Canon EOS 7D and using 3rd Party Lenses Questions
Started Oct 26, 2011 | Discussions
harvy3317 Forum Member • Posts: 96
So as I will be getting a Canon EOS 7D soon I wanted to ask anyone or everyone who owns a Canon EOS 7D if 3rd party lenses work good with this camera or atleast ones they have tried. I know sometimes you run across or read about some cameras not liking 3rd party lenses but how does the Canon EOS 7D hold up?
Any recommended lenses? I know their are several brands such as Tokina, Tamron, Sigma and more.
Thank you,
 harvy3317's gear list:harvy3317's gear list
Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Tamron SP AF 90mm F/2.8 Di Macro Canon EF 8-15mm f/4L Fisheye USM
birdbrain
birdbrain Veteran Member • Posts: 3,475
Re: Canon EOS 7D and using 3rd Party Lenses Questions
I think you can probably answer that question yourself as many happy users of third party lenses post on these forums.
Here are a few post to have a look at:
http://forums.dpreview.com/forums/read.asp?forum=1029&message=39670959
http://forums.dpreview.com/forums/read.asp?forum=1029&message=39675712
But companies like Sigma have a large following and their lenses are good.
Their 150 mm Macro is as good if not better than the Canon for IQ.
Also have a look here:
SLRGear Sigma lens tests:
http://www.slrgear.com/reviews/showcat.php/cat/29
If you navigate around the SLRGear site you will fine the other manufacturers as well there. Also have a look at the reviews by the users of the lens as they can be very helpful.
Photozone lens tests:
http://www.photozone.de/canon-eos
Just because it's not a Canon lens does not mean it's no good, yes there are some third party lemons out there but also some quite amazing lenses as well from not only Sigma but Tamron and Tokina to name a couple.
Phil
I wondered why the ball kept getting bigger, then it hit me.
http://www.flickr.com/photos/philthebirdbrain/
 birdbrain's gear list:birdbrain's gear list
Sony Cyber-shot DSC-RX10 II Canon EOS 5D Mark III Canon EOS 6D Canon EOS 7D Mark II Canon EF 16-35mm f/2.8L II USM +13 more
nick101 Contributing Member • Posts: 941
Thank you,
I have a 7D and I use a Tamron 17-50/2.8 and a Tamron 70-300, both image stabilised (VC in Tamron parlance) versions. They work fine with the camera - I've had no functional issues. I have no experience with Sigma lenses, but judging by posts here and elsewhere, they seem to work fine too.
Apart from an questions of quality (hotly debated here and in other places), the main disadvantage I see of 3rd party lenses is that, if there's an issue, you can't get Canon to look at the whole package, body and lens.
For me, at the moment, the much lower cost of the Tamrons has more than compensated for that.
 nick101's gear list:nick101's gear list
Sony RX100 Fujifilm X100S Canon EOS 7D Panasonic Lumix DMC-GH2 Olympus OM-D E-M5 +12 more
WoNHUSA Forum Member • Posts: 67
Sigma and Tamron are working fine for me and my 7D. The Sigma 17-50 f2.8 HSM OS is on my 7D most of the time. It is smaller and several hundred dollars less than the Canon 17-55 f2.8. The Sigma is sharp, focuses quickly and I like the colors I get from the lens. My Tamron is the 70-300 USD VC and it also focuses quickly. The pictures from the Tamron is very sharp. Both lenses have an "IS" system that works well too. These two lenses ended up costing me less than the Canon and they both work quite well...no regrets going with third party.
 WoNHUSA's gear list:WoNHUSA's gear list
Canon EOS 300D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF-S 18-55mm f/3.5-5.6 Canon EF 75-300mm f/4.0-5.6 III +2 more
jhal Senior Member • Posts: 2,178
My Tamron 17-35 ( 7 years old) and Sigma 300/2.8 ( 3 years old) work perfectly with the 7D.
All independent brands like Tamron, Tokina, Sigma are compatible with the 7D. BUT there are some older models of lenses that don't work and require re-chipping. I am talking about second hand lenses that are 7-10 years old ( pre-DSLR)
John
Thank you,
 jhal's gear list:jhal's gear list
Canon PowerShot G9 Canon EOS-1D Mark III Canon EOS 7D Canon EOS-1D Mark IV Canon EF 85mm f/1.8 USM +9 more
GammyKnee Contributing Member • Posts: 570
I've been very happy with my Sigma 10-20 zoom and Sigma 30mm prime on my 7D, though the 30mm can be hesitant to focus at close range when using contrast detect in Liveview. Other than that, no problems. In fact the only lens I've had trouble with on the 7D is the Canon 17-55, so go figure, as they say.
 GammyKnee's gear list:GammyKnee's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III
Simmo_B New Member • Posts: 1
Don't mess around with 3rd party cheap imitations. 3rd party is fine for those looking for cheap ways to get greater focal lengths or whatever, but remember that beyond the body, image quality is then all about the glass.
Spend some money, and go "L" series all the way. Spend your dollars on some glass that is purpose built for the Canon you're about to strap it to. You will not regret the purchase,and at the end of the day the lenses will likely outlive the camera body you've purchased them for.
 Simmo_B's gear list:Simmo_B's gear list
Canon EOS 7D Canon EF-S 17-85mm f/4-5.6 IS USM Canon EF 70-200mm f/4.0L USM Canon EF 70-200mm f/4L IS USM
paparios Regular Member • Posts: 482
Thank you,
I use, without any problems, the Sigma 150-500, Tamron 28-75 and Tokina 12-24 on my 7D.
Miguel
 paparios's gear list:paparios's gear list
Canon EOS 5D Mark II Canon EOS 50D Canon EOS 400D Canon EOS 7D Canon EOS M +17 more
Stollen1234 Contributing Member • Posts: 508
since you are going to buy such an advanced camera i assume that you know about photography and have basic understanding.
there are a lot of 3rd party which would work very well with this camera but why not first trying canon line of lenses..they offer a wide range of lenses.
davel33 Senior Member • Posts: 1,164
At one time all I used was Canon glass but then I wanted a 50mm 1.4 and read to many stories about the canon focus system on their 50 1.4 needing replacement so I went with the Sigma 50mm 1.4 and love the lens but I did have to send it in for calibration. On some websites the Sigma 24-70 is rated better then the Canon 24-70L. One more thing to consider is the warrenty is 4 years on a Sigma EX lens and Canon is 1 year.
The 24-70 needs +11 and the 50-150 needs +10, the 50mm 1.4 is now +1 and the 17-85 canon is +3.
Dave
7D with Zeikos grip, 17-85 EFs USM IS
Sigma 50 1.4 EX DG HSM, 24-70 2.8 EX DG HSM, 50-150 2.8 EX DC HSM II
 davel33's gear list:davel33's gear list
Canon EOS 70D Canon EOS 7D Mark II Sigma 24-70mm F2.8 EX DG HSM Sigma 2x EX DG Tele Converter Sigma 50-150mm F2.8 EX DC APO OS HSM +15 more
tonyjr
tonyjr Veteran Member • Posts: 5,256
I try to stay with Canon because the others are reverse engineered . They might not work on next body release .
There is also the color cast , noise and AF speed .
Then you get into price , weight , guarantee and just the feel .
I have used all my off brand lenses on the XTI , but only the Sigma 180 macro on 7D .
I don't use it much , but the noise is bad / don't like . Given a chance I would trade up , but few people trade down and there are other lenses I want . So I will use it till I have the other lenses .
As far as lenses go , find a size that fits your hand . In my case that is 77 mm .
10-22 , 17-55 , 70-200 [ soon 100-400 and 24-105 ] I also have 72 mm group . The 55, 58 and 52 mm are clumsy / don't feel right .
Also when you switch brands the hoods don't fit .
1st it's a hobby
7D gripped XTI gripped
Canon - efs 10-22 , 17-55 , ef 18-55 IS
EF 28-90 , 28 @ 2.8 , 50 @1.8 , 28-135 IS
L's 35-350 , 70-200 MK II IS
Quantaray lens 70-300 macro
Sigma 135 - 400 , 180 MACRO
2X III , Life Size converter
KSM filters for all
kenko auto tubes , EF 25
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
Markintosh
Markintosh Senior Member • Posts: 1,420
I had all sigmas line-up with my Canon 40D. It was calibrated by Sigma and worked perfectly. Sigma 30mm, 17-70 OS, 150mm Macro, 10-20. When I switched to 7D — they all behaved very strange — lots of mis-focusing (30-40%) — 4 of 10 shots from one position on tripod was out focus. I sold all sigmas and got Canon lenses — never been happier. 17-55 IS, 100mm L, and 70-200 f4 IS L.
This is my personal experience — I see many people have no problem with 3rd part lenses. I was very happy till I got 7D — I love quality and IQ of Sigma lenses. 7D is pushed me to get all canon set-up, and I'm not regret.
Got lens baby Sweet 35 — great with 7D, but it's manual lens.
 Markintosh's gear list:Markintosh's gear list
Canon EOS 5D Mark II Canon EOS M Canon EF 100mm f/2.8L Macro IS USM Voigtlander 40mm F2 Ultron SL II Canon EF-M 22mm f/2 STM +6 more
harvy3317 OP Forum Member • Posts: 96
Here are some of the lenses Im looking, let me know what you think.
One of the lenses Im looking for is a wide angle lens and below is three I have thought about, any word on these?
1) Sigma 18-125mm f/3.8-5.6 DC OS HSM Lens Review
2) Sigma 18-50mm f/2.8-4.5 DC OS HSM Canon-ef
3) Tamron 17-50mm f/2.8 XR Di II LD Canon-ef
Next group of lenses is for Telephoto, give me what you think.
1) Tamron SP 70-300mm f/4-5.6 Di VC USD Canon-ef
2) Canon EF 70-300mm f/4-5.6 IS USM
And the 3rd lens.
1) Canon EF-S 18-135mm f/3.5-5.6 IS
Al Giordano
Al Giordano Senior Member • Posts: 1,130
Wow 150-500, how can you argue with that focal range?
How do you like that lens?
Canon 7D, Sigma 17-70 2.8 IS, Canon EF 70-300
 Al Giordano's gear list:Al Giordano's gear list
Nikon D810 Sony Alpha 7 II Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +10 more
And the 3rd lens.
The Sigma 18-50 should be the 17-50 f2.8 HSM OS, which is a very nice lens. I have mine on my 7D most of the time and I am very happy with it. The Tamron 70-300 is also very nice. It is a great buy and produces sharp images on the 7D. Both lenses have their company's version of Ultra-Sonic (HSM and USD) and their own version of IS (OS and VC). Read some reviews and go check them out at a shop, I did and was convinced to buy.
This is a very good lens. Opinions are divided over whether the VD version is less sharp or not. If you don't need VC (stabilisation), go for the non-VC version - cheaper. I got the CV so I could use slow shutter speeds handheld (I do quite a bit of indoor low-light stuff) and for video
This is an excellent lens, as has already been said. Very good value indeed, and nice to use
The only one of those lenses I've used is the Canon 70-300. I found it to be pretty good; not super fast to focus but pretty accurate, with a good range though a little soft at 300. I did however sell it once I got the Canon 70-200 f4L which is exceptional.
I like it a lot. But I use it mostly at 500mm. It has a very good 4 stop OS (the Sigma equivalent of IS), so you can have a nice and sharp result at 500mm at 1/80 sec.
Miguel
boykinsbuddy Regular Member • Posts: 186
I had a Sigma 70-200 Ex F2.8 Macro that did not work with my 7D. It worked fine with my 1DIII and 5DII but not the 7D. It was about 4 years old and needed rechipping.
slowhands Veteran Member • Posts: 5,470
Sigma lens have been fine; Sigma flash needed firmware ($10)
7D seems to be happy with my Sigma 24-70 f2.8 I purchased way back when all I had was a 350d/xt; lens worked fine on a 40d too.
New Sigma 30mm f1.4 works fine too.
HOWEVER - 3x Sigma Super DG 500 flashes had to be sent back to Sigma for a firmware update... Fine on 40d and older bodies, but the 50d and newer introduced an incompatibility. $10 + shipping.
 slowhands's gear list:slowhands's gear list
Canon EOS 40D Canon EOS 350D Canon EOS 7D
