LED Light Panels
Started Oct 9, 2011 | Discussions
sacentre Senior Member • Posts: 1,599
LED Light Panels
I've been surfing around looking for some small LED light panels that would be suitable for macro work that I won't need a bank loan for.
Can anyone point me to a likely source? I'm thinking of something in the region of 3" to 4" square and hoping that there are some reasonably cheap Asian products out there. I can't believe I need to pay almost US$300/- which some US manufacturers are charging.
Thanks in advance.
Trevor
 sacentre's gear list:sacentre's gear list
Canon EOS 5D Mark II Canon EF 85mm f/1.2L II USM Canon EF 200mm f/2L IS USM Canon TS-E 17mm f/4L Canon EF 100mm f/2.8 Macro USM +5 more
v_ Senior Member • Posts: 1,926
Re: LED Light Panels
Search ebay.
Viktor
'Happy shooting!'
 v_'s gear list:v_'s gear list
Nikon D2X Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF Nikkor 50mm f/1.8D Nikon AF Nikkor 85mm f/1.8D
Cerumen
Cerumen Senior Member • Posts: 1,876
Consider why you want LEDs. The expensive ones are a whole lot brighter than the cheap panels, and even an expensive panel puts out less light than any shoe mount flash (using similar shutter speeds). If you're after softer light, and that's why you want a panel, consider adding a Lumiquest diffuser to the flash. This will easily soften the light as much as an LED panel, and you'll have all the power you need.
Also, any continuous light source will be more disturbing to critters than a flash will. Continuous lights are good for video, but for still image purposes, a flash has too many solid advantages.
Duncan C Veteran Member • Posts: 7,660
I've done a ton of macro, and tried a huge variety of different lighting setups, including a pricey Sigma TTL macro flash unit. Of all of those, my favorite is also the cheapest: A simple pop-up diffuser that I attach to the front of the lens.
It gives slightly directional lighting from above, with soft shadows, and very soft-edged, natural looking highlights.
Here's a picture I took from the eBay listing back when I bought mine:
And here's a current search link that finds a very similar product on eBay:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=on+camera+flash+diffuser
And here are a few sample images taken with that setup:
Look at the highlights on the ants' exoskeletons, and also note the subtle shadows under their bodies.
It works best with a hotshoe flash, but it also works pretty well with a pop-up flash.
Duncan C
dpreview and PBase supporter.
http://www.pbase.com/duncanc
My macro gallery:
http://www.pbase.com/duncanc/macro_pictures&page=all
sacentre OP Senior Member • Posts: 1,599
My set up is mostly for focus stacking with the StackShot motorised rail device for small product photography, machined components, watches etc. The camera is tethered to a PC using Helicon Focus remote control software.
For insects or wildlife, I'd always use a macro-flash like the Canon twin lite but for a static set up an inanimate objects, continuous light would be better.
When the camera and lens is moved by tiny amounts as with StackShot system, the lights need to be stationary. Flashes can be used off camera in fixed positions while the camera moves but continuous light would give me a much easier control over shadows - like modelling lights - and the result monitored with Liveview on the PC screen. Also, when you're shooting anything up to 200 stacked shots for a single image, it represents an awful lot of flashgun wear and tear.
Trevor
Great shots, Duncan. You're use of a simple diffuser seems perfectly successful. I bought the Canon Twin Lite before I realised much similar and cheaper altrenatives (in the right hands) can achieve just as good if not better results.
Thanks for sharing the great macros.
Trevor
Duncan C
My macro gallery:
Pom_ZJ Regular Member • Posts: 176
drh681
drh681 Forum Pro • Posts: 17,052
Re: LED Light Panels =
Grow lights...
They've gone to LED because the old lights used to give away their location by power consumption levels.
Photons by the bag.
Gravitons no longer shipped outside US or Canada
You got a camera, now go out and get a life; or at least a picture of one!
 drh681's gear list:drh681's gear list
Nokia Lumia Icon
hotdog321
hotdog321 Forum Pro • Posts: 15,724
I bought these NEEWER CN-160 for video. Cheap, multi-tasking, cool and takes a variety of batteries. Pretty handy.
http://www.amazon.com/Dimmable-Digital-Camcorder-Panasonic-Samsung/dp/B004TJ6JH6/ref=sr_1_1?ie=UTF8&qid=1366232224&sr=8-1&keywords=led+camera+light
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
