xz-1 menu question
Started Oct 27, 2011 | Discussions
leew8948
Contributing MemberPosts: 600Gear list
xz-1 menu question
Oct 27, 2011
Hi
can someone tell me what the "m" and "s" settings stand for in the camera record menu and what they do ??
I am not talking about manual mode on the control dial or shutter priority mode on the dial either, its in the main menu system whilst in "p" mode.
Ta
Lee
 leew8948's gear list:leew8948's gear list
Nikon Coolpix P610 Fujifilm X-A1 Olympus OM-D E-M10 II Panasonic Lumix G 25mm F1.7 ASPH
zabatman
Regular MemberPosts: 419Gear list
Re: xz-1 menu question
In reply to leew8948, Oct 27, 2011
From Olympus:
"The jpeg image size options in this camera are L (Large), M (Medium) and S (Small). The compression options in this camera are F (Fine) and N (Normal).
"The JPEG record modes in this camera are identified by a label that indicates their respective size and compression settings. The LF (Large Fine) and LN (Large Normal) JPEG modes have preset pixel dimensions and compression ratios that cannot be changed. The M and S JPEG modes are configurable. Customization of the desired Pixel Count and Compression settings is accomplished via the M S Settings function located in the Camera Menu."
 zabatman's gear list:zabatman's gear list
Olympus XZ-1 Olympus OM-D E-M5 Olympus E-M5 II Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +14 more
leew8948
In reply to zabatman, Oct 28, 2011
thanks...i read that aswell, still not sure was does m and s stand for??
i have set mine to the highest resolution and "fine" to both of them....is this right?
Lee
frdvdv
Regular MemberPosts: 244
In reply to leew8948, Oct 28, 2011
Lee
M stands for medium, S stands for small.
These are defined as customizable formats
In your normal live view on-screen menu, you can choose
RAW, LF, LN, MN, SN, LF+RAW, LN+RAW, MN+RAW, SN+RAW
as the picture format
If you choose MN or SN, you'll get the resolution and compression that you choose in the camera menu.
If you shoot in LF, LN, LN+RAW or LF+RAW, it doesn't matter what you set as the M or S resolution and compression.
These options can be handy if you want to have out-of-camera JPG's that are already resized for web publishing without having to resize them on your computer, or if you need a lot of pictures on your SD card.
leew8948
In reply to frdvdv, Oct 28, 2011
many thanks....Just got my new XZ-1 and just getting to grips with the menu's.
First impression great OOC jpegs... super macro shots are spot on !!
On auto iso it seems to pick low iso's compared to my 500d (sigma f2.8 17-70 os)
Amazing little camera was a toss up between that and a LX5 think i chose right.
Thanks for the help..
Lee
