, thanks guys for the Curtain Shutter OFF tip – I would give up and never use it on A77 if it wasn’t for that tip.
Some of my older work: http://www.pbase.com/papasha
 Papasha's gear list:Papasha's gear list
Sony Alpha NEX-7 Sony SLT-A77 Sony SLT-A99 Sony Alpha 7R II Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +10 more
