D7000 Reference for New Owners
Started Oct 17, 2011 | Discussions
Jimmy K.
Regular MemberPosts: 499
Oct 17, 2011
Hi, I have had D7000 for 4-5 months now. I learned quite a bit on both DP review and other resources on the web. I want to point out some of the free information that I found invaluable. Hope this is useful, particularly for new D7000 owners.
1. Ray Soares' D7000 Settings. This is also on the most bookmarked forum post. There are several threads started by Ray. I believe this post has the latest settings. You can start with Ray's settings and customize it for your personal likings.
http://forums.dpreview.com/forums/readflat.asp?forum=1034&message=37815130
2. Out There Images recommended settings, for Landscape, Portrait, P&S, and Sports. I find this is somewhat more generic and not as useful Ray's settings. But it does have variations for different shooting modes:
http://www.outthereimages.com/images/D7000_Setup_Guide.pdf
3. D7000 Configuration Settings and Set-Up Spreadsheet. With the number of camera settings available, plus the customized sets (U1, U2, and Save Settings to Memory Card), you need some way to keep track of the settings. One is for backup. Another is so that the U1 and U2 are consistent. There are some settings you purposely want to differentiate. Then there are other settings you don't care about; those should be the same, so there is no variable as you go from U1 to U2 to M/A/S. This Excel template can be used to track customized settings:
http://www.nikonians.org/forums/dcboard.php?az=show_topic&forum=329&topic_id=4398&mesg_id=4398&page=
http://www.nikonians.org/dcfp/user_files/187242.zip
4. Video. There are some limitations in Live View mode (and thus to Video), particularly on aperture settings. Once you understand the limitations, you can work around them easily. I found this link summarized all the important points for LV and Video:
http://www.dvxuser.com/V6/showthread.php?238925-Nikon-D7000-How-to-manually-control-Shutter-ISO-Aperture-%28and-more%29
5. Focus. For those who suspect front of back focus issue, you should run controlled tests. Couple links where you can download test charts and also details on how to perform the tests. (By the way, after reading dpreview forum posts, I was unnecessarily concerned about my D7000. After running focus test on my 3 lens, my D7000 is dead on and 0 offset for AF fine tune provide the best focus.)
focustestchart.com/chart.html
regex.info/blog/photo-tech/focus-chart
Hope this helps. Have fun shooting.
bhD7000
Regular MemberPosts: 317
Re: D7000 Reference for New Owners
In reply to Jimmy K., Oct 17, 2011
Thanks for the quick list. The only thing I would not use is a 45 degree angle for testing focus. You can run into more problems than its worth, and chances are focus is ok anyway.
mk500
New MemberPosts: 7Gear list
In reply to Jimmy K., Oct 18, 2011
THANK YOU!
I just received my D7000 last week, and am in love with it. But I knew there were several forum posts I had read that I wanted to reference. I just could not find some of these.
You hit on most of the ones I remember browsing. I wish this could somehow be "stickied" like some forums allow.
Mark Krueger
 mk500's gear list:mk500's gear list
Nikon Coolpix 950 Nikon D70 Nikon D7000 Nikon AF-S DX Nikkor 18-70mm f/3.5-4.5G ED-IF
