Printing your work.
Started Oct 16, 2011 | Discussions
RaymondC
Forum MemberPosts: 64
Printing your work.
Oct 16, 2011
Hello All,
I tried to post this in the printing forum, but with no luck. For 10 years I have been taking photos for electronic publication, some print, etc., but I really don't have much experience printing my photos larger than 8x10. (Largely due to procrastination). My wife an I have allocated some areas in our new home to hang some larger prints, and I was curious if anyone has suggestions on what to print on.
I have read recent blog posts from Moose Petereson, and and older Scott Kelby post on metal prints from bayphoto and imagewizards. These look beautiful online, and I will probably get a test print made, but this are expensive. What other options do I have?? Metallic paper? Glicee? What do most folks on this forum prefer??
I appreciate your input,
Raymond
olakiril2
Contributing MemberPosts: 503
Re: Printing your work.
In reply to RaymondC, Oct 16, 2011
Large metallic prints from MPix look very good on the wall and you can't say that they are expensive.
RaymondC
In reply to olakiril2, Oct 16, 2011
I would agree that metallic prints are not expensive, and that is certainly an option.
My expensive comment was to prints from Image Wizards and BayPhoto that are actually printed on a sheet of aluminum. See links:
http://www.scottkelby.com/blog/2009/archives/6589
http://imagewizards.net/upload/
So my curiosity is in the quality of how things compare. Is aluminum head and shoulders above regular metallic prints? What do folks prefer??
Catallaxy
Veteran MemberPosts: 3,593
I print on canvas, glossy, lustre, matte, metallic, true B&W, and on metal.
So which do I choose for a particular print? The medium that will work best to give teh look that I want.
canvas is good for very large prints and you can get a gallery wrap that does not even need a frame. However you lose resolution and lose fine detail.
glossy is good for prints behind museum glass. It is terrible for things that might get touched and have fingerprints on it.
luster is the workhorse, good for just about anything. Use a texture like Irish Linen to add interest to the photo.
matte is good for photos framed without glass, or in areas with high reflections and light spillover. You lose a tiny bit of resolution with matte.
metallic is good for vivid colors. Think macros and such. You lose some edge sharpness, I think, but gain some very vivid colors. I have a few portraits with this where the woman's eyes or hair are the focal point and the colors really pop - but I have also tried to print some regular portraits on it and it was not as nice as lustre or glossy.
True B&W gives a cleaner greys and blacks (not green-greys or magenta blacks) and I use it for all my B&W photos.
Prints on metal are very expensive for what you get. You basically do this so that you do not have to frame the result and can have interesting pieces.
A suggestion: You might just crop out an 8x10 part of an image that you wish to print larger so you can see if the print is going to look good at that higher print size. I did this to help me determine which print lab did the best job for various papers. Over 22 print labs later, I now know exactly which print labs do the best for various paper types and images. Relatively inexpensive compared to ordering a dozen huge prints from a print lab and then finding out that they stink (either the print lab stinks or the photos do not have enough resolution, sharpness, saturation, etc to look good printed 40x60).
Catallaxy
Meuh
Senior MemberPosts: 1,913Gear list
In reply to Catallaxy, Oct 16, 2011
I find whitewall.com to be very good and even do laser to real photo paper if you wish.
 Meuh's gear list:Meuh's gear list
Samsung GX-10 Panasonic Lumix DMC-GF1 Pentax K-5 Panasonic Lumix G 20mm F1.7 ASPH Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +3 more
ddolde
Forum MemberPosts: 99
In reply to RaymondC, Nov 2, 2011
That isn't correct to say they are printed on metal. They are first printed on a transfer media using dye based ink then fused to a specially coated sheet of aluminum under high heat and pressure. Hence the name dye-infused metal print.
Doug Dolde
http://douglasdolde.com
David Rosser
Veteran MemberPosts: 3,258Gear list
In reply to RaymondC, Nov 3, 2011
RaymondC wrote:
Hello All,
Glicee?
Raymond
Giclee is a made up word and is just another way of saying "high quality ink jet print", it's what you get if you use any of the top of the line A3+ ink jet printers. See http://en.wikipedia.org/wiki/Gicl%C3%A9e By the way the base French word which means to squirt has some rather smutty connotations in France
Dave
http://www.rosser.pwp.blueyonder.co.uk
http://www.pbase.com/dgrosser
 David Rosser's gear list:David Rosser's gear list
Panasonic Lumix DMC-LC5 Fujifilm X20 Nikon D40 Nikon D700 Nikon AF-S Nikkor 50mm f/1.4G +9 more
